Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 06-28-2021, 19:44   #871 (permalink)
Member: 2963360
Originally Posted by Chimera Tool View Post
Dear Mahmudhassan,
Thank you for the message, we will try to add the requested update to the tool.
Best regards
Sab
Chimera Team
Team, we don't need this update! We need an update for the samsung certificates patch of the latest security! We have been waiting for a very long time, and you ignore our requests and release minor updates for other phones.
Old 06-29-2021, 10:15   #872 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,706
reply
Dear KamekoMaster,
Based on the server logs, majority of the users are using our new "minor" updates. So i would respectfully disagree with the "we don't need this update" sentence.
We do know the needs of our users. We recognized the many requests that we received for the Samsung module and we are genuinely working on it but we have to understand collectively that nowadays developing a method for the Samsung Binary versions / security patches are not easy. Especially not fast.
As far as we see the market ,generally has no solution for the new methods. IF someone puts out a new method, it could be working for a week or two , then the Samsung fixes the exploit and the method goes out to the bin.
Which is not an ideal situation. So we would take our time, and try to develop a method which is safe and stable. We do understand that this is a frustrating thing as an user, and we are sorry for keep saying this over and over again, but this is the reality. We will update the Samsung Module, that is 100% sure.
We are thankful for your message, as we can clarify problems for you guys.
IF you have any issues, questions, let us know it and we will try to answer in the best possible way.
Best regards
Sab
Chimera Team
Old 06-29-2021, 11:38   #873 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 117
Originally Posted by iki View Post
work id : 139900840
when it comes to 48% uploading data it hangs and stops with error, failed to read try to hard reset phone
WorkID: 140135288
Chimera Mobile Phone Utility version: 28.89.0801 @ 2021-06-29
Printing phone history
Get Info
6/27/2021
8:31
AM
Huawei Id & Frp Remove
6/27/2021
8:06
AM
6/24/2021
4:12
PM
6/24/2021
4:05
PM
6/24/2021
2:37
AM
Removing Huawei account
Rebooting phone to factory mode
Changing to factory mode
Rebooting phone to USB update mode
Downloading ERECOVERY files
Flashing ERECOVERY files
Please put the phone into factory mode via Test Point!
Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone.
If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device.
If you fail to reconnect the battery, your phone might be still locked after the procedure finished
Uploading data
Failed to read, try to hard-reset the phone
Finished at local time: [06.29.21 12:24:45]
WorkID: 140135288
Old 06-29-2021, 13:19   #874 (permalink)
Member: 1787203
reply
Dear Iki,
Please reinstall the Chimera tool - Huawei - driver. Then restart the computer. For the connection please use another USB cable ( if you can use the original Huawei cable ) and another USB port.
Also please run a HARD RESET on the device. Which means press and hold the POWER button while the device is connected to the pc / tool. Hold the button for about 15-20 sec.
Best regards
Sab
Chimera Team
WorkID: 140135288
Get Info
6/27/2021
8:31
AM
6/27/2021
8:06
AM
6/24/2021
4:12
PM
6/24/2021
4:05
PM
6/24/2021
2:37
AM
Uploading data
WorkID: 140135288
Old 06-29-2021, 13:55   #875 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 117
Dear Iki,
Best regards
Sab
Chimera Team
i did hard reset , using always original cable , reinstaled chimeratool also completly and always stoping at 48% ...strange thing is that i can enter factory fastboot as single operation but i can not remove id and frp in that mode
Old 07-01-2021, 13:17   #876 (permalink)
Member: 706781
Thanks Meter: 15
pls add imei repair for new huawei mtk devices
The Following User Says Thank You to charmingfair For This Useful Post:
Old 07-01-2021, 13:27   #877 (permalink)
Member: 1787203
reply
Dear charmingfair,
Thank you for your request we will forward your suggestion to the developers.
Best regards
Sab
Chimera Team
Old 07-01-2021, 15:36   #878 (permalink)
Member: 1787203
01/07/2021 #26 BiWeekly Update - Fixes and Improvements
Samsung: added read NCK/MCK for Exynos models
  • Galaxy A51 (SM-A515x)
  • Galaxy A21S (SM-A217x)
  • Galaxy S21 5G (SM-G991B/N)
  • Galaxy S21+ 5G (SM-G996B/N)
  • Galaxy S21 Ultra 5G (SM-G998B/N)
  • And many more...
New features and improvements:
  • LG: added new Network Factory Reset mechanism for LG MTK phones in normal mode
  • MTK: improved phone model detection in bootrom mode
  • MTK: improved Repair IMEI procedure to support more Vivo models
  • Core: introducing ASUS modul (to facilitate mode switch into EDL mode)
Bugfixes:
  • MTK: fixed a bug when manually selecting preloader files
  • Core: fixed a local database related bug
Software version: 28.77.1315
Release date: 1 July 2021
Old 07-01-2021, 15:36   #879 (permalink)
Member: 1787203
  • And many more...
Bugfixes:
Software version: 28.91.1211
Old 07-01-2021, 16:46   #880 (permalink)
Member: 742615
Thanks Meter: 58
imei repair option is removed???
Old 07-01-2021, 16:47   #881 (permalink)
Member: 2171001
Thanks Meter: 196
  • And many more...
Bugfixes:
hi....repair imei option dissappeare? almost sumsung exyns cpu
Old 07-01-2021, 16:53   #882 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Yes Same With Me
Instead Of IMEI Repair Demo Remove Option Showing Now
The Following User Says Thank You to shoaibrao For This Useful Post:
Old 07-01-2021, 16:56   #883 (permalink)
Member: 1787203
Dear Users of the Chimera Tool,
Yes we noticed the issue with the IMEI REPAIR service. Currently we are working on the case, hopefully soon we can have another update which one will fix the problems. We are sorry for the inconveniences.
Best regards
Sab
Chimera Team
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 07-01-2021, 17:09   #884 (permalink)
Member: 2796172
Thanks Meter: 42
@Chimera Tool
do you have any updates about when is possibility to bring back to life network factory reset?
Old 07-01-2021, 17:11   #885 (permalink)
Member: 216844
Thanks Meter: 30
S21+ sm-G996U and S21 ultra sm-G998U Verizon USA for unlock
Page generated in 0.14302 seconds with 9 queries
