09-07-2016, 22:14 | #1231 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | LG G Flex 2 H955 FRP removed !! Quote:
09-08-2016, 07:27 | #1232 (permalink) |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | J500F unlock done Code: [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J500F Sales Code: AUT Country Code: Switzerland Timezone: Asia/Colombo Android Version: 5.1.1 [LMY48B] Build Date: Tue Oct 6 14:22:11 KST 2015 PDA Version: J500FXWU1AOJ2 [october 2015, rev2] Phone Version: J500FXWU1AOJ2 [october 2015, rev2] CSC Version: J500FAUT1AOJ1 [october 2015, rev1] Product Code: SM2J500FZWDAUT HIDSw Version: J500FXWU1AOJ2/J500FAUT1AOJ1/J500FXWU1AOJ2/J500FXWU1AOJ2 Board Platform: MSM8916 Modem Platform: MSM8916 Serial Number: RV8H21z Imei: 358001x Unique Number: C8G0104CA60FF23 Connections: AT,MTP Battery Status: 3.94V (49%) Network Type: GSM SIM Status: NETWORK_LOCKED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM183) Unlocked. Finished successfully. Finished at local time: [09.08.16 11:46:37] WorkID: 13324752 |
09-09-2016, 06:33 | #1233 (permalink) | |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | Quote:
write this modem and repeat unlock ... G930F modem UNLOCK.tar | |
09-09-2016, 16:19 | #1234 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Barnsley UK Age: 56
Member: 7910 Status: Offline Thanks Meter: 57 | g930f frp reset done Waiting for drivers to be installed. Chimera Mobile Phone Utility version: 11.35.1006 @ 2016-09-09 Printing phone history Reset FRP Lock 07/09/2016 09:10:14 Reset FRP Lock 07/09/2016 08:18:34 Reset FRP Lock 02/09/2016 14:02:35 SW Change 02/09/2016 13:07:48 Reset FRP Lock 02/09/2016 12:17:30 [Reset FRP lock started] Processing... Processing. Be patient! Do NOT disconnect the phone! Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image based root method... Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Reseting FRP lock... Done. Flashing stock boot image... Downloading stock boot image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Flashing stock boot image. Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Succeeded. Finished successfully. Finished at local time: [09.09.16 16:14:42] WorkID: 13361538 |
09-10-2016, 05:49 | #1235 (permalink) |
Freak Poster Join Date: May 2011 Location: ettumanoor
Member: 1587303 Status: Offline Thanks Meter: 42 | Lg p870 unlock done FIRST ROOT NO HIDDEN MENU CHECK ATTACHMENTS Chimera Mobile Phone Utility version: 11.35.1006 @ 2016-09-10 Printing phone history Direct Unlock 9/10/2016 4:39:20 AM Direct Unlock 9/10/2016 4:18:38 AM IMEI Repair 9/10/2016 4:18:00 AM Direct Unlock 9/9/2016 2:02:54 PM Direct Unlock 9/9/2016 2:02:42 PM [Direct Unlock started] Creating EFS backup... Waiting for serial port to appear... Trying to boot the phone into download mode... Waiting for download mode serial port to appear...  EFS Backup failed. Proceed at your own risk. Press 'OK' to continue, and 'Cancel' to abort process! Checking ports For unlock, a DIAG mode serial must be present. Searching for ports Waiting for diag serial port to appear...  Please make sure 'Port Check Test' is enabled on the phone! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*870# *#546368#*870# In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. Waiting for ADB connection.Be patient! Do NOT disconnect the phone! Unlocking Phone IMEI is correct.: 013237001 Unlocked. Restarting phone... Finished successfully. Finished at local time: [09.10.16 10:19:23] WorkID: 13375563 |
09-10-2016, 09:23 | #1236 (permalink) |
Freak Poster Join Date: Sep 2007 Location: VN
Member: 579694 Status: Offline Thanks Meter: 75 | Chimera Mobile Phone Utility version: 11.35.1006 @ 2016-09-10 Printing phone history Read / Write certificate 9/10/2016 8:19:05 AM Read / Write certificate 9/10/2016 8:17:56 AM Read / Write certificate 9/10/2016 8:17:27 AM [Repair DRK] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G925F Sales Code: XXV Country Code: VIETNAM Timezone: Asia/Saigon Android Version: 6.0.1 [MMB29K] Build Date: Wed Jul 27 19:54:05 KST 2016 PDA Version: G925FXXU4DPH1 [august 2016, rev1] Phone Version: G925FXXU4DPG4 [july 2016, rev4] CSC Version: G925FOLB4DPH1 [august 2016, rev1] Product Code: XXXXXXXXXXXXXX HIDSw Version: G925FXXU4DPH1/G925FOLB4DPH1/G925FXXU4DPG4/G925FXXU4DPH1 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: 00000000000 Imei: 350000000000006 Unique Number: 03157DF3E2EDBF30 Connections: AT,MTP Battery Status: 3.74V (33%) Network Type: GSM SIM Status: ABSENT Knox Version: 0 Warranty Bit: 1 Security Patch: 2016-08-01 Repairing DRK... Damaged DRK repaired. Finished successfully. Finished at local time: [09.10.16 15:21:56] WorkID: 13376797 |
09-13-2016, 06:49 | #1237 (permalink) |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | J120G unlock done (no root) Code: [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J120G Sales Code: XME Country Code: MALAYSIA Timezone: Asia/Colombo Android Version: 5.1.1 [LMY47X] Build Date: Wed Jun 8 23:56:36 KST 2016 PDA Version: J120GDXU1APF2 [june 2016, rev2] Phone Version: J120GDXU1APF3 [june 2016, rev3] CSC Version: J120GOLB1APF3 [june 2016, rev3] Product Code: SM-J120GZKDXME HIDSw Version: J120GDXU1APF2/J120GOLB1APF3/J120GDXU1APF3/J120GDXU1APF2 Board Platform: EXYNOS3 Modem Platform: SHANNON308 Serial Number: R58xxxx Imei: 357xxxx Unique Number: CFN00F373E65043 Connections: AT,MTP Battery Status: 4.31V (94%) Network Type: GSM SIM Status: NETWORK_LOCKED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-06-01 Unlocking... Please unlock screen if closed. Trying on SAMSUNG Mobile USB Modem (COM24) Processing. Be patient! Do NOT disconnect the phone! Restarting. Unlocked. Finished successfully. Finished at local time: [09.13.16 11:18:14] WorkID: 13429803 |
09-13-2016, 08:59 | #1238 (permalink) |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | j110h unlock done Code: Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J110H Sales Code: KSA Country Code: KSA Timezone: Asia/Colombo Android Version: 4.4.4 [KTU84P] Build Date: Fri Apr 22 15:37:00 KST 2016 PDA Version: J110HXXU0APD3 [april 2016, rev3] Phone Version: J110HXXU0APD3 [april 2016, rev3] CSC Version: J110HOJV0APD3 [april 2016, rev3] Product Code: SM-J110HZWDKSA HIDSw Version: J110HXXU0APD3/J110HOJV0APD3/J110HXXU0APD3/J110HXXU0APD3 Board Platform: SC8830 Modem Platform: SC7727S Serial Number: RV1H60xx Imei: 3597xx Unique Number: C4G0142F2442E43 Connections: AT,MTP Battery Status: 3.89V (49%) Network Type: GSM SIM Status: NETWORK_LOCKED SIM2 Status: ABSENT Knox Version: v00 Security Patch: 2016-05-01 Unlocking... Trying on SAMSUNG Mobile USB Modem (COM32) If needed use unlock code '11111111'. Succeeded. Finished successfully. Finished at local time: [09.13.16 11:52:12] WorkID: 13429982 |
09-14-2016, 07:50 | #1239 (permalink) |
Member: 579694 Status: Offline Thanks Meter: 75 | Chimera Mobile Phone Utility version: 11.35.1006 @ 2016-09-14 Printing phone history Unlock 9/14/2016 4:29:14 AM [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SC-04E Sales Code: DCM Country Code: JP Android Version: 4.4.2 [KOT49H] Build Date: Tue Jun 24 18:27:13 KST 2014 PDA Version: SC04EOMUFNF6 [june 2014, rev6] Phone Version: SC04EOMUFNF6 [june 2014, rev6] CSC Version: SC04EDCMFNF6 [june 2014, rev6] Board Platform: MSM8960 Modem Platform: MDM9215M Serial Number: R31D7012Z9N Imei: 356778059225400 Battery Status: 3.89V (64%) Network Type: GSM SIM Status: ABSENT Knox Version: v00 Warranty Bit: 1 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM73) Protocol is not supported. Trying on SAMSUNG Mobile USB Serial Port (COM74) Unlocked. Finished successfully. Finished at local time: [09.14.16 12:52:47] WorkID: 13454891 |
