05-08-2021, 06:58 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,131 | JNY-LX2 Huawei id fail Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Rebooting phone to USB update mode Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data Servicing the phone Operation failed Finished at local time: [05.08.21 11:27:10] WorkID: 133610593 |
05-10-2021, 10:34 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,059 | reply Dear User, Make sure that you reinstall the Chimera Tool drivers - specially the Huawei drivers - Then use another usb cable ( if you can use the original Huawei cable ) and another usb port for the connection. Also close all the running background tools / softwares before you start the ID remove again. Best regards Sab Chimera team Quote:
