GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 02-25-2019, 08:42   #1 (permalink)
Member: 2483507
Thanks Meter: 81
Anyone successfully patched this models J2Core,J4,J6 ??
Hi,
Anyone successfully patch certificate on this models? Any success report?
Samsung Galaxy J2 Core (SM-J260F, SM-J260G, SM-J260Y)
Samsung Galaxy J4 (SM-J400F, SM-J400G, SM-J400M)
Samsung Galaxy J6 (2018) (SM-J600F, SM-J600FN, SM-J600G, SM-J600GF, SM-J600GT, SM-J600L, SM-J600N)
BR.
The Following User Says Thank You to sany5491 For This Useful Post:
Old 02-25-2019, 14:28   #2 (permalink)
Member: 1768975
Sonork: 1615342:cikaaca
Thanks Meter: 45
anyone rooted easily ?
Old 02-25-2019, 15:31   #3 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 205
Originally Posted by sany5491 View Post
Hi,
BR.
i'm fighting with a j600fn from 1 week, rooted but patch not works
Old 02-25-2019, 15:33   #4 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 190
I think Chimera should work on the rooting aspect as well. That has been the biggest problem so far.
Old 02-25-2019, 15:53   #5 (permalink)
Member: 2896590
Thanks Meter: 22
Hi,
I'm new here and on this Market too. I'm discoussed with some other shop owners and they sent me some firmware version where the patch cert function was done.
It savedmy life in some cases. They finished successfully on some device the patch cert with them.
Here is a list, not for all. Enjoy it
Patch cert - Model: SM-J260G
PDA Version: J260GDDU2ARK1
Phone Version: J260GDDU2ARJ7
CSC Version: J260GOLE2ARK1
Patch cert - Model: SM-J400F
PDA Version: J400FXXU2ARG7
Phone Version: J400FXXU2ARG7
CSC Version: J400FOJM2ARG7
PDA Version: J400FXXU2ARK2
Phone Version: J400FXXU2ARI2
CSC Version: J400FOJM2ARK1
Patch cert- Model: SM-J400M
PDA Version: FA80_J400MUBU2ARF2
Patch cert - Model: SM-J600F
PDA Version: J600FXXU3ARK1
Phone Version: J600FXXU3ARK1
CSC Version: J600FOJM3ARK1
Patch cert - Model: SM-J600G
PDA Version: J600GUBS3ASA5
Phone Version: J600GDXU3ARH1
CSC Version: J600GOWA3ARJ2
When it was usefull please do not forget say Thank you
The Following 7 Users Say Thank You to the_newguy For This Useful Post:
Old 02-25-2019, 15:58   #6 (permalink)
Member: 1768975
Thanks Meter: 45
how to root when device rmm prenormal
Old 02-25-2019, 16:02   #7 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 16,670
reply
Hi,
first of all you need remove the rmm prenormal status.
unfortunately there isn't any perfect solution for this issue, this is why we do not have procedure for RMM prenormal "remove" or "bypass".
However you can try some of the google results, because sometimes you can find working one.
https://www.google.com/search?hl=&si...prenormal+skip
Old 02-25-2019, 22:00   #8 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 328
Originally Posted by the_newguy View Post
Hi,
Thanks man
But in gsm world no any one did success report for this models of course after rooted with magisk root.
Did you tested this firmwares and after patch imei status OK?
If done please share video one of models without network problem after patch
Old 02-26-2019, 12:32   #9 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 205
Hi,
thank's for your post mate, but i assure you i tried this version J600FXXU3ARK1, rooted with magisk and dont works!
br
ss
Old 02-26-2019, 13:09   #10 (permalink)
Member: 2483507
Thanks Meter: 81
br
ss
sometimes magisk root problem while patch, try root by SuperSu and patch again. and oviously post results here.
Old 02-26-2019, 16:29   #11 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 205
tried with supersu but phone goes in bootloop! tried also with other tool root and no luck. i wish in chimera root method because with others model, like g950f, a520f ..... patch works very well
Old 03-01-2019, 11:13   #12 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 137
Any news? I try on two set, always got NG. So maybe chimera solutions not working?
Old 03-01-2019, 12:40   #13 (permalink)
Member: 738323
Sonork: 1618038
Thanks Meter: 68
I think it was just smoke this update for j4 j6 and other models,always result is ng
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-J400M
Sales Code: COO
Country Code: Colombia
Timezone: America/Bogota
Android Version: 8.0.0 [R16NW] [SDK 26]
Build Date: Mon Jul 16 23:39:37 KST 2018
PDA Version: J400MUBU2ARG7 [july 2018, rev7]
Phone Version: J400MUBU2ARF2 [june 2018, rev2]
CSC Version: J400MOWO2ARF7 [june 2018, rev7]
Product Code: COO
HIDSw Version: J400MUBU2ARG7/J400MOWO2ARF7
Board Platform: EXYNOS5
Modem Platform: SHANNON305
Serial Number: R28K92QZ8RH
Imei: 3574740xxxxxx
Unique Number: CQX0022A4E46F95
Connections: AT,MTP
Battery Status: 3.88V (54%)
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2018-07-01
Data Encryption State: unencrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
Checking boot image. Be patient! Do NOT disconnect the phone!
Selinux could cause problems.
If the patchcert does not work, try another root solution.
Reading data...
Checking modem version.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data. Be patient! Do NOT disconnect the phone!
Patching certificate...
Communicating with the server. Be patient! Do NOT disconnect the phone!
Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Successfully finished.
Finished at local time: [03.01.19 06:42:50]
WorkID: 53738443
Old 03-02-2019, 00:46   #14 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 140
Selinux different in some newest models. Can try:
adb shell su -c mount -o remount,rw /
adb shell su -c dd if=/sys/fs/selinux/sepolicy of=/sepolicy
Then without reboot, reattempt patch cert. This may or may not help.
Old 03-02-2019, 16:54   #15 (permalink)
Member: 738323
Sonork: 1618038
Thanks Meter: 68
Chimera Mobile Phone Utility version: 20.39.0941 @ 2019-03-02
Printing phone history
Patch Certificate
02/03/2019
03:49:17
p.m.
Patch Certificate
02/03/2019
03:46:04
p.m.
Patch Certificate
02/03/2019
03:45:24
p.m.
Patch Certificate
02/03/2019
03:42:15
p.m.
Repair IMEI
02/03/2019
03:39:00
p.m.
Model: SM-J400M
Sales Code: COO
Phone Version: J400MUBU2ARG1 [july 2018, rev1]
Product Code: COO
HIDSw Version: J400MUBU2ARG7/J400MOWO2ARF7/J400MUBU2ARG1/J400MUBU2ARG7
Serial Number: R28K90ffff
Imei: 35747409fffffff
Unique Number: CQX00963EE40795
Connections: AT,MTP
Battery Status: 3.86V (48%)
Network Type: GSM
SIM Status: READY,ABSENT
Knox Version: v30
Warranty Bit: 0
Preparing...
Restarting phone.
Previous patchcert successfully removed.
Checking modem.
Checking root.
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Reading data...
Restarting phone.
Succeeded.
Finished at local time: [03.02.19 11:00:28]
WorkID: 53840976
cert ng
Page generated in 0.39004 seconds with 7 queries
