07-29-2017, 09:27 | #2071 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | [Removing network lock...] This method will overwrite the factory recovery with a custom recovery (TWRP). In some cases, it will remain permanently installed on the phone. Are you sure you want to continue? Checking bootloader... Rebooting device to fastboot mode... Device found! bootloader status: locked Unlocking bootloader... Searching for Manufacture port... Couldn't connect to the phone. Please try the following: Try reconnecting the USB cable Please power off your phone, then insert USB cable while the device is still powered off. Check MTK drivers, and re-install them if necessary. Check Windows device manager. A new serial COM-port should appear associated to the phone at this stage. Phone version: BB chip version: mt6735m,S01 DSP fw version: Fri Dec 30 20:19:13 CST 2016 DSP patch version: n/a Eco version: n/a Hardware version: ALPS.L1.MP3.V2.95_OT6735M.35GU.L1_P91 Melody version: S01 Software version: n/a Unlocking bootloader... Bootloader unlock / relock code: 2781298758318837 Device found! Unlocking the bootloader will erase all your data from the phone! Also, pobably the bootloader cannot be re-locked later. Are you sure you want to unlock the bootloader? The phone might ask for confirmation. Please check the phone screen and follow the instructions. The phone is now restarting. Please be patient, as it might take a few minutes for the factory reset to complete. After the device has been booted, please enable the USB debugging and the OEM-unlocking options in the developer menu on your phone. To access developer settings, press 7 times on the Build number in the About phone menu. When you have finished with these tasks, click OK to continue. Waiting for the phone... Rebooting device to fastboot mode... Device found! Downloading TWRP recovery... Booting recovery... Please keep pressing down the volume up button while clicking OK below. Do not release the volume up button until recovery is booted. If a menu appears on the phone, select recovery mode. Removing SIM-lock... Finished successfully. Finished at local time: [๐๗.๒๙.๑๗ ๑๕:๒๕:๕๔] WorkID: 24377339 |
07-29-2017, 11:43 | #2072 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2384553 Status: Offline Thanks Meter: 85 | n7105 network repair Successfully Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-29 Printing phone history Network repair 29-Jul-17 10:40:38 AM [Repair Qualcomm modem filesystem.] File: ChimeraFiles/Samsung/Qualcomm/GT-N7105/GT-N7105_from_server.cqcn Connecting to phone.  1.On dial window enter *#0808# (or *#9090# or *#7284#) and set DM + MODEM + ADB 2. Select OK on phone display Try to connect: COM563 Phone found at COM563. Authenticating. Login with SPC password: 000000. done. Login with diagnostic password: FFFFFFFFFFFFFFFF. done. Gathering qcn filesystem information. done. Be patient! Do NOT disconnect the phone! Restore the config files. 17 files saved. Restore the rf files. 100 files saved. Restoring the nv items. NVItem 2602: skipped. 1390 nv items restored.  Network calibration data succesfully repaired! If your phone has no signal after 20 mintues, please try to Repair IMEI. Restarting phone. Finished successfully. Finished at local time: [07.29.17 15:42:26] WorkID: 24381613 |
07-29-2017, 13:36 | #2073 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | G920f Version 7.0 unlock done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-29 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920F Sales Code: VOD Country Code: UK Timezone: Asia/Karachi Android Version: 7.0 [NRD90M] Build Date: Sat Feb 25 19:35:17 KST 2017 PDA Version: G920FXXU5EQBG [february 2017, revG] Phone Version: G920FXXU5EQAC [january 2017, revC] CSC Version: G920FVFG5EQBG [february 2017, revG] Product Code: VOD HIDSw Version: G920FXXU5EQBG/G920FVFG5EQBG/G920FXXU5EQAC/G920FXXU5EQBG Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8G51WJXZJ Imei: 352148072xxxxxx Unique Number: 04157DF4C041D710 Connections: AT,MTP Battery Status: 4.26V (100%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-02-01 Data Encryption State: unencrypted Checking custom root image... Present. To avoid "To start up your device, enter your password",  go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G920F, Region: EUR, Provider: OPEN, PDA: G920FXXU5EQBG Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [07.29.17 17:33:28] WorkID: 24385491 |
07-29-2017, 13:42 | #2074 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | i9505 5.01 unlock done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-29 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9505 Sales Code: EVR Country Code: UK Timezone: Asia/Karachi Android Version: 5.0.1 [LRX22C] Build Date: Wed Nov 16 19:12:05 KST 2016 PDA Version: I9505XXUHPK2 [november 2016, rev2] Phone Version: I9505XXUHPK2 [november 2016, rev2] CSC Version: I9505EVRHQA1 [january 2017, rev1] Board Platform: MSM8960 Modem Platform: MDM9215M Serial Number: R28F318WDND Imei: 353514060xxxxxx Battery Status: 3.88V (46%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-11-01 Data Encryption State: unencrypted Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM571) Protocol is not supported. Trying on SAMSUNG Mobile USB Serial Port (COM572) Unlocked. Finished successfully. Finished at local time: [07.29.17 17:41:21] WorkID: 24385863 |
07-29-2017, 13:44 | #2075 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | J200h Frp remove done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-29 Printing phone history Reset FRP Lock 29-Jul-17 7:37:42 AM Reset FRP Lock 29-Jul-17 7:27:24 AM Reset FRP Lock 26-Jul-17 11:30:33 AM Reset FRP Lock 26-Jul-17 11:27:35 AM Reset FRP Lock 26-Jul-17 11:24:28 AM [Reset FRP lock started] Selected model: SM-J200H Resetting FRP by old odin based method. Processing... Waiting for download mode. Connecting. Initializing. Reading PIT. Reseting. Restarting phone. Please install a stock firmware. Finished successfully. Finished at local time: [07.29.17 17:43:33] WorkID: 24385933 |
07-29-2017, 14:05 | #2076 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | g930f Frp reset done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-29 Printing phone history Reset FRP Lock 29-Jul-17 1:01:37 PM Reset FRP Lock 29-Jul-17 12:45:50 PM Reset FRP Lock 29-Jul-17 12:43:22 PM Reset FRP Lock 29-Jul-17 7:37:42 AM Reset FRP Lock 29-Jul-17 7:27:24 AM [Reset FRP lock started] Selected model: SM-G930F Resetting FRP by engineering boot based method. Processing... Processing. Be patient! Do NOT disconnect the phone! After reboot if the boot process get stuck, you can install a stock firmware. Checking custom root image... Present. Rooting by custom image based root method... Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-G930F, Region: EUR, Provider: OPEN, PDA: G930FXXU1APB6 Reading PIT. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Resetting FRP lock... Done. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. Succeeded. Finished successfully. Finished at local time: [07.29.17 18:04:41] WorkID: 24386693 |
07-29-2017, 15:22 | #2077 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | J320fn Cert read successfully Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-29 [Read/Write certificate started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J320FN Sales Code: H3G Country Code: UK Timezone: Asia/Karachi Android Version: 5.1.1 [LMY47V] Build Date: Sat Mar 12 17:59:03 KST 2016 PDA Version: J320FNXXU0APC6 [march 2016, rev6] Phone Version: J320FNXXU0APC3 [march 2016, rev3] CSC Version: J320FNH3G0APC3 [march 2016, rev3] Product Code: SM-J320FZDNH3G HIDSw Version: J320FNXXU0APC6/J320FNH3G0APC3/J320FNXXU0APC3/J320FNXXU0APC6 Board Platform: SC8830 Modem Platform: SC9830I Serial Number: R58H63K2JRZ Imei: 35233708195xxxx Unique Number: CQN0019B596A743 Connections: AT,MTP Battery Status: 3.59V (3%) Network Type: GSM SIM Status: ABSENT Warranty Bit: unknown Security Patch: 2016-03-01 Data Encryption State: unencrypted Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Processing... Reading image #1 Storing image #1 Preparing image #1 Cert written to: C:/ChimeraFiles/Samsung/Cert/SM-J320FN/SM-J320FN_3523370819xxxx.cert Succeeded. Finished successfully. Finished at local time: [07.29.17 19:20:18] WorkID: 24389713 |
07-30-2017, 08:52 | #2078 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | J700m Unlock Done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-30 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J700M Sales Code: CGU Country Code: Guatemala Timezone: Asia/Karachi Android Version: 5.1.1 [LMY48B] Build Date: Wed Jun 1 04:59:49 KST 2016 PDA Version: J700MUBU2APF1 [june 2016, rev1] Phone Version: J700MUBU2APF1 [june 2016, rev1] CSC Version: J700MUWM2APF2 [june 2016, rev2] Product Code: SM-J700MZKACGU HIDSw Version: J700MUBU2APF1/J700MUWM2APF2/J700MUBU2APF1/J700MUBU2APF1 Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: R28H82WKTXR Imei: 3517070826xxxxx Unique Number: C0000664F3AC553 Connections: AT,MTP Battery Status: 4.21V (89%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-06-01 Data Encryption State: unencrypted Unlocking... Please unlock screen if closed. Trying on SAMSUNG Mobile USB Modem (COM591) Processing. Be patient! Do NOT disconnect the phone! Restarting. Unlocked. Finished successfully. Finished at local time: [07.30.17 12:50:13] WorkID: 24417572 |
07-30-2017, 10:24 | #2079 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | j230fn Write patch successfully Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-30 Printing phone history Patch Certificate 29-Jul-17 2:45:28 PM Patch Certificate 29-Jul-17 2:23:56 PM Info 29-Jul-17 2:23:30 PM [Patch certificate started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J320FN Sales Code: DDE Country Code: Germany Timezone: Asia/Karachi Android Version: 5.1.1 [LMY47V] Build Date: Wed Mar 16 18:49:44 KST 2016 PDA Version: J320FNXXU0APC8 [march 2016, rev8] Phone Version: J320FNXXU0APD1 [april 2016, rev1] CSC Version: J320FNDDX0APC2 [march 2016, rev2] Product Code: SM-J320FZKNXFA HIDSw Version: J320FNXXU0APC8/J320FNDDX0APC2/J320FNXXU0APD1/J320FNXXU0APC8 Board Platform: SC8830 Modem Platform: SC9830I Serial Number: R58H614SHCX Imei: 359464079653437 Unique Number: CQN00D5FDC65D43 Connections: AT,MTP Battery Status: 3.84V (36%) Network Type: GSM SIM Status: ABSENT Warranty Bit: unknown Security Patch: 2016-03-01 Data Encryption State: unencrypted Checking custom root image... Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Patching certificate... Reading data. Be patient! Do NOT disconnect the phone! Writing data. Be patient! Do NOT disconnect the phone! Reminder! In case of new firmware flashing the "Patch Certificate" process must be repeated! Succeeded. Finished successfully. Finished at local time: [07.30.17 14:16:48] WorkID: 24418465 |
07-30-2017, 13:31 | #2080 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | G925F Unlock done Version 7.0 Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-30 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G925F Sales Code: EVR Country Code: UK Timezone: Asia/Karachi Android Version: 7.0 [NRD90M] Build Date: Thu Jun 15 17:06:39 KST 2017 PDA Version: G925FXXU5EQFH [june 2017, revH] Phone Version: G925FXXU5EQF1 [june 2017, rev1] CSC Version: G925FEVR5EQE1 [may 2017, rev1] Product Code: EVR HIDSw Version: G925FXXU5EQFH/G925FEVR5EQE1/G925FXXU5EQF1/G925FXXU5EQFH Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58H60765PM Imei: 3564210749xxxxx Unique Number: 0416049856ED2302 Connections: AT,MTP Battery Status: 3.91V (62%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-06-01 Data Encryption State: unencrypted Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. To avoid "To start up your device, enter your password",  go to "Settings -> Google -> Security" and turn OFF "Scan device for security threats" option. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G925F, Region: EUR, Provider: OPEN, PDA: G925FXXU5EQFH Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [07.30.17 17:29:28] WorkID: 24421774 |
07-30-2017, 14:18 | #2081 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | G9350 Info read successfully Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-30 Printing phone history Reset FRP Lock 29-Jul-17 1:03:01 PM Reset FRP Lock 29-Jul-17 1:01:37 PM Reset FRP Lock 29-Jul-17 12:45:50 PM Reset FRP Lock 29-Jul-17 12:43:22 PM Reset FRP Lock 29-Jul-17 7:37:42 AM [Get device info started] Gathering device info... Collecting device information. Be patient! Do NOT disconnect the phone! Selected model: SM-G9350 DVIF CAPA: 32 FWVER: 0009 MODEL: SM-G9350 PRODUCT: KLUBG4G1CE-B0B1 PROV: PASS UN: CE0316037C315E1A05 VENDOR: SAMSUNG PIT PIT written to file: "Backup/SM-G9350/PIT/SM-G9350_24422772.pit" Finished successfully. Finished at local time: [07.30.17 18:17:47] WorkID: 24422772 |
07-31-2017, 06:39 | #2082 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | WUAWEI Y6II (caml-21) done. Chimera Mobile Phone Utility version: 14.54.1007 @ ๒๐๑๗-๐๗-๓๑ [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [๐๗.๓๑.๑๗ ๑๒:๓๖:๐๗] WorkID: 24437283 |
07-31-2017, 08:22 | #2083 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | G900f unlock done Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-31 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G900F Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 5.0 [LRX21T] Build Date: Tue Mar 15 13:56:46 KST 2016 PDA Version: G900FXXS1PPCG [march 2016, revG] Phone Version: G900FXXU1POEC [may 2015, revC] CSC Version: G900FOJV1POG1 [july 2015, rev1] Product Code: SM-G900FZWAEVR HIDSw Version: G900FXXS1PPCG/G900FOJV1POG1/G900FXXU1POEC/G900FXXS1PPCG Board Platform: MSM8974 Modem Platform: MSM8974PRO Serial Number: RF8F40GC4DW Imei: 353222063xxxxx Unique Number: CMA00C58D97AC31 Connections: AT,MTP,MTP Battery Status: 3.86V (44%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-03-01 Data Encryption State: unencrypted Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is initialized. 5. Click OK button Appropriate serial port is not available. 1. On dial window enter *#0808# or *#9090# or *#7284# 2. Select DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is initialized. 5. Click OK button Trying on SAMSUNG Mobile USB Serial Port (COM473) Unlocked. Finished successfully. Finished at local time: [07.31.17 12:22:04] WorkID: 24438360 |
07-31-2017, 08:59 | #2084 (permalink) |
Member: 2384553 Status: Offline Thanks Meter: 85 | i9300 cert write successfully Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-31 [Read/Write certificate started] An important information is still missing. Collecting information. Be patient! Do NOT disconnect the phone!  Unable to detect imei number and baseband version. It seems that the modem does not work or network is unavailable/disabled.  Please reinstall a complete stock firmware and try again! Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9300 Sales Code: MID Country Code: Iraq Timezone: Asia/Karachi Android Version: 4.3 [JSS15J] Build Date: Thu Feb 25 16:46:13 KST 2016 PDA Version: I9300XXUGPB1 [february 2016, rev1] CSC Version: I9300OJVGPB1 [february 2016, rev1] Board Platform: EXYNOS4 Battery Status: 3.82V (41%) Network Type: GSM SIM Status: NOT_READY Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Root method failed. Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing recovery.img Flashing cache.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Determining secure image format. done. Creating backup. done. Gathering cert information done. Calculating key. done. Saving certificate. Cert written to: ChimeraFiles/Samsung/Cert/GT-I9300/Backup/backup_2017_07_31_12_58_23_GT-I9300_.cert Writing image. Checking secure image. Writing secure image. done. Restarting phone. Finished successfully. Finished at local time: [07.31.17 12:58:34] WorkID: 24438933 |
07-31-2017, 10:46 | #2085 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Gt s7390g read code done Code: Chimera Version Mobile Phone Utility : 14.53.0744 @ 2017-07-31 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-S7390G Sales Code: FTM Country Code: France Timezone: Indian/Antananarivo Android Version: 4.1.2 [JZO54K] Build Date: Thu Jan 29 12:37:13 KST 2015 PDA Version: S7390GXXUAOB1 [february 2015, rev1] Phone Version: S7390GXXUAOB1 [february 2015, rev1] CSC Version: S7390GFTMAOB1 [february 2015, rev1] Product Code: GT-S7390MKFFTM HIDSw Version: S7390GXXUAOB1/S7390GFTMAOB1/S7390GXXUAOB1/S7390GXXUAOB1 Board Platform: HAWAII Serial Number: R21F93NSNHM Imei: 352905068270473 Unique Number: CN50494AFD45E91 Connections: AT,MTP Battery Status: 3.83V (37%) Network Type: GSM SIM Status: ABSENT Data Encryption State: unsupported Reading Codes... Essai sur le port modem SAMSUNG Mobile USB Modem (COM76) Freeze Code: 84850972 Network Lock: 25262915 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [07.31.17 12:43:32] WorkID: 24442145 |
