10-20-2020, 15:32 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | a307fn repair imei fail Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: MID Sales Code: MID Country Code: Iraq Timezone: Asia/Tehran Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 20 19:15:08 KST 2019 PDA Version: A307FNXXU2ASK4 [november 2019, rev4] Phone Version: A307FNXXU2ASK4 [november 2019, rev4] CSC Version: A307FNOJM2ASK2 [november 2019, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: x Imei: x Imei2: x Battery Status: 3.77V (26%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Trying on port SAMSUNG Mobile USB Serial Port (COM254) There is no proper diag port or not responding or the warranty is void Repair imei failed. Finished at local time: [10.20.20 19:03:02] WorkID: 112016826 |
10-20-2020, 16:27 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,743 | reply Dear User, Please reflash the device with the latest firmware, then root the phone again. Use another root method then before. After that you will be able to do the imei repair! Quote:
10-22-2020, 13:25 | #3 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | still not work Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: MID Sales Code: MID Country Code: Iraq Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jul 7 13:43:45 KST 2020 PDA Version: A307FNXXU2BTG1 [july 2020, rev1] Phone Version: A307FNXXU2BTG1 [july 2020, rev1] CSC Version: A307FNOJM2BTG2 [july 2020, rev2] Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: Rx Imei: 35x Imei2: 352x Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-07-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [10.22.20 16:55:54] WorkID: 112299082 |
10-22-2020, 13:59 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: AsTeknik Elektronik
Member: 194874 Status: Offline Thanks Meter: 458 | atch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: SER Sales Code: XSG Country Code: UAE Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jul 7 13:43:45 KST 2020 PDA Version: A307FNXXU2BTG1 [july 2020, rev1] Phone Version: A307FNXXU2BTG1 [july 2020, rev1] CSC Version: A307FNOJM2BTG2 [july 2020, rev2] Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: RZ8M90JXRRW Imei: 86xx Imei2: 86xx Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-07-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.17.20 22:32:51] WorkID: 111667437 |
10-22-2020, 15:38 | #5 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Chimera Mobile Phone Utility version: 26.38.1324 @ 2020-10-22 Printing phone history Repair IMEI 10/22/2020 1:41 PM Repair IMEI 10/22/2020 1:06 PM Enable Diag Mode 10/22/2020 12:26 PM Get Info 10/22/2020 12:25 PM Repair IMEI 10/22/2020 12:23 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: MID Sales Code: MID Country Code: Iraq Timezone: Asia/Tehran Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 20 19:15:08 KST 2019 PDA Version: A307FNXXU2ASK4 [november 2019, rev4] Phone Version: A307FNXXU2ASK4 [november 2019, rev4] CSC Version: A307FNOJM2ASK2 [november 2019, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: x Imei2: x Battery Status: 3.78V (26%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-11-01 Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.22.20 19:07:38] WorkID: 112319656 |
