03-16-2023, 07:27 | #4531 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,669 | reply Thank you for the report. Pretty good job from you. Best regards Sab Chimera team Quote:
03-16-2023, 13:16 | #4532 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | J330FN U3 imei Repair & Patch success Chimera Mobile Phone Utility version: 35.12.1127 @ 2023-03-16 Printing phone history Repair IMEI 3/16/2023 12:09 PM Reboot 3/16/2023 11:59 AM Reboot 3/16/2023 11:56 AM Get Info 3/16/2023 11:55 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J330FN Sales Code: AMO Country Code: SPAIN Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Feb 12 16:34:43 KST 2019 PDA Version: J330FNXXS3BSB1 [february 2019, rev1] Phone Version: J330FNXXU3BSB2 [february 2019, rev2] CSC Version: J330FNAMO3BRK1 [november 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58KB6Q9ACK Imei: 3532220xxxxxxxx Battery Status: 4.16V (91%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-02-01 Em Did: 05B6AE7F0B74 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.16.23 17:11:58] WorkID: 215388186 |
03-17-2023, 09:40 | #4533 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,669 | reply Dear Qasir, Thank you for the feedback. Good job from you. Best regards Sab Chimera team Quote:
03-18-2023, 11:39 | #4534 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G955F U12 Band Not compatible in AJK fix little trick Galaxy S8 plus G955F VHF bands not sported in Azad Kashmir Pakistan successful fix before patch a little trick (PTA Approved but no signal) Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-18 Printing phone history Read Cert 3/18/2023 10:24 AM SW Change 3/18/2023 10:12 AM Reboot 3/18/2023 9:39 AM Get Info 3/18/2023 9:37 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Carrier ID: EVR Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Apr 6 19:12:08 KST 2021 PDA Version: G955FXXUCDUD1 [april 2021, rev1] Phone Version: G955FXXUCDUD1 [april 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J449YJVX Imei: 358792XXXXXXXXXXX Battery Status: 3.75V (19%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 00F42E863482 Preparing... Checking root access. The phone is rooted by: 25.2:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.18.23 15:27:11] WorkID: 215569893 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
03-19-2023, 09:53 | #4535 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | M013F U6 Repair imei & Patch Success just use this Rom M013FDDU6AVC5 Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-19 Printing phone history Repair IMEI 3/19/2023 8:45 AM Repair IMEI 3/19/2023 8:22 AM SW Change 3/19/2023 7:11 AM Repair IMEI 3/19/2023 5:37 AM Get Info 3/19/2023 5:35 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-M013F Carrier ID: INS Sales Code: INS Country Code: India Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Mar 10 14:26:08 KST 2022 PDA Version: M013FDDU6AVC5 [march 2022, rev5] Phone Version: M013FDDU6AVC5 [march 2022, rev5] CSC Version: M013FODM6AVA2 [january 2022, rev2] Board Platform: MT6739 Modem Platform: MT6739 Serial Number: RZ8N80REFRJ Imei: 3565811xxxxxxxxxx Imei2: 3568811xxxxxxxxxx Battery Status: 3.90V (51%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Security Patch: 2022-01-01 Em Did: 5C98D4B12A23 Preparing... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.19.23 13:50:41] WorkID: 215658807 |
03-21-2023, 09:19 | #4538 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | g973f repair patch done Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: VOD Sales Code: BTU Country Code: UK & IRE Timezone: Europe/Istanbul Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Thu Aug 26 19:12:13 KST 2021 PDA Version: G973FXXSCFUH5 [august 2021, rev5] Phone Version: G973FXXUCFUH3 [august 2021, rev3] CSC Version: G973FOXMCFUH3 [august 2021, rev3] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Imei: 3561520622522vv Battery Status: 3.67V (38%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-09-01 Em Did: 20000E4C41123A11 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Please restart the phone manually using the power button! Successfully finished. Finished at local time: [03.21.23 11:16:15] WorkID: 215824146 |
The Following User Says Thank You to canliyayin For This Useful Post: |
03-22-2023, 06:18 | #4539 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,669 | reply Dear User, Thank you for the feedback! Good job from you! Best regards Sab Chimera team Quote:
03-22-2023, 07:30 | #4540 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A125F U2 FRP one click king chimera Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-22 Printing phone history Device Info 3/22/2023 6:23 AM Reboot 3/22/2023 6:15 AM Get Info 3/22/2023 6:14 AM Reset FRP lock started Resetting FRP... Model: SM-A125F SW Version: A125FXXU2BVB4/A125FOXM2BVB6/A125FXXU2BVB4/A125FXXU2BVB4 Serial: RZ8R50VBFVM IMEI: 3543071xxxxxxxxxx Product Code: TIM Unique Number: CDV0044C0D43C48 Operation in progress. Be patient! Do NOT disconnect the phone! Phone does not respond Restart the phone, then try again Please 'Allow USB debugging' in the popup window Waiting for ADB device... Resetting FRP... To complete resetting FRP, go to 'Settings/General management/Reset' then select 'Factory data reset' Restarting phone Successfully finished. Finished at local time: [03.22.23 11:29:44] WorkID: 215920359 |
03-22-2023, 07:36 | #4541 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A600N U6 Patch Success Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-22 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A600N Carrier ID: KTC Sales Code: KTC Country Code: KOREA Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Sat Jan 23 12:09:56 KST 2021 PDA Version: A600NKSU6CUA3 [january 2021, rev3] Phone Version: A600NKOU6CUA1 [january 2021, rev1] CSC Version: A600NOKR6CUA3 [january 2021, rev3] Board Platform: UNIVERSAL7870 Modem Platform: SHANNON315 Serial Number: RF9K601G48 Imei: 35502110XXXXXXX Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 0535751954D4 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.22.23 11:35:51] WorkID: 215920765 |
03-23-2023, 06:50 | #4542 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,669 | reply Good one from you, once again! Thank you for sharing it with us. Best regards Sab Chimera team Quote:
03-23-2023, 12:10 | #4543 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Barnsley UK Age: 56
Member: 7910 Status: Offline Thanks Meter: 57 | a13 usa spectrum unlock Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-23 Printing phone history Network Factory Reset (Online) 23/03/2023 10:09 Network Factory Reset (Online) Selected method: Hardware test point Change to bootrom mode ADB interface detected. Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! bootrom interface detected. Initializing... Reading data from the phone... Network Factory Reset Waiting for the phone to restart... Please reboot your phone by long-pressing the power button! Successfully finished. Finished at local time: [03.23.23 11:01:36] WorkID: 216043243 |
The Following User Says Thank You to Colin For This Useful Post: |
03-23-2023, 13:59 | #4544 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,669 | reply Dear Colin, Thank you for the feedback! Pretty good job from you. Best regards Sab Chimera team Quote:
03-24-2023, 16:17 | #4545 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,792 | Samsung Galaxy Tab A 7-Inch (2016) Tablet WI-FI SM-T280 frp done Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-24 Printing phone history Reset FRP Lock 28/05/2022 08:21 ص Reset FRP Lock 26/03/2021 06:09 م Reset FRP Lock 26/03/2021 06:07 م SW Change 03/05/2020 05:07 م SW Change 11/06/2019 07:11 م Reset FRP lock started Checking boot image... Present. Flashing boot image... Flashing boot image. After the reboot, you can install a stock firmware, if the boot process get stuck. Waiting for download mode. Connecting. Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Processing... To avoid any problems caused by the combination boot, please install a stock firmware. To complete FRP Reset go to Backup and Reset and select Factory Data Reset. Succeeded. Successfully finished. Finished at local time: [03.24.23 17:36:55] WorkID: 216147909 |
