01-06-2020, 07:25 | #3841 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | a105g repair log Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105G Sales Code: XID Country Code: INDONESIA Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 6 17:02:21 KST 2019 PDA Version: A105GDXS5ASK1 [november 2019, rev1] Phone Version: A105GDXS5ASK1 [november 2019, rev1] CSC Version: A105GOLE5ASK1 [november 2019, rev1] Product Code: XID HIDSw Version: A105GDXS5ASK1/A105GOLE5ASK1/A105GDXS5ASK1/A105GDXS5ASK1 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RR8M40L1QJP Imei: 357080101846575 Unique Number: CBJ00674A4FA046 Connections: AT,MTP Battery Status: 4.35V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Data Encryption State: encrypted Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 357080101846575 Repaired imei: 357297070073xx Current imei2: 357081101846573 Repaired imei2: 3572970700739xx Successfully finished. Finished at local time: [01.06.20 09:23:04] WorkID: 85123019 |
01-06-2020, 15:41 | #3842 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | A105g u5 repaİr done Chimera Mobile Phone Utility version: 23.32.0922 @ 2020-01-06 Printing phone history Get Info 6.01.2020 14:40:12 Repair IMEI 6.01.2020 06:21:57 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105G Sales Code: XID Country Code: INDONESIA Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 6 17:02:21 KST 2019 PDA Version: A105GDXS5ASK1 [november 2019, rev1] Phone Version: A105GDXS5ASK1 [november 2019, rev1] CSC Version: A105GOLE5ASK1 [november 2019, rev1] Product Code: XID HIDSw Version: A105GDXS5ASK1/A105GOLE5ASK1/A105GDXS5ASK1/A105GDXS5ASK1 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RR8M40L1QJP Imei: 357297070073953 Unique Number: CBJ00674A4FA046 Connections: AT,MTP Battery Status: 4.32V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 9.3:uni-android_su Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.06.20 17:41:03] WorkID: 85166055 |
The Following User Says Thank You to canliyayin For This Useful Post: |
01-07-2020, 17:53 | #3843 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Samsung N7100 write CERT done Code: Chimera Mobile Phone Utility version: 23.32.0922 @ 2020-01-07 Write certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-N7100 Sales Code: XSG Country Code: UAE Timezone: Asia/Dubai Android Version: 4.1.1 [JRO03C] [SDK 16] Build Date: Tue Oct 2 02:09:07 KST 2012 PDA Version: N7100XXALJ1 [october 2012, rev1] Phone Version: N7100XXALIH [september 2012, revH] CSC Version: N7100OJVALJ1 [october 2012, rev1] Product Code: XXXXXXXXXXXXXX HIDSw Version: N7100XXALJ1/N7100OJVALJ1/N7100XXALIH/N7100XXALJ1 Board Platform: EXYNOS4 Modem Platform: XMM6262 Serial Number: R31C80HWG1F Imei: 004999010640000 Connections: AT,MTP Battery Status: 3.86V (20%) Network Type: GSM SIM Status: ABSENT Data Encryption State: unencrypted Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Determining secure image format. done. Creating backup. done. Gathering cert information. done. Writing certificate. Cert written to: DataFiles/Samsung/Cert/GT-N7100/Backup/backup_2020_01_07_20_44_45_GT-N7100_004999010640000.cert done. Writing image. Current IMEI checksum error! Checking secure image. Writing secure image. done. Restarting phone. Successfully finished. Finished at local time: [01.07.20 20:44:59] WorkID: 85302674 |
The Following User Says Thank You to technomak For This Useful Post: |
01-08-2020, 16:14 | #3844 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | HTC Desire 10 pro FRP reset done Code: Chimera Mobile Phone Utility version: 23.51.1359 @ 2020-01-08 Printing phone history Remove FRP lock 2019-mm-01 10:04:24 FRP lock remove started Reading FRP information... Calculating FRP response... This may take a while. Be patient! Do NOT disconnect the phone! Writing FRP response... Waiting for download mode Phone detected FRP removed successfully. Rebooting the device... You're running the FRP procedure on unidentified phone, it is possible that the procedure will fail. Successfully finished Finished at local time: [01.08.20 19:12:28] WorkID: 85411998 |
