Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #3796 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1. Repair with out root 2. Patch cert with root 3. Root TWRP J7 Prime 3.2.3 & Magisk 19.3 by OTG or MTP comunication from Recovery Chimera Mobile Phone Utility version: 23.07.0749 @ 2019-11-26 Printing phone history Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610M Sales Code: TPA Country Code: PANAMA Timezone: America/Argentina/Buenos_Aires Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Fri Jul 5 07:53:00 KST 2019 PDA Version: G610MUBU6CSG1 [july 2019, rev1] Phone Version: G610MUBU6CSG1 [july 2019, rev1] CSC Version: G610MUUB6CSG1 [july 2019, rev1] Product Code: TPA HIDSw Version: G610MUBU6CSG1/G610MUUB6CSG1/G610MUBU6CSG1/G610MUBU6CSG1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R28JA01JJPL Imei: 355764086984384 Unique Number: CAJ03DDC6FEC794 Connections: AT,MTP Battery Status: 4.14V (74%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: unencrypted Repairing IMEI... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Calculating. Be patient! Do NOT disconnect the phone! Repaired IMEI: 355764096984382 Repaired IMEI2: 355764097284626 Writing secure image. If necessary, use the patch cert procedure. IMEI repaired. Successfully finished. Finished at local time: [11.26.19 02:01:08] WorkID: 80603351 Chimera Mobile Phone Utility version: 23.07.0749 @ 2019-11-26 Printing phone history Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610M Sales Code: TPA Country Code: PANAMA Timezone: America/Argentina/Buenos_Aires Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Fri Jul 5 07:53:00 KST 2019 PDA Version: G610MUBU6CSG1 [july 2019, rev1] Phone Version: G610MUBU6CSG1 [july 2019, rev1] CSC Version: G610MUUB6CSG1 [july 2019, rev1] Product Code: TPA HIDSw Version: G610MUBU6CSG1/G610MUUB6CSG1/G610MUBU6CSG1/G610MUBU6CSG1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R28JA01JJPL Imei: 355764096984382 Unique Number: CAJ03DDC6FEC794 Connections: AT,MTP Battery Status: 4.05V (74%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.4:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.26.19 02:03:15] WorkID: 80603383 |
![]() | #3797 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-11-30 Reset FRP lock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G532F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 6.0.1 [MMB29T] [SDK 23] Build Date: Mon Feb 11 15:57:19 KST 2019 PDA Version: G532FXWU1ASB1 [february 2019, rev1] Phone Version: G532FXXU1ARF3 [june 2018, rev3] CSC Version: G532FXFV1ASB1 [february 2019, rev1] Product Code: SM-G532FMDAXFV HIDSw Version: G532FXWU1ASB1/G532FXFV1ASB1/G532FXXU1ARF3/G532FXWU1ASB1 Board Platform: MT6737T Modem Platform: MT6737T Serial Number: RZ8KA03ZPBX Imei: 356914091491037 Unique Number: C8G0123B2C88345 Connections: AT,MTP Battery Status: 3.72V (7%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-08-01 Data Encryption State: unencrypted Processing... To avoid any problems caused by the combination boot, please install a stock firmware. To complete FRP Reset go to Backup and Reset and select Factory Data Reset. Succeeded. Successfully finished. Finished at local time: [11.30.19 14:12:27] |
![]() | #3798 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Code: Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-11-29 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Mar 15 20:56:03 KST 2019 PDA Version: A305FDDU1ASC4 [march 2019, rev4] Phone Version: A305FXXU1ASC2 [march 2019, rev2] CSC Version: A305FOJM1ASC4 [march 2019, rev4] Product Code: XFA HIDSw Version: A305FDDU1ASC4/A305FOJM1ASC4/A305FXXU1ASC2/A305FDDU1ASC4 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M51WNMJH Imei: 350076755411226 Unique Number: CCU009D4C48BA46 Connections: AT,MTP Battery Status: 4.30V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.29.19 10:58:32] |
![]() | #3799 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Code: Chimera Mobile Phone Utility version: 23.07.0749 @ 2019-11-25 Printing phone history Patch Certificate 11/24/2019 11:03:05 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Sales Code: XFA Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Nov 5 23:10:55 KST 2019 PDA Version: A505FDDS3ASK5 [november 2019, rev5] Phone Version: A505FXXS3ASK5 [november 2019, rev5] CSC Version: A505FODM3ASK5 [november 2019, rev5] Product Code: INS HIDSw Version: A505FDDS3ASK5/A505FODM3ASK5/A505FXXS3ASK5/A505FDDS3ASK5 Board Platform: EXYNOS5 Modem Platform: SHANNON337 Serial Number: R58M53CC0BE Imei: 35 Unique Number: CE0319338C0DE0C23F7E Connections: AT,MTP Battery Status: 3.82V (43%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.25.19 12:27:53] |
![]() | #3800 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Code: Chimera Mobile Phone Utility version: 23.09.1018 @ 2019-11-28 Printing phone history Patch Certificate 6/19/2019 12:32:39 PM Knoxguard Unlock 6/19/2019 12:29:53 PM Knoxguard Unlock 6/19/2019 12:10:32 PM Rmm Unlock 6/19/2019 12:07:28 PM Repair IMEI 6/19/2019 11:02:23 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jun 4 14:09:27 KST 2019 PDA Version: G960FXXU5CSF2 [june 2019, rev2] Phone Version: G960FXXU5CSF2 [june 2019, rev2] CSC Version: G960FOXM5CSF2 [june 2019, rev2] Product Code: XFA HIDSw Version: G960FXXU5CSF2/G960FOXM5CSF2/G960FXXU5CSF2/G960FXXU5CSF2 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58M42P1VXW Imei: 350098765434568 Unique Number: CE12182CC40D3611027E Connections: AT,MTP Battery Status: 3.80V (29%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 20.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.28.19 12:56:09] |
