07-24-2017, 13:41 | #2041 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | Chimera Mobile Phone Utility version: 14.49.1622 @ 2017-07-24 [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Finished successfully. Finished at local time: [07.24.17 14:33:39] WorkID: 24133346 |
07-25-2017, 15:07 | #2042 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Bangladesh
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | [IMG][/IMG] Chimera Mobile Phone Utility version: 14.42.1225 @ 2017-07-17 [S-ON/S-OFF started] Checking current security flag Restarting in fastboot mode Phone detected Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Checking bootloader state... Phone detected Bootloader unlock is required, asking server for access Gathering bootloader information ? All user data will be lost and the phone will reset to factory default! You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty. Please select 'Yes' to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection (If you select Yes, your phone will be reset to its factory default settings, and your bootloader will be unlocked.If you select No, your phone will reboot and no modifications will have been made.) Waiting for bootloader unlock to finish Fastboot detached. 1.) When the HTC logo appears on the screen, 1.) Please switch to HBOOT mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN and POWER until the HBOOT menu comes on. 2.) Then select FASTBOOT mode by VOLUME+/- then press POWER button Phone detected Installing recovery image Installing was successful 1.) Please select BOOTLOADER/HBOOT 2.) Select RECOVERY option from FASTBOOT menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Initializing phone side Cleaning up Restarting the phone Writing security flag Initializing phone side Cleaning up Checking Reading security flag Security flag was set correctly. Finished successfully Finished at local time: [07.17.17 18:55:11] WorkID: 23812367 Last edited by g_gsm; 07-25-2017 at 15:13. |
The Following User Says Thank You to g_gsm For This Useful Post: |
07-25-2017, 15:16 | #2043 (permalink) |
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | [IMG][/IMG] Chimera Mobile Phone Utility version: 14.53.0744 @ 2017-07-24 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G532F Sales Code: KSA Country Code: KSA Timezone: Asia/Dhaka Android Version: 6.0.1 [MMB29T] Build Date: Tue Feb 28 13:24:33 KST 2017 PDA Version: G532FXWU1AQB5 [february 2017, rev5] Phone Version: G532FXXU1AQB3 [february 2017, rev3] CSC Version: G532FOJV1AQB5 [february 2017, rev5] Product Code: SM-G532FZDDKSA HIDSw Version: G532FXWU1AQB5/G532FOJV1AQB5/G532FXXU1AQB3/G532FXWU1AQB5 Board Platform: MT6737T Modem Platform: MT6737T Serial Number: RV8J61L9QDW Imei: 359614081230448 Unique Number: CQN00E7C2C65654 Connections: AT,MTP Battery Status: 3.86V (22%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-03-01 Data Encryption State: encrypted Checking custom root image... Present. To avoid "To start up your device, enter your password", ? go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. The data partition is encrypted so after the root the phone may ask for a password (minimal-framework). Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Preparing... Reading and storing secure images. Be patient! Do NOT disconnect the phone! Unlocking... Preparing simlock. Unlocked. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. Finished successfully. Finished at local time: [07.24.17 18:46:21] WorkID: 24133690 |
07-25-2017, 15:22 | #2044 (permalink) |