01-13-2020, 13:02 | #3845 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | HTC One M9 TMB unlock done Code: Chimera Mobile Phone Utility version: 23.53.1421 @ 2020-01-13 Printing phone history Direct Unlock 2020-mm-13 11:36:28 Direct unlock started Downloading recovery image from server. Please hold on, it can take a while. Recovery image has been downloaded. Switching to Fastboot mode Phone detected Checking Bootloader state... Phone detected Using new method Rebooting in Bootloader mode Phone detected Bootloader is locked Rebooting in download mode Phone detected Bootloader unlock is required, asking server for access Gathering Bootloader information Waiting for Bootloader unlock to finish Fastboot detached. Phone detected Installing recovery image Installing was successful 1.) Please select Reboot to Bootloader option from Download mode menu 2.) Select Boot to Recovery mode option from the Bootloader menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Waiting for the phone... Calculating simlock Preparing the phone for the procedure Rebooting in recovery mode Cleaning up Information Your phone may asks for decryption password after it boots. Please type a single zero digit, then press the enter button. After that the phone will ask you for Factory Reset. Push Reset button, then phone boots into TWRP recovery. It may ask also for decryption password, but cancel it. It's IMPORTANT to push the Keep Read Only button (if it exists) on TWRP landing screen. Please go to the Wipe Menu in the TWRP recovery and pull the sliding bar to reset. After that you can boot into system mode and use the phone as usual. All in all: please factory reset your phone. Successfully finished Finished at local time: [01.13.20 15:47:10] WorkID: 85912953 |
01-14-2020, 15:42 | #3846 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | SM-A520F Patch certificate Successfully finished. Chimera Mobile Phone Utility version: 23.53.1421 @ 2020-01-14 Printing phone history Repair IMEI 1/14/2020 11:49:23 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: XXV Country Code: VIETNAM Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Jul 20 16:53:23 KST 2018 PDA Version: A520FXXU5CRGB [july 2018, revB] Phone Version: A520FXXU5CRF8 [june 2018, rev8] CSC Version: A520FOLB5CRF8 [june 2018, rev8] Product Code: XXV HIDSw Version: A520FXXU5CRGB/A520FOLB5CRF8/A520FXXU5CRF8/A520FXXU5CRGB Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58J8058LEM Imei: 35 Unique Number: CBJ000A57EEB664 Connections: AT,MTP Battery Status: 4.10V (79%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-07-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.14.20 14:09:30] |
01-14-2020, 15:43 | #3847 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.51.1823 @ 2020-01-09 Printing phone history Repair IMEI 1/9/2020 7:29:20 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Aug 23 14:53:57 KST 2019 PDA Version: A307FNXXU1ASHG [august 2019, revG] Phone Version: A307FNXXU1ASHD [august 2019, revD] CSC Version: A307FNOJM1ASI2 [september 2019, rev2] Product Code: XFA HIDSw Version: A307FNXXU1ASHG/A307FNOJM1ASI2/A307FNXXU1ASHD/A307FNXXU1ASHG Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8MA0ZT72A Imei: 35 Unique Number: CDU0038D35FDF96 Connections: AT,MTP Battery Status: 3.80V (30%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-08-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.2:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.09.20 10:48:33] |