09-14-2016, 13:45 | #1240 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | SM-A300FU unlocked Chimera Mobile Phone Utility version: 11.35.1006 @ 2016-09-14 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A300FU Sales Code: XFV Country Code: South Africa Timezone: Africa/Kampala Android Version: 5.0.2 [LRX22G] Build Date: Fri May 6 21:35:02 KST 2016 PDA Version: A300FUXXS1BPE1 [may 2016, rev1] Phone Version: A300FUXXU1BPC1 [march 2016, rev1] CSC Version: A300FUVFG1BPC1 [march 2016, rev1] Product Code: SM-A300FZKUXFV HIDSw Version: A300FUXXS1BPE1/A300FUVFG1BPC1/A300FUXXU1BPC1/A300FUXXS1BPE1 Board Platform: MSM8916 Modem Platform: MSM8916 Serial Number: R58GA2N9XQP Imei: 354200073104802 Unique Number: CQ300D174D602A2 Connections: AT,MTP Battery Status: 3.84V (28%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-05-01 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM32) Unlocked. Finished successfully. Finished at local time: [09.14.16 15:31:25] WorkID: 13460169 |
09-14-2016, 13:48 | #1241 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | blackberry 9900 done Printing phone history Nuke 9/14/2016 12:43:19 PM blackberry-providepw 9/14/2016 12:43:06 PM [Unlock phone] Initializing Loader started Sign correct Initializing phone Unlocking The phone is unlocked now. Finished at local time: [09.14.16 15:46:27] WorkID: 13460491 |
09-14-2016, 13:59 | #1242 (permalink) |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | j500f unlock done Code: Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J500F Sales Code: KSA Country Code: KSA Timezone: Asia/Colombo Android Version: 5.1.1 [LMY48B] Build Date: Fri Jul 10 16:43:33 KST 2015 PDA Version: J500FXXU1AOG1 [july 2015, rev1] Phone Version: J500FXXU1AOG1 [july 2015, rev1] CSC Version: J500FOJV1AOG5 [july 2015, rev5] Product Code: SM-J500FZDDKSA HIDSw Version: J500FXXU1AOG1/J500FOJV1AOG5/J500FXXU1AOG1/J500FXXU1AOG1 Board Platform: MSM8916 Modem Platform: MSM8916 Serial Number: RVxxxxx Imei: 359707xxxx Unique Number: CQN00FD16D65F72 Connections: AT,MTP Battery Status: 4.25V (99%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM65) Unlocked. Finished successfully. Finished at local time: [09.14.16 17:38:45] WorkID: 13459768 |
09-14-2016, 15:00 | #1243 (permalink) |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | j111f read unlock code done Code: [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J111F Sales Code: XME Country Code: MALAYSIA Timezone: Asia/Colombo Android Version: 5.1.1 [LMY47V] Build Date: Fri May 20 20:16:54 KST 2016 PDA Version: J111FXXU0APE4 [may 2016, rev4] Phone Version: J111FXXU0APD2 [april 2016, rev2] CSC Version: J111FOLB0APD3 [april 2016, rev3] Product Code: SM-J111FZKDXME HIDSw Version: J111FXXU0APE4/J111FOLB0APD3/J111FXXU0APD2/J111FXXU0APE4 Board Platform: SC8830 Modem Platform: SC9830I Serial Number: R58xxxx Imei: 352942xxxx Unique Number: CFN00107ED66D63 Connections: AT,MTP Battery Status: 4.01V (78%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Warranty Bit: unknown Security Patch: 2016-05-01 Reading Codes... Trying on modem port SAMSUNG Mobile USB Modem (COM69) Freeze Code: 62680374 Network Lock: 08357594 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [09.14.16 18:58:30] WorkID: 13461529 |
09-15-2016, 18:13 | #1244 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | LG G Flex 2 H955 FRP removed successfully Chimera Mobile Phone Utility version: 11.35.1006 @ 2016-09-15 Printing phone history Remove FRP lock 2016-09-07 21:12:33 Remove FRP lock 2016-09-07 21:10:45 [FRP lock remove started] Removing FRP lock... Waiting for download mode serial port to appear... Removing FRP lock. FRP lock removed. Finished successfully. Finished at local time: [09.15.16 19:10:34] WorkID: 13492987 |
