01-01-2018, 08:53 | #2746 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | Huawei Nova IMEI Reapir Sucess Chimera Mobile Phone Utility version: 16.03.1047 @ 2018-01-01 Printing phone history FRP Remove 1/1/2018 7:39:32 AM [Repairing IMEI(s)...] Searching for Manufacture port... Testing connection... Checking IMEI(s)... Old IMEI 1: 8631630337xxxxx New IMEI 1: 3557880654xxxx Old IMEI 2: 8631630338xxxxx New IMEI 2: 3557880654xxxxx Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing first IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Resetting device to factory state... Finished successfully. |
The Following User Says Thank You to applestorebd For This Useful Post: |
01-02-2018, 07:08 | #2747 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Printing phone history Unlock 2/1/2561 5:38:06 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J730F Sales Code: PHN Country Code: The Netherlands Timezone: Asia/Bangkok Android Version: 7.0 [NRD90M] Build Date: Fri Sep 22 14:52:36 KST 2017 PDA Version: J730FXXU1AQI5 [september 2017, rev5] Phone Version: J730FXXU1AQI5 [september 2017, rev5] CSC Version: J730FPHN1AQI1 [september 2017, rev1] Product Code: PHN HIDSw Version: J730FXXU1AQI5/J730FPHN1AQI1/J730FXXU1AQI5/J730FXXU1AQI5 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58JB020RBD Imei: 359603083935088 Unique Number: CAJ00FD42F4DCA4 Connections: AT,MTP Battery Status: 3.74V (20%) Network Type: GSM SIM Status: ABSENT,NETWORK_LOCKED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-08-01 Data Encryption State: encrypted Checking custom root image... Present. The "Data Encryption State" is "encrypted", therefore, after the root process the phone will most likely start in minimal framework. Minimal framework information:  In minimal framework mode you have two options: 1. By selecting the "Reset" button you can turn off the encryption of the data partition, but all user data will be lost! 2. You can revert the phone to the original state by flasing a stock firmware. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-J730F, Region: EUR, Provider: OPEN, PDA: J730FXXU1AQI5 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! It is necessary to restart the phone. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [๐๑.๐๒.๑๘ ๑๓:๐๔:๒๖] WorkID: 31375045 |
The Following User Says Thank You to wsmobile For This Useful Post: |
01-02-2018, 09:51 | #2748 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | huawei mate10 pro done. Chimera Mobile Phone Utility version: 16.03.1047 @ ๒๐๑๘-๐๑-๐๒ [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [๐๑.๐๒.๑๘ ๑๕:๔๙:๑๖] WorkID: 31377414 |
01-02-2018, 09:57 | #2749 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Chimera Mobile Phone Utility version: 16.03.1047 @ ๒๐๑๘-๐๑-๐๒ Printing phone history FRP Remove 2/1/2561 8:48:45 [Resetting device to factory state...] Searching for Manufacture port... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Removing Huawei-ID Protection from the device... Resetting device to factory state... Finished successfully. Finished at local time: [๐๑.๐๒.๑๘ ๑๕:๕๗:๒๑] WorkID: 31377578 |
01-02-2018, 10:59 | #2750 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | HTC M8S DIRECT UNLOCK DONE Chimera Mobile Phone Utility version: 16.03.1047 @ 2018-01-02 [Direct unlock started] Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Checking bootloader state... Phone detected Bootloader unlock is required, asking server for access Gathering bootloader information  All user data will be lost and the phone will reset to factory default! You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty. Please select 'Yes' to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection (If you select Yes, your phone will be reset to its factory default settings, and your bootloader will be unlocked.If you select No, your phone will reboot and no modifications will have been made.) Waiting for bootloader unlock to finish Fastboot detached. 1.) When the HTC logo appears on the screen, 1.) Please switch to HBOOT mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN and POWER until the HBOOT menu comes on. 2.) Then select FASTBOOT mode by VOLUME+/- then press POWER button Phone detected Booting recovery image Boot command was successful. Waiting for ADB device Failed to boot recovery image. 