08-03-2020, 16:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,339 | SM-J701F ''U8'' IMEI & Patch Certificate Done Chimera Mobile Phone Utility version: 25.56.1658 @ 2020-08-02 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J701F Sales Code: INS Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Nov 15 17:15:38 KST 2019 PDA Version: J701FDDU8CSK4 [november 2019, rev4] Phone Version: J701FXXU8CSK2 [november 2019, rev2] CSC Version: J701FODD8CSK4 [november 2019, rev4] Product Code: INS HIDSw Version: J701FDDU8CSK4/J701FODD8CSK4/J701FXXU8CSK2/J701FDDU8CSK4 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RZ8KA0STY8R Imei: 35XXXXXXXXXXXX Unique Number: CAJ00B0DA8FB955 Connections: AT,MTP Battery Status: 4.27V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Appropriate serial port is not available. 1. On the dial window, enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Trying to enable diagnostic mode. Be patient! Do NOT disconnect the phone! Succeeded. Trying on port SAMSUNG Mobile USB Serial Port (COM159) Diag mode available on port SAMSUNG Mobile USB Serial Port (COM159) Processing. Be patient! Do NOT disconnect the phone! Current imei: 35XXXXXXXXXXXX Repaired imei: 35XXXXXXXXXXXX Current imei2: 35XXXXXXXXXXXX Repaired imei2: 35XXXXXXXXXXX Successfully finished. Finished at local time: [08.02.20 09:53:58] WorkID: 102616293 Chimera Mobile Phone Utility version: 25.56.1658 @ 2020-08-02 Printing phone history Repair IMEI 02-Aug-20 7:50:55 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J701F Sales Code: INS Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Nov 15 17:15:38 KST 2019 PDA Version: J701FDDU8CSK4 [november 2019, rev4] Phone Version: J701FXXU8CSK2 [november 2019, rev2] CSC Version: J701FODD8CSK4 [november 2019, rev4] Product Code: INS HIDSw Version: J701FDDU8CSK4/J701FODD8CSK4/J701FXXU8CSK2/J701FDDU8CSK4 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RZ8KA0STY8R Imei: 35XXXXXXXXXXX Unique Number: CAJ00B0DA8FB955 Connections: AT,MTP Battery Status: 4.30V (97%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-11-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [08.02.20 10:37:30] WorkID: 102617824 |
05-10-2021, 10:14 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,091 | reply Dear User, Good job, thank you for the report! Best regards Sab Chimera Team Quote:
