02-19-2021, 16:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2019 Location: ZW port of good hope
Member: 2925617 Status: Offline Thanks Meter: 49 | ..::World First G965F U14 PATCH DONE::.. Printing phone history Knoxguard Remove 2/19/2021 3:00 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Carrier ID: XFE Sales Code: XFE Country Code: SOUTHERN AFRICA Timezone: Africa/Harare Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Jan 22 14:52:52 KST 2021 PDA Version: G965FXXSEFUA1 [january 2021, rev1] Phone Version: G965FXXSEFUA1 [january 2021, rev1] CSC Version: G965FOXMEFUA1 [january 2021, rev1] Product Code: XFE HIDSw Version: G965FXXSEFUA1/G965FOXMEFUA1/G965FXXSEFUA1/G965FXXSEFUA1 Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RXXXXXXX Imei: 356XXXXXXXXXX Imei2: 356XXXXXXXXXXX Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-02-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [02.19.21 17:07:07] WorkID: 125518244 |
The Following 3 Users Say Thank You to 123frp For This Useful Post: |
02-19-2021, 21:44 | #2 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Hi there, Thank you for the post, very good work from you. IF you have more to share, even failed jobs, please do it! |
04-18-2021, 13:03 | #3 (permalink) | |
Freak Poster Join Date: May 2009 Location: Rawalpindi
Member: 1024839 Status: Offline Sonork: 100.1592057 Thanks Meter: 64 | Quote:
