06-29-2020, 02:00 | #1 (permalink) |
Freak Poster Join Date: May 2018
Member: 2837277 Status: Offline Thanks Meter: 39 | a515f u3 repair imei but imei ng Chimera Mobile Phone Utility version: 25.21.0722 @ 2020-06-28 Printing phone history Patch Certificate 29/06/2020 0:14:16 Patch Certificate 29/06/2020 0:10:05 Patch Certificate 29/06/2020 0:08:28 Patch Certificate 28/06/2020 23:34:07 Patch Certificate 28/06/2020 23:32:34 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A515F Sales Code: ZTO Country Code: Brazil Timezone: America/Santiago Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Sat Mar 14 03:51:30 KST 2020 PDA Version: A515FXXU3ATC5 [march 2020, rev5] Phone Version: A515FXXU3ATC2 [march 2020, rev2] CSC Version: A515FOWO3ATC1 [march 2020, rev1] Product Code: ZTO HIDSw Version: A515FXXU3ATC5/A515FOWO3ATC1/A515FXXU3ATC2/A515FXXU3ATC5 Board Platform: UNIVERSAL9611 Modem Platform: SHANNON337 Serial Number: RXXXX Imei: 35713XXXXXXXX Unique Number: CE11193BA9A109533F7E Connections: AT,MTP Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 20.5:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [06.28.20 20:18:11] WorkID: 99214764 Last edited by WorldCellularSe; 06-29-2020 at 02:06. |
06-29-2020, 14:36 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,658 | reply Hi, it is worth to install complete stock firmware on the device and repeat the processes again in a correct sequence. 1. reflash 2. imei repair 3. root -> in each case it is worth to check the root successfully done. 4. patch cert Best regards Nicole Quote:
06-29-2020, 17:02 | #3 (permalink) | |
Member: 2837277 Status: Offline Thanks Meter: 39 | Quote:
Hello nicole, a pleasure to greet you, I have already tried that method, I even tried 3 times and the imei NG continues, I changed the MAGISK version to see if that was the problem, do I attach the working ids? | |
08-18-2020, 09:35 | #8 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Shop # 34 HafeeZ Center,
Member: 2161392 Status: Offline Sonork: 100.1677520:hafiz Thanks Meter: 50 | Chimera Mobile Phone Utility version: 25.69.1404 @ 2020-08-18 Printing phone history Patch Certificate 8/18/2020 6:48 AM Patch Certificate 8/18/2020 6:43 AM Patch Certificate 8/18/2020 6:39 AM Patch Certificate 8/17/2020 12:09 PM Patch Certificate 8/17/2020 10:55 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A515F Sales Code: KSA Country Code: VIETNAM Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Mar 9 15:15:30 KST 2020 PDA Version: A515FXXU3ATC3 [march 2020, rev3] Phone Version: A515FXXU3ATC1 [march 2020, rev1] CSC Version: A515FOLM3ATC3 [march 2020, rev3] Product Code: XXV HIDSw Version: A515FXXU3ATC3/A515FOLM3ATC3/A515FXXU3ATC1/A515FXXU3ATC3 Board Platform: UNIVERSAL9611 Modem Platform: SHANNON337 Serial Number: RZ8MC0P1ZDZ Imei: 356000000000000 Unique Number: CE11193B145EE19C3F7E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [08.18.20 13:02:10] WorkID: 104276503 root link download https://www.4shared.com/file/cmWaDrR8ea/RootedBoot.html |
10-16-2020, 13:40 | #9 (permalink) | |
Junior Member Join Date: Dec 2016 Location: Earth
Member: 2664234 Status: Offline Thanks Meter: 31 | Quote:
chimera needs root for repairing. Last edited by andzytis; 10-16-2020 at 13:47. | |
10-21-2020, 12:32 | #11 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Chimera Mobile Phone Utility version: 26.37.0928 @ 2020-10-21 Printing phone history Patch Certificate 21/10/2020 11:15 Patch Certificate 21/10/2020 11:13 Patch Certificate 20/10/2020 16:03 Patch Certificate 20/10/2020 13:33 Patch Certificate 20/10/2020 13:32 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A515F Carrier ID: ZTO Sales Code: XSG Country Code: UAE Timezone: America/Sao_Paulo Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Apr 21 23:03:39 KST 2020 PDA Version: A515FXXU3BTD4 [april 2020, rev4] Phone Version: A515FXXU3ATC1 [march 2020, rev1] CSC Version: A515FOJM3BTD4 [april 2020, rev4] Board Platform: UNIVERSAL9611 Modem Platform: SHANNON337 Serial Number: RX8N904NJ4V Imei: 355707113061742 Imei2: 355708113061757 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. Failed to write data. Checking boot image. Be patient! Do NOT disconnect the phone! Patchcert will not work. Please reinstall the firmware or use another root solution and try again. Unable to patch certificate. Finished at local time: [10.21.20 08:19:59] WorkID: 112140809 |
10-21-2020, 13:51 | #12 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,658 | reply Hi, Please reflash the device with the following firmware and then do the rooting again. After that , please run the Patch cert A515FXXU3BTH4 [august 2020, rev4] Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
