03-05-2021, 07:25 | #1 (permalink) |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | A30S Imei repair and patch done. because for safety and network will fast recongize.After phone powered on just 5 seconds to full work. Here is logs of easy work: Downgrade operation: Firmware update started Model: SM-A307FN Carrier ID: SER Sales Code: SER Country Code: Russia Timezone: Asia/Tashkent Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Oct 16 11:05:38 KST 2020 PDA Version: A307FNXXU2BTJ2 [october 2020, rev2] Phone Version: A307FNXXU2BTI4 [september 2020, rev4] CSC Version: A307FNOXM2BTJ2 [october 2020, rev2] Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: RZ8N20QRNPH Imei: 351709114XXXXXX Imei2: 351710114XXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-10-01 Extracting firmware... Unzipping firmware: BL_A307FNXXU2ASKA_CL16657552_QB27556737_REV00_user _low_ship.tar.md5. Unzipping firmware: AP_A307FNXXU2ASKA_CL16657552_QB27556737_REV00_user _low_ship_meta_OS9.tar.md5. Unzipping firmware: CP_A307FNXXU2ASKA_CP14490020_CL16657552_QB27556737 _REV00_user_low_ship.tar.md5. Unzipping firmware: HOME_CSC_OMC_OEM_A307FNOEM2ASKA_CL17395115_QB27558 085_REV00_user_low_ship.tar.md5. Unzipping firmware: CSC_OMC_OEM_A307FNOEM2ASKA_CL17395115_QB27558085_R EV00_user_low_ship.tar.md5. Processing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-A307F, Region: EUR, Provider: OPEN, PDA: A307FNXXU2BTJ2 Checking PIT file: A30S_EUR_OPEN_OEM.pit Writing PIT to phone. Reading PIT from phone. Flashing boot.img Flashing recovery.img Flashing dt.img Flashing dtbo.img Flashing system.img Flashing vendor.img Flashing userdata.img Flashing vbmeta.img Flashing sboot.bin Flashing param.bin Flashing cm.bin Flashing vbmeta.img Flashing modem.bin Flashing modem_debug.bin Flashing cache.img Flashing omr.img Flashing product.img Restarting phone. Successfully finished. Repair operationknox:0 without root ;-) Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: SER Sales Code: PHE Country Code: SPAIN Timezone: Asia/Tashkent Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 27 16:56:01 KST 2019 PDA Version: A307FNXXU2ASKA [november 2019, revA] Phone Version: A307FNXXU2ASKA [november 2019, revA] CSC Version: A307FNOEM2ASKA [november 2019, revA] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8N20QRNPH Imei: 351709114XXXXXX Imei2: 351710114XXXXXX Battery Status: 4.20V (96%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 351709114XXXXXX Repaired imei: 359861082XXXXXX Current imei2: 351710114XXXXXX Repaired imei2: 356468061XXXXXX Successfully finished. Patch certificatePhone rooted,but I don't know knox warranty still x0 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Carrier ID: SER Sales Code: PHE Country Code: SPAIN Timezone: Asia/Tashkent Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 27 16:56:01 KST 2019 PDA Version: A307FNXXU2ASKA [november 2019, revA] Phone Version: A307FNXXU2ASKA [november 2019, revA] CSC Version: A307FNOEM2ASKA [november 2019, revA] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8N20QRNPH Imei: 359861082XXXXXX Imei2: 356468061XXXXXX Battery Status: 4.16V (93%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. |
The Following 2 Users Say Thank You to Dilmurod1999 For This Useful Post: |
03-05-2021, 11:46 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,752 | reply Hi there, Thank you for the report. Good job from you, once again Quote:
