05-08-2017, 13:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | A320FL unable to reset FRP??? How to remove it, cause after writing Combination file phone hangs at Galaxy A3 logo and doesn't go further? BR |
05-08-2017, 15:22 | #2 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear Sir, used you chimeratool on the device ? when yes, please send us work id for it. Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-08-2017, 16:17 | #3 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | 20906875 20899265 and some other work IDs Printing phone history Reset FRP Lock 2017-05-08 14:55:54 Reset FRP Lock 2017-05-08 12:37:49 Reset FRP Lock 2017-05-08 12:34:05 Reset FRP Lock 2017-05-08 12:28:16 SW Change 2017-05-06 22:38:34 [Reset FRP lock started] Selected model: SM-A320FL Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Device unavailable. Finished at local time: [05.08.17 17:16:07] WorkID: 20906875 |
05-08-2017, 16:52 | #4 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Now I have other strange problem, unimaginable what happens to me I was flashing the phone and power supply went OFF when it was at the middle of writing system.img seems.... Now phone enters into download mode but detected only as Mediatek device and I can not flash it anymore. Even smartswitch is not detecting it anymore I need to revive it first now. |
05-08-2017, 17:06 | #5 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Now reviving it, it detected as a Samsung device finally I will post feedback when done [Firmware update started] Selected model: SM-A320FL Processing firmware... Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Flashing recovery.img Flashing system.img Flashing sboot.bin Flashing param.bin Flashing cm.bin Flashing modem.bin Flashing cache.img Flashing hidden.img Restarting phone. Finished successfully. Finished at local time: [05.08.17 18:07:40] WorkID: 20909819 Finally revived this MTK brick |
08-03-2017, 22:28 | #9 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Need to fight very hard with these cheap Mediatek devices to get FRP removed. Still didn't found a faster way than struggling 6 hours with a single phone |
09-05-2017, 21:47 | #10 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 93292 Status: Offline Sonork: www.paypal.me/FGSM Thanks Meter: 83 | Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-A320FL, Region: EUR, Provider: OPENXC, PDA: A320FLXXU1AQA8 Reading PIT. Checking firmware compatibility. Skip firmware compatibility checking. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Device unavailable. Finished at local time: [09.05.17 21:46:42] WorkID: 26100776 |
09-06-2017, 12:36 | #11 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | The firmware that you need to have a satisfactory result in the FRP solution are these: A320FLXXU1AQB3 02/2017 A320FLXXU1AQC3 03/2017 The option to use is Reset FRP Lock - New with the phone in download mode. The firmwares you can find on the chimera stand or Samsung's official website. |
