04-29-2021, 15:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Italy Age: 41
Member: 129817 Status: Offline Thanks Meter: 19 | art-l29 failed to remove huawei id Exit Factory Mode 29/04/2021 14:04 Load Factory Fastboot 29/04/2021 14:02 Huawei Id & Frp Remove 29/04/2021 13:28 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Rebooting phone to USB update mode Rebooting phone to USB update mode Failed to switch to factory mode with the given method. Rebooting into USB update mode again. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished We counld't identify the device, please select manually, if present! Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Operation failed Finished at local time: [04.29.21 16:09:29] WorkID: 132823271 |
04-29-2021, 15:17 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,751 | reply Dear User, We checked the mentioned work, as it looks like there is a communication issue. Please try to reinstall the chimera tool drivers - specially the Huawei driver - then use another usb port and cable for the process. Make sure that you do a virus check on the computer before the mentioned steps. Best regards Sab Chimera team Quote:
