Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #3781 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 136 | Printing phone history Repair IMEI 11/19/2019 7:49:44 AM Repair IMEI 11/19/2019 7:27:46 AM Repair IMEI 11/16/2019 11:37:57 AM Repair IMEI 11/16/2019 11:18:50 AM Repair IMEI 11/16/2019 11:17:22 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: XFA Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 17:03:00 KST 2019 PDA Version: A105FDDU3ASG2 [july 2019, rev2] Phone Version: A105FDDU3ASG2 [july 2019, rev2] CSC Version: A105FODM3ASG2 [july 2019, rev2] Product Code: INS HIDSw Version: A105FDDU3ASG2/A105FODM3ASG2/A105FDDU3ASG2/A105FDDU3ASG2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M77VNQ2F Imei: 35 Unique Number: CBJ004CC9940776 Connections: AT,MTP Battery Status: 3.89V (57%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.19.19 10:17:17] |
![]() | #3782 (permalink) |
Moderator ![]() Join Date: Nov 2009 Location: South Africa > Bangladesh Age: 40
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,064 | SM-A105F U3'' IMEI & patchcert Done ![]() Code: Chimera Mobile Phone Utility version: 22.97.1505 @ 2019-11-19 Printing phone history Repair IMEI 11/19/2019 7:52:52 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: XFA Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 17:03:00 KST 2019 PDA Version: A105FDDU3ASG2 [july 2019, rev2] Phone Version: A105FDDU3ASG2 [july 2019, rev2] CSC Version: A105FODM3ASG2 [july 2019, rev2] Product Code: INS HIDSw Version: A105FDDU3ASG2/A105FODM3ASG2/A105FDDU3ASG2/A105FDDU3ASG2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M77VNPAV Imei: 35 Unique Number: CBJ004CCE953676 Connections: AT,MTP Battery Status: 3.90V (53%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.19.19 13:44:15]
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
![]() | #3783 (permalink) |
Junior Member ![]() Join Date: Jun 2018
Member: 2847375 Status: Offline Thanks Meter: 3 | Does anyone know how to remove Knox from Galaxy S8 (G950U)? Online in the supported models it shows that it is possible through Chimera buit when I plug in the device, I don't see an option to do it. Thanks! ![]() |
![]() | #3784 (permalink) |
Junior Member Join Date: Nov 2019 Location: Barbados
Member: 2936771 Status: Offline Thanks Meter: 0 | At first, I was struggling to unlock a SM-G570M. I needed to downgrade modem. I was getting nowhere with it so I was about to give up on the software. But another SM-G570M came into my hands and I used Read Codes Online and was able to unlock the second SM-G570M. Will be working on the first one so I can have a success story with that. |
![]() | #3785 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 136 | Chimera Mobile Phone Utility version: 23.02.1046 @ 2019-11-20 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N950F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Oct 29 15:06:46 KST 2018 PDA Version: N950FXXS5CRJ6 [october 2018, rev6] Phone Version: N950FXXU5CRHA [august 2018, revA] CSC Version: N950FOVF5CRI3 [september 2018, rev3] Product Code: XFV HIDSw Version: N950FXXS5CRJ6/N950FOVF5CRI3/N950FXXU5CRHA/N950FXXS5CRJ6 Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58JB116KKZ Imei: 35 Unique Number: 988AD934344133533130 Connections: AT,MTP Battery Status: 3.77V (22%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-11-01 Data Encryption State: unsupported Preparing... Checking root access. The phone is rooted by: 2.82:SUPERSU An old patchcert detected on the phone. Suggestion: Install a new firmware then re-run the pathcert process. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.20.19 14:38:31] |
