10-17-2022, 11:59 | #4366 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G930F No Signal After Patch All Done Printing phone history Patch Certificate 10/17/2022 10:41 AM Repair IMEI 10/17/2022 10:40 AM Reboot 10/17/2022 9:58 AM Repair IMEI 10/17/2022 9:57 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed May 26 17:15:16 KST 2021 PDA Version: G930FXXU8EUE1 [may 2021, rev1] Phone Version: G930FXXU8EUE1 [may 2021, rev1] CSC Version: G930FOXA8EUE1 [may 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58HA6A4Q1Y Imei: 3574XXXXXXXXXXX Battery Status: 4.18V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.17.22 15:42:53] WorkID: 199481722 |
10-17-2022, 13:24 | #4367 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G92F Network unlock one click Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-17 Printing phone history Get Info 10/17/2022 12:20 PM Network Factory Reset started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G925F Sales Code: HTS Country Code: Sweden Timezone: Asia/Karachi Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Tue Oct 4 19:08:04 KST 2016 PDA Version: G925FXXU4DPJ4 [october 2016, rev4] Phone Version: G925FXXU5BPK2 [november 2016, rev2] CSC Version: G925FHTS4DPJ1 [october 2016, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58G51MPF2D Imei: 359523064324039 Battery Status: 4.31V (18%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-10-01 Doing Network Factory Reset Please unlock screen if closed. Trying on SAMSUNG Mobile USB Modem (COM46) Processing. Be patient! Do NOT disconnect the phone! Restarting. Network configuration was set to factory default. Successfully finished. Finished at local time: [10.17.22 17:21:24] WorkID: 199495151 |
10-17-2022, 13:31 | #4368 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G960F Last Binary Patch success Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-17 Printing phone history Repair IMEI 10/17/2022 12:27 PM Reboot 10/17/2022 11:59 AM Repair IMEI 10/17/2022 11:56 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Carrier ID: H3G Sales Code: VD2 Country Code: Germany Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Oct 19 11:22:58 KST 2021 PDA Version: G960FXXSHFUJ2 [october 2021, rev2] Phone Version: G960FXXSHFUJ2 [october 2021, rev2] CSC Version: G960FOVFHFUJ1 [october 2021, rev1] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RF8M434ZP0V Imei: 3528xxxxxxxxxx Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 200B0FCCCD928011 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.17.22 17:30:43] WorkID: 199496475 |
10-17-2022, 16:34 | #4369 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,745 | reply Dear Qasir, Thank you for the report. Good work from you. Best regards Sab Chimera team Quote:
10-18-2022, 11:28 | #4370 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G955f one click frp Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-18 Printing phone history SW Change 3/29/2022 7:57 AM SW Change 3/29/2022 7:12 AM SW Change 8/12/2021 9:55 AM SW Change 2/3/2021 11:57 AM SW Change 1/24/2021 9:11 AM Reset FRP lock started Resetting FRP... Operation in progress. Be patient! Do NOT disconnect the phone! Model: SM-G955F SW Version: G955FXXSBDTJ1/G955FOXMBDTJ1/G955FXXSBDTJ1/G955FXXSBDTJ1 Serial: R58J56773RT IMEI: 3591XXXXXXXXXX Product Code: DBT Unique Number: CE041714C246D0E40D Resetting FRP... To complete resetting FRP, go to 'Settings/General management/Reset' then select 'Factory data reset' Restarting phone Successfully finished. Finished at local time: [10.18.22 15:24:08] WorkID: 199611012 |
10-18-2022, 11:39 | #4371 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,745 | reply Dear Qasir, Thank you for the feedback. Good job from you. Best regards Sab Chimera team Quote:
10-18-2022, 12:42 | #4372 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A520F Repair imei and Patch Cert Success Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-18 Printing phone history Repair IMEI 10/18/2022 11:39 AM Reboot 10/18/2022 10:26 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Nov 27 11:30:11 KST 2020 PDA Version: A520FXXUGCTKA [november 2020, revA] Phone Version: A520FXXUGCTKA [november 2020, revA] CSC Version: A520FOXAGCTL1 [december 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58K413XF1K Imei: 35431XXXXXXXXXXX Battery Status: 4.01V (69%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-12-01 Em Did: 07360F52C714 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.18.22 16:41:14] WorkID: 199621464 |