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | [IMG][/IMG] Chimera Mobile Phone Utility version: 14.53.0744 @ 2017-07-24 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G532F Sales Code: KSA Country Code: KSA Timezone: Asia/Dhaka Android Version: 6.0.1 [MMB29T] Build Date: Tue Feb 28 13:24:33 KST 2017 PDA Version: G532FXWU1AQB5 [february 2017, rev5] Phone Version: G532FXXU1AQB3 [february 2017, rev3] CSC Version: G532FOJV1AQB5 [february 2017, rev5] Product Code: SM-G532FZDDKSA HIDSw Version: G532FXWU1AQB5/G532FOJV1AQB5/G532FXXU1AQB3/G532FXWU1AQB5 Board Platform: MT6737T Modem Platform: MT6737T Serial Number: RV8J61L9S9V Imei: 359614081231065 Unique Number: CQN00EB4CC4C854 Connections: AT,MTP Battery Status: 3.69V (21%) Network Type: GSM SIM Status: ABSENT,NETWORK_LOCKED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-03-01 Data Encryption State: encrypted Checking custom root image... Present. To avoid "To start up your device, enter your password", ? go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. The data partition is encrypted so after the root the phone may ask for a password (minimal-framework). Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Preparing... Reading and storing secure images. Be patient! Do NOT disconnect the phone! Unlocking... Preparing simlock. Unlocked. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. Finished successfully. Finished at local time: [07.24.17 18:52:32] WorkID: 24134063 |
07-25-2017, 15:24 | #2045 (permalink) |
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | [IMG][/IMG] Chimera Mobile Phone Utility version: 14.49.1622 @ 2017-07-23 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J700T Sales Code: TMB Country Code: USA Timezone: Asia/Dhaka Android Version: 6.0.1 [MMB29K] Build Date: Thu Nov 24 14:58:58 KST 2016 PDA Version: J700TUVU2APK6 [november 2016, rev6] Phone Version: J700TUVU2APK6 [november 2016, rev6] CSC Version: J700TTMB2APK6 [november 2016, rev6] Product Code: XXXXXXXXXXXTMB HIDSw Version: J700TUVU2APK6/J700TTMB2APK6/J700TUVU2APK6/J700TUVU2APK6 Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: R58H90WSVNJ Imei: 357218076959987 Unique Number: C0000BBA60F6853 Connections: AT,MTP Battery Status: 3.83V (36%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-11-01 Data Encryption State: encrypted Checking custom root image... Present. To avoid "To start up your device, enter your password", ? go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. The data partition is encrypted so after the root the phone may ask for a password (minimal-framework). Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-J700T, Region: USA, Provider: TMO, PDA: J700TUVU2APK6 Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Preparing secure image. Be patient! Do NOT disconnect the phone! Trying on SAMSUNG Mobile USB Modem (COM115) Processing. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [07.23.17 19:21:14] WorkID: 24107343 ===== |
07-25-2017, 15:27 | #2046 (permalink) |
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | [IMG][/IMG] Chimera Mobile Phone Utility version: 14.47.0910 @ 2017-07-19 Printing phone history Unlock 7/19/2017 9:26:16 AM [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: INS Country Code: India Timezone: Asia/Dhaka Android Version: 6.0.1 [MMB29K] Build Date: Wed Apr 19 18:31:12 KST 2017 PDA Version: G570FXXU1AQD2 [april 2017, rev2] Phone Version: G570FXXU1API9 [september 2016, rev9] CSC Version: G570FODD1AQD2 [april 2017, rev2] Product Code: SM-G570FZKDINS HIDSw Version: G570FXXU1AQD2/G570FODD1AQD2/G570FXXU1API9/G570FXXU1AQD2 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58J60SW98X Imei: 357762087841999 Unique Number: CQ3002915DA8854 Connections: AT,MTP Battery Status: 4.32V (98%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-04-01 Data Encryption State: encrypted Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [07.19.17 15:43:08] WorkID: 23913616 |
07-25-2017, 15:29 | #2047 (permalink) |
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | [IMG][/IMG] Chimera Mobile Phone Utility version: 14.49.1622 @ 2017-07-23 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610F Sales Code: KSA Country Code: KSA Timezone: Asia/Dhaka Android Version: 6.0.1 [MMB29K] Build Date: Wed Dec 28 15:04:12 KST 2016 PDA Version: G610FDDU1APLC [december 2016, revC] Phone Version: G610FDDU1API9 [september 2016, rev9] CSC Version: G610FOJV1APJ2 [october 2016, rev2] Product Code: SM-G610FZDDKSA HIDSw Version: G610FDDU1APLC/G610FOJV1APJ2/G610FDDU1API9/G610FDDU1APLC Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58J60JK7YH Imei: 354772086828072 Unique Number: CAJ033E4948C354 Connections: AT,MTP Battery Status: 4.25V (98%) Network Type: GSM SIM Status: NETWORK_LOCKED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-10-01 Data Encryption State: encrypted Checking custom root image... Present. To avoid "To start up your device, enter your password", ? go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. The data partition is encrypted so after the root the phone may ask for a password (minimal-framework). Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G610F, Region: SWA, Provider: OPEN, PDA: G610FDDU1APLC Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. Unlocked. Finished successfully. Finished at local time: [07.23.17 15:39:20] WorkID: 24103261 |
The Following 2 Users Say Thank You to g_gsm For This Useful Post: |
07-25-2017, 23:38 | #2048 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Unlock J320M (Read Codes) Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-25 Printing phone history Info 25/7/2017 10:34:19 p. m. [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J320M Sales Code: TFG Country Code: OPEN Timezone: America/Argentina/Buenos_Aires Android Version: 5.1.1 [LMY47V] Build Date: Tue Sep 13 02:42:08 KST 2016 PDA Version: J320MUBU0API1 [september 2016, rev1] Phone Version: J320MUBU0APH1 [august 2016, rev1] CSC Version: J320MTFG0API2 [september 2016, rev2] Product Code: SM-J320MZWPUFN HIDSw Version: J320MUBU0API1/J320MTFG0API2/J320MUBU0APH1/J320MUBU0API1 Board Platform: SC8830 Modem Platform: SC9830I Serial Number: RV8H91L04ME Imei: 359931074120919 Unique Number: CQN00F5FB68CD63 Connections: AT,MTP Battery Status: 3.89V (50%) Network Type: GSM SIM Status: ABSENT Warranty Bit: unknown Security Patch: 2016-09-01 Data Encryption State: unencrypted Reading Codes... Trying on modem port SAMSUNG Mobile USB Modem (COM53) Freeze Code: 91381740 Network Lock: 46931720 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [07.25.17 19:35:39] WorkID: 24220299 |
07-26-2017, 00:24 | #2049 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Unlock I9195L with out root Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-25 Printing phone history Info 25/7/2017 11:17:00 p. m. [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9195L Sales Code: COM Country Code: COLOMBIA Timezone: America/Argentina/Buenos_Aires Android Version: 4.2.2 [JDQ39] Build Date: Tue Jul 23 16:17:21 KST 2013 PDA Version: I9195LUBUAMG5 [july 2013, rev5] Phone Version: I9195LUBUAMG5 [july 2013, rev5] CSC Version: I9195LUWAAMG5 [july 2013, rev5] Product Code: GT-I9195ZKMCOM HIDSw Version: I9195LUBUAMG5/I9195LUWAAMG5/I9195LUBUAMG5/I9195LUBUAMG5 Board Platform: MSM8960 Modem Platform: MSM8930AB Serial Number: R21D9A4Z0RH Imei: 357957052413861 Unique Number: C08900880F92A90 Connections: AT,MTP Battery Status: 4.10V (88%) Network Type: GSM SIM Status: ABSENT Data Encryption State: unencrypted Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is initialized. 5. Click OK button Trying on SAMSUNG Mobile USB Serial Port (COM55) Unlocked. Finished successfully. Finished at local time: [07.25.17 20:18:38] WorkID: 24221943 |
The Following User Says Thank You to gcceleghg For This Useful Post: |
07-26-2017, 09:01 | #2050 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | [Repair Qualcomm modem filesystem.] File: ChimeraFiles/Samsung/Qualcomm/SM-G530H/SM-G530H_from_server.cqcn Connecting to phone.  1.On dial window enter *#0808# (or *#9090# or *#7284#) and set DM + MODEM + ADB 2. Select OK on phone display Try to connect: COM398 Phone found at COM398. Authenticating. Login with SPC password: 000000. done. Login with diagnostic password: FFFFFFFFFFFFFFFF. done. Gathering qcn filesystem information. done. Be patient! Do NOT disconnect the phone! Restore the config files. 4 files saved. Restore the rf files. 102 files saved. Restoring the nv items. NVItem 2602: skipped. 1389 nv items restored.  Network calibration data succesfully repaired! If your phone has no signal after 20 mintues, please try to Repair IMEI. Restarting phone. Finished successfully. Finished at local time: [07.26.17 10:56:37] WorkID: 24229161 |
The Following User Says Thank You to ibrajinja For This Useful Post: |
07-26-2017, 11:37 | #2051 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-26 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-S5360 Sales Code: SWR Country Code: Switzerland Android Version: 2.3.6 [GINGERBREAD] Build Date: Tue Nov 5 23:26:58 KST 2013 PDA Version: S5360XXMK1 [november 2013, rev1] Phone Version: S5360XXMK1 [november 2013, rev1] CSC Version: S5360SWRML1 [december 2013, rev1] Product Code: GT2S5360TKASWR HIDSw Version: S5360XXMK1/S5360SWRML1/S5360XXMK1/S5360XXMK1 Board Platform: BCM21553 Imei: 35177706871AAA2 Connections: AT,UMS Network Type: GSM SIM Status: ABSENT Reading Codes... Trying on modem port SAMSUNG Mobile USB Modem (COM181) Freeze Code: 60380863 Network Lock: 40592959 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [07.26.17 10:35:43] WorkID: 24233697 |
07-26-2017, 11:38 | #2052 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-26 [Patch certificate started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A310F Sales Code: BTU Country Code: UK & IRE Timezone: Africa/Banjul Android Version: 5.1.1 [LMY47X] Build Date: Wed Apr 27 12:50:56 KST 2016 PDA Version: A310FXXU2APDC [april 2016, revC] Phone Version: A310FXXU2APC5 [march 2016, rev5] CSC Version: A310FBTU2APDC [april 2016, revC] Product Code: SM-A310FZKABTU HIDSw Version: A310FXXU2APDC/A310FBTU2APDC/A310FXXU2APC5/A310FXXU2APDC Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: R28HA0NAAAAMZ Imei: 35416208358AAA5 Unique Number: CAJ03BF3A51AF93 Connections: AT,MTP Battery Status: 4.25V (86%) Network Type: GSM SIM Status: READY Knox Version: v30 Warranty Bit: 1 Security Patch: 2016-05-01 Data Encryption State: unencrypted Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-A310F, Region: EUR, Provider: OPEN, PDA: A310FXXU2APDC Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Patching certificate... Initializing. Reading modem. Be patient! Do NOT disconnect the phone! Preparing. Reminder! In case of new firmware flashing or modem replacement, the "Patch Cert" process must be repeated! Succeeded. Finished successfully. Finished at local time: [07.26.17 09:57:43] WorkID: 24231914 |
07-26-2017, 18:21 | #2053 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Reset Screen Lock - G920F Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-26 [Reset screen lock started] Selected model: SM-G920F Checking firmware image... Present. Flashing firmware image... Downloading firmware image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Flashing firmware image. Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-G920F, Region: EUR, Provider: OPEN, PDA: G920FXXS5EQF9 Reading PIT. Flashing image. Restarting phone. To complete Reset ScreenLock goto "Backup and reset" and select "Factory data reset". Succeeded. Finished successfully. Finished at local time: [07.26.17 14:17:24] WorkID: 24254339 |
07-26-2017, 19:43 | #2054 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | G920F Read Codes 7.0 Done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-26 Printing phone history Info 26/7/2017 6:36:19 p. m. [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920F Sales Code: XSG Country Code: UAE Timezone: GMT Android Version: 7.0 [NRD90M] Build Date: Thu Jun 8 20:45:18 KST 2017 PDA Version: G920FXXS5EQF9 [june 2017, rev9] Phone Version: G920FXXU5EQEG [may 2017, revG] CSC Version: G920FOJV5EQD1 [april 2017, rev1] Product Code: XSG HIDSw Version: G920FXXS5EQF9/G920FOJV5EQD1/G920FXXU5EQEG/G920FXXS5EQF9 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58G82072FT Imei: 359937069422293 Unique Number: 06157DF6CCA88824 Connections: AT,MTP Battery Status: 3.81V (30%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-06-01 Data Encryption State: unencrypted Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. To avoid "To start up your device, enter your password",  go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G920F, Region: EUR, Provider: OPEN, PDA: G920FXXS5EQF9 Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Reading Codes... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Calculating. Be patient! Do NOT disconnect the phone! MasterLock: 09626057 NetworkLock: 00000000 SubsetLock: 00000000 SpLock: 00000000 CpLock: 00000000 SimLock: 00000000 Finished successfully. Finished at local time: [07.26.17 15:38:42] WorkID: 24258989 |