01-15-2020, 23:36 | #3848 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | G9650 Read Codes Chimera Mobile Phone Utility version: 23.53.1421 @ 2020-01-15 Printing phone history SW Change 15/01/2020 17:41:26 Read codes started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G9650 Sales Code: ANC Country Code: Uruguay Timezone: America/Argentina/Buenos_Aires Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Aug 21 18:05:16 KST 2018 PDA Version: G9650ZHU3ARH4 [august 2018, rev4] Phone Version: G9650ZCU3ARH4 [august 2018, rev4] CSC Version: G9650OWE3ARI3 [september 2018, rev3] Product Code: ANC HIDSw Version: G9650ZHU3ARH4/G9650OWE3ARI3/G9650ZCU3ARH4/G9650ZHU3ARH4 Board Platform: SDM845 Modem Platform: SDM845 Serial Number: R28K30QRMFW Imei: 354263091046702 Unique Number: 988B5C35394451463830 Connections: AT,MTP Battery Status: 4.20V (97%) Network Type: CDMA SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-08-01 Data Encryption State: encrypted Downloading modem image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Decompressing modem image. Flashing modem image. Switching to download mode. Waiting for download mode. Connecting. Reading PIT from phone. Flashing dspso.bin Flashing modem.bin Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking diagnostic mode availability... Appropriate serial port is not available. 1. On the dial window, enter *#0808# 2. Select DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Diagnostic mode available on port SAMSUNG Mobile USB Serial Port (COM139) Reading data... Reading data is in progress. Method failed. Preparing... Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! The phone will restart in upload mode, this is normal operation, do not worry! Switching to upload mode. Be patient! Do NOT disconnect the phone! Waiting for upload interface... Waiting for upload interface. Be patient! Do NOT disconnect the phone! Upload interface: SAMSUNG Mobile USB Modem (COM23) Reading data... Reading data is in progress. Be patient! Do NOT disconnect the phone! Communicating with the server... The phone can be unplugged now. Waiting for server response... This operation costed 109 credits. Freeze Code: 30363974 Network Lock: 72964152 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 Successfully finished. Finished at local time: [01.15.20 19:30:25] WorkID: 86210815 |
01-16-2020, 10:39 | #3850 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,745 | reply Hi, re-flash your device with older than 01.11.2019 firmware and start relock again. Please do not forget the message what we send at the end of the process: turn off the auto update on your device. When it will be updated to the 01.11.2019 or newer security patch version the relock state will be restored to the original. Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
01-18-2020, 10:00 | #3851 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | J530F U5 imei/Baseband Null Successful Repair Chimera Mobile Phone Utility version: 23.59.1330 @ 2020-01-18 Printing phone history Patch Certificate 19-Dec-19 12:04:24 PM Patch Certificate 19-Dec-19 11:58:26 AM Rmm Unlock 19-Dec-19 10:28:52 AM Knoxguard Unlock 19-Dec-19 10:26:48 AM Get Info 19-Dec-19 10:25:03 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530F Sales Code: XEO Country Code: Poland Timezone: Asia/Karachi Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Thu May 30 15:30:35 KST 2019 PDA Version: J530FXXS5BSE3 [may 2019, rev3] Phone Version: J530FXXS5BSF2 [june 2019, rev2] CSC Version: J530FOXA5BSC2 [march 2019, rev2] Product Code: XEO HIDSw Version: J530FXXS5BSE3/J530FOXA5BSC2/J530FXXS5BSF2/J530FXXS5BSE3 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8J61M335R Imei: 357063083833324 Unique Number: CAJ00BE34EE9544 Connections: AT,MTP Battery Status: 4.22V (87%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unsupported Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.18.20 13:05:06] WorkID: 86432517 |