![]() | #3786 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 136 | Chimera Mobile Phone Utility version: 23.01.1310 @ 2019-11-20 Printing phone history Repair IMEI 11/19/2019 1:53:25 PM Repair IMEI 11/19/2019 11:03:41 AM Repair IMEI 11/19/2019 11:01:25 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Sales Code: XFA Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Oct 16 17:48:32 KST 2019 PDA Version: A205FXXU3ASJ2 [october 2019, rev2] Phone Version: A205FDDU3ASJ2 [october 2019, rev2] CSC Version: A205FODM3ASJ2 [october 2019, rev2] Product Code: INS HIDSw Version: A205FXXU3ASJ2/A205FODM3ASJ2/A205FDDU3ASJ2/A205FXXU3ASJ2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M44T0KEM Imei: 350098765432117 Unique Number: CBJ000066423236 Connections: AT,MTP Battery Status: 3.89V (52%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.20.19 12:52:15] |
![]() | #3787 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 702 ![]() | ![]() Quote:
Thanks To Chimera Team | |
![]() | #3789 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 136 | Chimera Mobile Phone Utility version: 23.07.0749 @ 2019-11-25 Printing phone history Root/Unroot 11/25/2019 7:49:51 AM Patch Certificate 11/16/2019 8:51:46 AM Root/Unroot 11/16/2019 8:43:24 AM Rmm Unlock 11/16/2019 8:39:11 AM Knoxguard Unlock 11/16/2019 8:36:16 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J701F Sales Code: XSG Country Code: UAE Timezone: Africa/Johannesburg Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Mon Dec 3 22:22:38 KST 2018 PDA Version: J701FXVU6BRL1 [december 2018, rev1] Phone Version: J701FXXU6BRJ2 [october 2018, rev2] CSC Version: J701FOJV6BRL1 [december 2018, rev1] Product Code: XSG HIDSw Version: J701FXVU6BRL1/J701FOJV6BRL1/J701FXXU6BRJ2/J701FXVU6BRL1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8J92B8BJT Imei: 350099887766556 Unique Number: CAJ00ADA7FE9A84 Connections: AT,MTP Battery Status: 4.12V (68%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-12-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: Chimera SU v1.0 Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.25.19 09:59:39] |
![]() | #3790 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 136 | Chimera Mobile Phone Utility version: 23.07.0749 @ 2019-11-26 Printing phone history Repair IMEI 11/26/2019 1:08:39 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 17:03:00 KST 2019 PDA Version: A105FDDU3ASG2 [july 2019, rev2] Phone Version: A105FDDU3ASG2 [july 2019, rev2] CSC Version: A105FOJM3ASG2 [july 2019, rev2] Product Code: XFV HIDSw Version: A105FDDU3ASG2/A105FOJM3ASG2/A105FDDU3ASG2/A105FDDU3ASG2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8M40R9S8F Imei: 350087654444457 Unique Number: CBJ006EB0428F36 Connections: AT,MTP Battery Status: 3.80V (23%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.26.19 16:09:46] |
![]() | #3791 (permalink) |
![]() | #3792 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2017 Location: Canada
Member: 2689153 Status: Offline Thanks Meter: 45 | SW Change 10/30/2019 8:30:33 PM SW Change 10/30/2019 6:05:01 PM SW Change 10/27/2019 11:10:50 PM SW Change 10/27/2019 10:59:23 PM Firmware update started Checking firmware presence... Firmware version: N9600ZHS3CSH2/N9600OWO3CSH1/N9600ZCS3CSH2/N9600ZHS3CSH2 Firmware version friendly name: Pie(Android 9) Checking firmware files... Extracting firmware... Unzipping firmware: BL_N9600ZHS3CSH2_CL16463908_QB25423666_REV00_user_ low_ship_MULTI_CERT.tar.md5. Unzipping firmware: AP_N9600ZHS3CSH2_CL16463908_QB25423666_REV00_user_ low_ship_MULTI_CERT_meta_OS9.tar.md5. Unzipping firmware: CP_N9600ZCS3CSH2_CP13592894_CL16463908_QB25423666_ REV00_user_low_ship_MULTI_CERT.tar.md5. Unzipping firmware: HOME_CSC_OMC_OWO_N9600OWO3CSH1_CL16594570_QB252183 64_REV00_user_low_ship_MULTI_CERT.tar.md5. Unzipping firmware: CSC_OMC_OWO_N9600OWO3CSH1_CL16594570_QB25218364_RE V00_user_low_ship_MULTI_CERT.tar.md5. Processing firmware... Waiting for download mode. Connecting. Valid PIT file can be found in the firmware: CROWNQLTE_CHN_HK_ODM450M_OMR80M.pit Use the Enable PIT Write option if you want to use it. Reading PIT from phone. Flashing vendor.img.ext4 Flashing system.img.ext4 Restarting phone. Successfully finished. Finished at local time: [11.01.19 11:46:15] WorkID: 77884772 |
![]() | #3793 (permalink) |
Member: 2689153 Status: Offline Thanks Meter: 45 | Unlock phone started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G550T Sales Code: TMB Country Code: USA Timezone: America/Costa_Rica Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Thu Mar 23 17:45:19 KST 2017 PDA Version: G550TUVU2AQC4 [march 2017, rev4] Phone Version: G550TUVU2AQC4 [march 2017, rev4] CSC Version: G550TTMB2AQC4 [march 2017, rev4] Product Code: XXXXXXXXXXXTMB HIDSw Version: G550TUVU2AQC4/G550TTMB2AQC4/G550TUVU2AQC4/G550TUVU2AQC4 Board Platform: EXYNOS3 Modem Platform: SHANNON308 Serial Number: RV8HA0EZXDB Imei: 35376xxxx Unique Number: CQN00850FD8C383 Connections: AT,MTP Battery Status: 3.86V (44%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-03-01 Data Encryption State: unencrypted Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Preparing secure image. Be patient! Do NOT disconnect the phone! Please unlock screen if closed. Attempt failed. Reading modem. Be patient! Do NOT disconnect the phone! It is necessary to restart the phone. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Successfully finished. Finished at local time: [09.19.19 16:28:15] WorkID: 73691828 |
![]() | #3794 (permalink) |
Member: 2689153 Status: Offline Thanks Meter: 45 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J700M Sales Code: ARO Country Code: Argentina Timezone: America/Costa_Rica Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Tue May 16 04:51:30 KST 2017 PDA Version: J700MUBS2BQEA [may 2017, revA] Phone Version: J700MUBS2BQB1 [february 2017, rev1] CSC Version: J700MUUB2BPJ1 [october 2016, rev1] Product Code: SM-J700MZKACHX HIDSw Version: J700MUBS2BQEA/J700MUUB2BPJ1/J700MUBS2BQB1/J700MUBS2BQEA Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: R28GA18TJKY Imei: 35196xxxx Unique Number: C00001A97A9D672 Connections: AT,MTP Battery Status: 3.80V (28%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-05-01 Data Encryption State: unencrypted Checking custom root image... Present. Rooting by custom image-based root method... Switching to download mode. Waiting for download mode. Connecting. Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling Knox. Be patient! Do NOT disconnect the phone! Knox disabled. Writing cert to phone... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Writing cert backup. Cert written to: DataFiles/Samsung/Cert/SM-J700M/Backup/backup_20190919_143813_SM-J700M_351966xxxxx1.cert Writing secure image. Restarting phone. Succeeded. Successfully finished. Finished at local time: [09.19.19 14:38:19] WorkID: 73683543 |
![]() | #3795 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 136 | Code: Chimera Mobile Phone Utility version: 23.07.0749 @ 2019-11-27 Printing phone history Patch Certificate 11/27/2019 10:05:35 AM Root/Unroot 11/27/2019 9:45:13 AM Patch Certificate 11/27/2019 9:44:29 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J111F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 5.1.1 [LMY47V] [SDK 22] Build Date: Wed Dec 28 13:38:04 KST 2016 PDA Version: J111FXWU0APLA [december 2016, revA] Phone Version: J111FXWU0API1 [september 2016, rev1] CSC Version: J111FOJW0APJ3 [october 2016, rev3] Product Code: SM-J111FZKAXFV HIDSw Version: J111FXWU0APLA/J111FOJW0APJ3/J111FXWU0API1/J111FXWU0APLA Board Platform: SC8830 Modem Platform: SC9830I Serial Number: R58HA1DXXDV Imei: 350056542432651 Unique Number: CFN00C61FD44693 Connections: AT,MTP Battery Status: 3.98V (62%) Network Type: GSM SIM Status: READY Warranty Bit: unknown Security Patch: 2016-10-01 Data Encryption State: unencrypted Patching certificate... Reading data. Be patient! Do NOT disconnect the phone! Writing data. Be patient! Do NOT disconnect the phone! Reminder! In case of new firmware, flashing the Patch Certificate process must be repeated! Succeeded. Successfully finished. Finished at local time: [11.27.19 12:38:46] |
