05-16-2021, 12:20 | #1 (permalink) |
Junior Member Join Date: Dec 2010 Location: Tunisie
Member: 1476214 Status: Offline Thanks Meter: 0 | help with bricked scc-u21 after flash with chimera I flashed scc-u21 through fastboot with chimera and it's stucked on edl mode with red led Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Flashing partitions Flashing GPT . Fastboot flashPartiton command error. Flashing RPM . Flashing TZ . Flashing SBL1 . Flashing MODEM . Flashing FSG . Flashing ABOOT . Flashing RECOVERY . Flashing ERECOVERY . Flashing SYSTEM . Flashing USERDATA . Flashing CACHE . Flashing CUST . Flashing PERSIST . Flashing BOOT . Rebooting the device... Writing vendor-country pair Searching for manufacture port... The procedure has been canceled. Finished at local time: [05.15.21 17:00:50] WorkID: 134314650 |
05-17-2021, 10:55 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,027 | reply Dear punicher1981, Thank you for the posted log. We would recommend to flash another firmware version. Put the device into Fastboot mode and then use the Update Firmware again, but with another firmware. You can download firmware's from various sources like: https://support.halabtech.com https://firmware.gem-flash.com Home Page | Romthai Center https://androidhost.ru https://androidfilehost.com https://gsmhostingfiles.com http://bbs.lophone.cn Best regards Sab Chimera Team Quote:
05-18-2021, 16:35 | #3 (permalink) |
Member: 1476214 Status: Offline Thanks Meter: 0 | thanks for the reply but the phone Don't boot anymore only edl mode and I return it to customer after multi failed flash( gpt partition failed error) on edl mode |
05-19-2021, 09:20 | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,027 | reply Thank you for the feedback. I think we still could work with it. If you face this issue again, please hold the device a bit and we will try to find a solution for it. |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