1.) Hard reset the phone 1.) Please switch to HBOOT mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN and POWER until the HBOOT menu comes on. 2.) Then select FASTBOOT mode by VOLUME+/- then press POWER button Phone detected Installing recovery image Installing was successful 1.) Please select BOOTLOADER/HBOOT 2.) Select RECOVERY option from FASTBOOT menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Initializing phone side Cleaning up Rebooting to recovery mode Writing simlock data Simlock write done Re-checking simlock data Simlock data is verified Initializing phone side Cleaning up Restarting the phone Finished successfully Finished at local time: [01.02.18 11:56:01] WorkID: 31378728 |
The Following User Says Thank You to bright hlatini For This Useful Post: |
01-02-2018, 20:45 | #2751 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Huawei P10 Lite, (WAS-LX1A), FRP removed done Quote:
allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
01-03-2018, 08:40 | #2752 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | huawei p10 plus done. [Resetting device to factory state...] Searching for Manufacture port... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Removing Huawei-ID Protection from the device... Resetting device to factory state... Finished successfully. Finished at local time: [๐๑.๐๓.๑๘ ๑๔:๓๗:๕๐] WorkID: 31426095 |
01-04-2018, 04:14 | #2753 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Chimera Mobile Phone Utility version: 16.16.1303 @ 2018-01-04 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570M Sales Code: ZTO Country Code: Brazil Timezone: America/Argentina/Buenos_Aires Android Version: 6.0.1 [MMB29K] Build Date: Thu Nov 9 22:32:35 KST 2017 PDA Version: G570MUBU2AQK2 [november 2017, rev2] Phone Version: G570MUBU2AQJ1 [october 2017, rev1] CSC Version: G570MZTO2AQK2 [november 2017, rev2] Product Code: SM-G570MWDVZTO HIDSw Version: G570MUBU2AQK2/G570MZTO2AQK2/G570MUBU2AQJ1/G570MUBU2AQK2 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R28J62VKHRH Imei: 354621083649793 Unique Number: CQ3002E52971A54 Connections: AT,MTP Battery Status: 4.33V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-08-01 Data Encryption State: encrypted Reading Codes Online... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port not found. 1. On dial window enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is up 5. Click OK button Serial port found on COM157 Reading data. Be patient! Do NOT disconnect the phone! Communicating with the server... Waiting for the server to respond.  This operation costed 59 credits. New balance: 333 Master Lock: 90538594 Network Lock: 00000000 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [01.04.18 00:09:16] WorkID: 31481396 |
01-05-2018, 14:37 | #2756 (permalink) |
Junior Member Join Date: Jul 2008
Member: 819747 Status: Offline Thanks Meter: 6 | huawei p10 plus done. [Resetting device to factory state...] Searching for Manufacture port... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Removing Huawei-ID Protection from the device... Resetting device to factory state... Finished successfully. |
01-06-2018, 09:18 | #2757 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Chimera authenticator error in windows 10 My chimera authenticator doesnt work on windows 10 baesd PC What will be the possible solution? |
01-06-2018, 13:53 | #2760 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | LG K4 K121 Direct unlocked done Chimera Mobile Phone Utility version: 16.18.1249 @ 2018-01-06 Printing phone history Direct Unlock 1/6/2018 11:20:16 AM Direct Unlock 1/6/2018 11:15:57 AM Direct Unlock 1/6/2018 11:12:01 AM Info 1/6/2018 11:11:40 AM [Direct Unlock started] You have 1 backup created for this phone in the past 12 hours. Skipping backup process. Checking ports For unlock, a DIAG mode serial must be present. Searching for ports Waiting for diag serial port to appear...  Please make sure 'Port Check Test' is enabled on the phone! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will appear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*121# *#546368#*121# In case you cannot get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. Waiting for ADB connection.Be patient! Do NOT disconnect the phone! Unlocking Phone IMEI is correct.: 35654107407XXXX Unlocked. Restarting phone... Finished successfully. Finished at local time: [01.06.18 13:26:54] WorkID: 31597479 |
