04-12-2022, 00:45 | #1 (permalink) |
Junior Member Join Date: Sep 2009 Location: Peru
Member: 1128985 Status: Offline Thanks Meter: 17 | SAMSUNG A22 5G A226BR U3 IMEI and Patch DONE Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A226BR Carrier ID: PEO Sales Code: PET Country Code: PERU Timezone: America/Lima Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Feb 11 12:31:45 KST 2022 PDA Version: A226BRUBU3AVB1 [february 2022, rev1] Phone Version: A226BRUBU3AVB1 [february 2022, rev1] CSC Version: A226BROWO3AVB4 [february 2022, rev4] Product Code: PET HIDSw Version: A226BRUBU3AVB1/A226BROWO3AVB4/A226BRUBU3AVB1/A226BRUBU3AVB1 Board Platform: MT6833 Modem Platform: MT6853 Serial Number: R9AT208TVJP Imei: 3580553XXXXXXXX Connections: AT,MTP Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v00 Warranty Bit: 1 Security Patch: 2022-02-01 Em Did: 3D582BFB937B Repair imei... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Operation in progress. Be patient! Do NOT disconnect the phone! Repaired imei: 3560071XXXXXXXX Modifications might be lost with a factory reset! Successfully finished. PATCH Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A226BR Carrier ID: PEO Sales Code: PET Country Code: PERU Timezone: America/Lima Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Feb 11 12:31:45 KST 2022 PDA Version: A226BRUBU3AVB1 [february 2022, rev1] Phone Version: A226BRUBU3AVB1 [february 2022, rev1] CSC Version: A226BROWO3AVB4 [february 2022, rev4] Product Code: PET HIDSw Version: A226BRUBU3AVB1/A226BROWO3AVB4/A226BRUBU3AVB1/A226BRUBU3AVB1 Board Platform: MT6833 Modem Platform: MT6853 Serial Number: R9AT208TVJP Imei: 3560071XXXXXXXX Connections: AT,MTP Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v00 Warranty Bit: 1 Security Patch: 2022-02-01 Em Did: 3D582BFB937B Preparing... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. |
The Following 2 Users Say Thank You to eltorri For This Useful Post: |
04-12-2022, 10:18 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,741 | reply Dear Eltorri, Thank you for the detailed logs. Great stuff from you. Best regards Sab Chimera team Quote:
01-10-2023, 23:59 | #5 (permalink) |
Freak Poster Join Date: Sep 2006 Location: medellin colombia
Member: 350892 Status: Offline Thanks Meter: 40 | A226br dead with chimera Chimera Mobile Phone Utility version: 34.45.1032 @ 2023-01-10 Printing phone history SW Change 10/01/2023 9:59 p. m. Firmware update started Processing firmware... Preparing. Be patient! Do NOT disconnect the phone! Waiting for download mode. Connecting. Valid PIT file can be found in the firmware: A22X_EUR_OPEN.pit Use the Enable PIT Write option if you want to use it. Reading PIT from phone. Flashing boot.img Flashing recovery.img Flashing super.img Flashing userdata.img Flashing dpm-verified.img Flashing vbmeta.img Flashing dtbo.img Flashing gz-verified.img Flashing spmfw-verified.img Flashing scp-verified.img Flashing sspm-verified.img Flashing tee-verified.img Flashing tzar.img Flashing mcupm-verified.img Flashing pi_img-verified.img Flashing vbmeta_system.img Flashing preloader.img Flashing lk-verified.img Flashing param.bin Flashing up_param.bin Flashing efuse.img Flashing vbmeta.img Flashing md1img.img Flashing cache.img Flashing omr.img Flashing optics.img Flashing prism.img Restarting phone. Successfully finished. Finished at local time: [01.10.23 17:25:11] WorkID: 209140219 HELPME NO TESTPOIN to recognize, DEAD DEAD . THANKS IN ADVANCED |
01-11-2023, 00:05 | #6 (permalink) |
Member: 350892 Status: Offline Thanks Meter: 40 | A226br dead with chimera Chimera Mobile Phone Utility version: 34.45.1032 @ 2023-01-10 Autodetect features Change to bootrom mode preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected Failed to connect to the phone, please reboot the phone to bootrom mode so that we can try again! Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected preloader interface detected. Preloader interface disconnected The procedure has been canceled. Finished at local time: [01.10.23 17:27:31] WorkID: 209140984 it no longer recognizes it EVEN WITH TEST POINT |
01-11-2023, 06:14 | #7 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,741 | reply Dear juanguirre, We see 3 works with that device: 209139291 - SW Change , this one crashed. 209140219 - SW Change , this is successfully finished. After this work, the device is already Bricked? Just because after that I think you connected the phone in EDL mode to the tool, as we see this job: 209140984 If you connect the device via TestPoint to the tool, what do you get from the software? Best regards Sab Chimera team Quote:
