Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-15-2020, 08:34   #1 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 569
A307fn u2 Repair imei failed. - SOLVED
Chimera Mobile Phone Utility version: 24.13.1846 @ 2020-03-15
Printing phone history
Repair IMEI
15/03/2020
7:28:09
AM
Patch Certificate
15/03/2020
7:23:59
AM
Repair IMEI
15/03/2020
7:20:27
AM
Repair IMEI
15/03/2020
5:37:40
AM
Patch Certificate
15/03/2020
5:32:03
AM
Repair started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A307FN
Sales Code: INS
Country Code: India
Timezone: Asia/Karachi
Android Version: 9 [PPR1.180610.011] [SDK 28]
Build Date: Wed Nov 27 21:15:59 KST 2019
PDA Version: A307FNXXU2ASKD [november 2019, revD]
Phone Version: A307FNXXU2ASKD [november 2019, revD]
CSC Version: A307FNODM2ASKD [november 2019, revD]
Product Code: INS
HIDSw Version: A307FNXXU2ASKD/A307FNODM2ASKD/A307FNXXU2ASKD/A307FNXXU2ASKD
Board Platform: EXYNOS5
Modem Platform: SHANNON327
Serial Number: RZ8M90W4H3X
Imei: 35xxxxxxxxxxxxxx
Unique Number: CCU0093DD520186
Connections: AT,MTP
Battery Status: 4.27V (100%)
Network Type: GSM
SIM Status: ABSENT,LOADED
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-11-01
Data Encryption State: encrypted
Repair imei...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Current imei: 358xxxxxxxxx
Repair imei failed.
Finished at local time: [03.15.20 12:32:54]
WorkID: 91911788
Old 03-16-2020, 11:26   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 16,917
reply
Hi,
please install complete stock firmware on your device, after the successfully firmware flash follow our instructions step by step. Please do not forget: when you change the sequence of the processes the result can be fail.
(0. install complete stock firmware)
1. Repair imei
2. root your device magisk based root method
3. patch cert
Best regards
Nicole
Repair IMEI
15/03/2020
7:28:09
AM
Patch Certificate
15/03/2020
7:23:59
AM
Repair IMEI
15/03/2020
7:20:27
AM
Repair IMEI
15/03/2020
5:37:40
AM
Patch Certificate
15/03/2020
5:32:03
AM
Repair started
Model: SM-A307FN
Sales Code: INS
Country Code: India
Product Code: INS
Connections: AT,MTP
Network Type: GSM
Knox Version: v30
Warranty Bit: 0
Repair imei...
Repair imei failed.
WorkID: 91911788
Old 03-17-2020, 06:50   #3 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 569
Chimera Mobile Phone Utility version: 24.13.1846 @ 2020-03-17
Repair IMEI
15/03/2020
7:31:57
AM
Repair IMEI
15/03/2020
7:28:09
AM
Patch Certificate
15/03/2020
7:23:59
AM
Repair IMEI
15/03/2020
7:20:27
AM
Repair IMEI
15/03/2020
5:37:40
AM
Repair started
Model: SM-A307FN
Sales Code: INS
Country Code: India
Product Code: INS
Imei: 358577102284747
Connections: AT,MTP
Battery Status: 4.08V (83%)
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Repair imei...
Current imei: 35xxxxxxxxxxxxxxxxx
Repaired imei: 35xxxxxxxxxxxxx
Current imei2: 35xxxxxxxxxxxxx
Repaired imei2: 35xxxxxxxxxxxxxxx
Successfully finished.
Finished at local time: [03.17.20 10:41:51]
WorkID: 92058978
THANKS
Old 04-23-2020, 01:11   #4 (permalink)
.::TR_LAZ::.'s Avatar
Member: 178227
Sonork: 100.1597371
Thanks Meter: 171
NO SERVİCE ... ALL OK REPAİR OK PATCH CERT OK
%10000000 TEST PATCH NO SERVİS
Preparing...
Checking root access.
The phone is rooted by: 20.4:MAGISKSU
Previously installed patchcert detected.
Reading data...
Patching certificate...
About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Successfully finished..
TR_LAZ
Old 05-08-2020, 12:49   #5 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 13,828
have you tired with Android 10
Old 07-12-2020, 14:38   #6 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 797
i also same proble i flash imei repair then root then patch all done but no service show
Old 07-13-2020, 05:46   #7 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 797
https://forum.gsmhosting.com/vbb/f89...e-but-2865390/
any one help me how to solve this problem no service show
Old 07-13-2020, 08:31   #8 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 797
Finally Solved problem
Page generated in 0.25730 seconds with 7 queries