01-18-2020, 10:05 | #3852 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | Motorolla E5 Plus imei Repair Chimera Mobile Phone Utility version: 23.51.1823 @ 2020-01-09 Printing phone history Get Info 09-Jan-20 7:06:27 AM Repair IMEI Searching for manufacture port... Restarting the phone. Found preloader device: MediaTek PreLoader USB VCOM (Android) (COM28) Request sent Found factory port: MediaTek USB VCOM (Android) (COM139) Connected to the phone Writing new IMEI(s) Initializing... IMEI write failed Trying alternative solution... Searching for manufacture port... ADB interface detected. Serial port interface detected. Connected to the phone Reading data from the phone... Couldn't mount userdata. Probably it's encrypted. Original IMEI1: 355634080270413 Original IMEI2: fffffffffffffff Writing new IMEI(s) New IMEI1: 35360107016---- Rebooting phone to normal mode Disconnect the USB cable and power up the phone. As soon as the phone boots up, please reconnect the USB cable! ADB interface detected. Searching for manufacture port... Restarting the phone. Found preloader device: MediaTek PreLoader USB VCOM (Android) (COM138) Request sent Found factory port: MediaTek USB VCOM (Android) (COM139) Connected to the phone Writing backup... Restarting the phone... Finished at local time: [01.09.20 13:16:37] WorkID: 85488573 |
01-19-2020, 10:03 | #3853 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SM-A720F U8 patchcert Successfully finished. Chimera Mobile Phone Utility version: 23.59.1330 @ 2020-01-19 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A720F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Jun 14 18:02:29 KST 2019 PDA Version: A720FXXU8CSF1 [june 2019, rev1] Phone Version: A720FXXU8CSF1 [june 2019, rev1] CSC Version: A720FOJV8CSF1 [june 2019, rev1] Product Code: XFA HIDSw Version: A720FXXU8CSF1/A720FOJV8CSF1/A720FXXU8CSF1/A720FXXU8CSF1 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R28J12M2V3D Imei: 350 Unique Number: CBJ109179B42CC3 Connections: AT,MTP Battery Status: 3.86V (33%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.19.20 10:31:01] |
01-22-2020, 07:58 | #3854 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Samsung J320fn unlock done Code: Chimera Mobile Phone Utility version: 23.59.1330 @ 2020-01-22 Read codes started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J320FN Sales Code: EVR Country Code: UK Timezone: Asia/Dubai Android Version: 5.1.1 [LMY47V] [SDK 22] Build Date: Wed Jan 3 16:45:54 KST 2018 PDA Version: J320FNXXU0ARA1 [january 2018, rev1] Phone Version: J320FNXXU0ASF1 [june 2019, rev1] CSC Version: J320FNEVR0ARA1 [january 2018, rev1] Product Code: SM-J320FZKNEVR HIDSw Version: J320FNXXU0ARA1/J320FNEVR0ARA1/J320FNXXU0ASF1/J320FNXXU0ARA1 Board Platform: SC8830 Modem Platform: SC9830I Serial Number: Imei: Unique Number: CQN000227EE92B3 Connections: AT,MTP Battery Status: 4.32V (93%) Network Type: GSM SIM Status: NETWORK_LOCKED Warranty Bit: unknown Security Patch: 2018-01-01 Data Encryption State: unencrypted Reading codes... Trying on modem port SAMSUNG Mobile USB Modem (COM133) Freeze Code: 57205791 Network Lock: 60528626 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Successfully finished. Finished at local time: [01.22.20 10:39:59] WorkID: 86814915 |
01-23-2020, 13:25 | #3855 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G950F U5 Successful Ptch CERT Chimera Mobile Phone Utility version: 23.65.1405 @ 2020-01-23 Printing phone history Repair IMEI 23-Jan-20 11:46:21 AM Patch Certificate 23-Jan-20 11:42:36 AM Patch Certificate 21-Jan-20 6:42:56 AM Get Info 21-Jan-20 6:42:23 AM Get Info 20-Jan-20 11:55:24 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: DBT Country Code: Germany Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Jun 3 19:51:23 KST 2019 PDA Version: G955FXXS5DSF1 [june 2019, rev1] Phone Version: G955FXXS5DSF1 [june 2019, rev1] CSC Version: G955FOXM5DSF1 [june 2019, rev1] Product Code: DBT HIDSw Version: G955FXXS5DSF1/G955FOXM5DSF1/G955FXXS5DSF1/G955FXXS5DSF1 Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J46NLGKN Imei: 357062092349041 Unique Number: CE031713EC7AE70103 Connections: AT,MTP Battery Status: 3.99V (73%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.23.20 16:49:57] WorkID: 86942876 |