10-18-2022, 18:25 | #4373 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,745 | reply Dear Qasir, Thank you for the post. Good work from you. Best regards Sab Chimera team Quote:
10-19-2022, 13:11 | #4374 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G981B S205G FRP one Click Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-19 Reset FRP lock started Resetting FRP... Operation in progress. Be patient! Do NOT disconnect the phone! Model: SM-G981B SW Version: G981BXXSCDUJ5/G981BOXMCDUJ5/G981BXXSCDUJ5/G981BXXSCDUJ5 Serial: R3CN60D1E4J IMEI: 351826111353xxx Product Code: EVR Unique Number: CE032043853401591E7E Please 'Allow USB debugging' in the popup window Waiting for ADB device... Resetting FRP... To complete resetting FRP, go to 'Settings/General management/Reset' then select 'Factory data reset' Restarting phone Successfully finished. Finished at local time: [10.19.22 17:06:02] WorkID: 199756997 |
10-19-2022, 13:42 | #4375 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Sudan
Member: 1648903 Status: Offline Thanks Meter: 158 | Frp stk-l21m 10.0.0.193-chimera Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-19 Printing phone history Get Info 10/19/2022 12:26 PM Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.19.22 14:32:04] WorkID: 199760041 |
10-19-2022, 13:53 | #4376 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G950F u12 Repair orignal imei Chimera Mobile Phone Utility version: 33.59.1438 @ 2022-10-19 Printing phone history Read Cert 10/19/2022 12:48 PM Read Cert 10/19/2022 12:45 PM Reboot 10/19/2022 11:07 AM Read Cert 10/19/2022 11:06 AM Enable Diag Mode 10/18/2022 3:56 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Carrier ID: VOD Sales Code: XEU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Apr 6 19:15:03 KST 2021 PDA Version: G950FXXUCDUD1 [april 2021, rev1] Phone Version: G950FXXUCDUD1 [april 2021, rev1] CSC Version: G950FOXMCDUD1 [april 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8JB3GRMBR Imei: 359042089727720 Battery Status: 3.58V (9%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 03B72CB97D12 Repair imei... Operation in progress. Be patient! Do NOT disconnect the phone! Current imei: 000000000000000 Repaired imei: 359042089727720 Successfully finished. Finished at local time: [10.19.22 17:49:50] WorkID: 199763114 |
10-20-2022, 05:41 | #4377 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,745 | reply Dear Qasir, Thank you for the feedback, good job from you again! Best regards Sab Chimera team Quote:
10-20-2022, 09:51 | #4378 (permalink) |
Member: 1648903 Status: Offline Thanks Meter: 158 | Frp jkm-lx1 9.1.0.363(c185e6r5p1) Chimera Mobile Phone Utility version: 33.66.1530 @ 2022-10-20 Printing phone history Get Info 10/20/2022 8:00 AM Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.20.22 10:03:47] WorkID: 199858000 |
The Following User Says Thank You to rashidmohamm For This Useful Post: |
10-20-2022, 11:53 | #4379 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,745 | reply Dear rashidmohamm, Thank you for the feedback. Good work from you. Best regards Sab Chimera team Quote:
10-24-2022, 11:27 | #4380 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A107m patch Chimera Mobile Phone Utility version: 33.68.1346 @ 2022-10-24 Printing phone history Get Info 10/24/2022 10:22 AM Repair IMEI 10/24/2022 10:17 AM Get Info 10/24/2022 10:11 AM Patch Certificate 9/15/2022 7:20 AM Repair IMEI 9/15/2022 7:10 AM Your license is going to expire soon (4 day(s) left), if you want to extend it click here, or if you want to buy a new one, clickhere. Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A107M Carrier ID: TCE Sales Code: EBE Country Code: ECUADOR Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jul 21 23:12:10 KST 2020 PDA Version: A107MUBU5BTG4 [july 2020, rev4] Phone Version: A107MUBU5BTF1 [june 2020, rev1] CSC Version: A107MOWT5BTG4 [july 2020, rev4] Board Platform: MT6765 Modem Platform: MT6762 Serial Number: R9ANB06DFWJ Imei: 359805XXXXXXXXX Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v00 Security Patch: 2020-07-01 Em Did: DCCCCE80AB84 Patch cert... Operation in progress. Be patient! Do NOT disconnect the phone! Please restart the phone manually using the power button! Successfully finished. Finished at local time: [10.24.22 15:25:42] WorkID: 200328018 Your license is going to expire soon (4 days left), if you want to extend it click here, or if you want to buy a new one clickhere. |
The Following User Says Thank You to qasir_amz For This Useful Post: |