![]() | #3801 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-01 Printing phone history Patch Certificate 11/29/2019 8:57:51 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305F Sales Code: XFA Country Code: MALAYSIA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue May 28 10:46:14 KST 2019 PDA Version: A305FDDU2ASE5 [may 2019, rev5] Phone Version: A305FXXU2ASE5 [may 2019, rev5] CSC Version: A305FOLM2ASE5 [may 2019, rev5] Product Code: XME HIDSw Version: A305FDDU2ASE5/A305FOLM2ASE5/A305FXXU2ASE5/A305FDDU2ASE5 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M51WNMJH Imei: 350076755411226 Unique Number: CCU009D4C48BA46 Connections: AT,MTP Battery Status: 3.90V (55%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.01.19 11:00:57] |
![]() | #3802 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-01 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G361H Sales Code: SER Country Code: Russia Timezone: Africa/Johannesburg Android Version: 5.1.1 [LMY48B] [SDK 22] Build Date: Thu Jun 25 11:13:32 KST 2015 PDA Version: G361HXXU0AOFF [june 2015, revF] Phone Version: G361HXXU0AOFF [june 2015, revF] CSC Version: G361HOXE0AOFF [june 2015, revF] Board Platform: SC8830 Modem Platform: SC7730SE Serial Number: R51GA34CXDW Imei: 351955073650376 Battery Status: 4.03V (11%) Network Type: GSM SIM Status: ABSENT Knox Version: v00 Data Encryption State: unencrypted Checking IMEI... Preparing. Processing... Reading image #1 Storing image #1 Preparing image #1 Writing image #1 Reading image #2 Storing image #2 Preparing image #2 Writing image #2 Reading image #3 Storing image #3 Preparing image #3 Writing image #3 Reading image #4 Storing image #4 Preparing image #4 Writing image #4 Repaired IMEI: 350098765444443 Imei repaired. Successfully finished. Finished at local time: [12.01.19 10:05:36] |
![]() | #3803 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-01 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri May 31 17:03:12 KST 2019 PDA Version: A205FXXU2ASE8 [may 2019, rev8] Phone Version: A205FDDU2ASE7 [may 2019, rev7] CSC Version: A205FOJM2ASE8 [may 2019, rev8] Product Code: XFA HIDSw Version: A205FXXU2ASE8/A205FOJM2ASE8/A205FDDU2ASE7/A205FXXU2ASE8 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8M73H73PX Imei: 355670679019761 Unique Number: CBJ0078188E5066 Connections: AT,MTP Battery Status: 3.89V (57%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU An old patchcert detected on the phone. Suggestion: Install a new firmware then re-run the pathcert process. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.01.19 12:24:06] |
![]() | #3804 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-01 Printing phone history Knoxguard Unlock 12/1/2019 10:34:14 AM Knoxguard Unlock 12/1/2019 10:06:01 AM Repair IMEI 12/1/2019 10:04:34 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A260F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 8.1.0 [OPR6] [SDK 27] Build Date: Wed Mar 20 21:48:42 KST 2019 PDA Version: A260FXXU1ASCG [march 2019, revG] Phone Version: A260FJVU1ASCA [march 2019, revA] CSC Version: A260FOJM1ASCG [march 2019, revG] Product Code: XFA HIDSw Version: A260FXXU1ASCG/A260FOJM1ASCG/A260FJVU1ASCA/A260FXXU1ASCG Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8M416E2JX Imei: 350009876543239 Unique Number: C0001DFCEF00B36 Connections: AT,MTP Battery Status: 3.85V (26%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.01.19 12:40:58] |
![]() | #3805 (permalink) |
![]() | #3806 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-01 Printing phone history Patch Certificate 11/16/2019 1:24:42 PM Knoxguard Unlock 11/16/2019 1:20:41 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J600F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Apr 12 19:59:07 KST 2019 PDA Version: J600FXXU3BSD6 [april 2019, rev6] Phone Version: J600FXXU3BSD6 [april 2019, rev6] CSC Version: J600FOJM3BSD6 [april 2019, rev6] Product Code: XFA HIDSw Version: J600FXXU3BSD6/J600FOJM3BSD6/J600FXXU3BSD6/J600FXXU3BSD6 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RZ8K81G7RTK Imei: 350041215870999 Unique Number: CBJ00B3D1581E65 Connections: AT,MTP Battery Status: 4.29V (97%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.01.19 12:55:49] |
![]() | #3807 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 787 ![]() | Samsung S8 active SM-G892A unlock done Code: Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-11-30 Printing phone history Read Codes Online 2019-mm-30 13:55:20 Read codes started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G892A Sales Code: ATT Country Code: USA Timezone: Asia/Dubai Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Sat Jul 22 14:01:16 KST 2017 PDA Version: G892AUCU1AQG4 [july 2017, rev4] Phone Version: G892AUCU1AQG4 [july 2017, rev4] CSC Version: G892AATT1AQG4 [july 2017, rev4] Product Code: ATT HIDSw Version: G892AUCU1AQG4/G892AATT1AQG4/G892AUCU1AQG4/G892AUCU1AQG4 Board Platform: MSM8998 Modem Platform: MSM8998 Serial Number: R38J80H3GGB Imei: 358524081335371 Unique Number: xx Connections: AT,MTP Battery Status: 3.74V (14%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-07-01 Data Encryption State: encrypted Preparing... The phone will restart in upload mode, this is normal operation, do not worry! Switching to upload mode. Be patient! Do NOT disconnect the phone! Waiting for upload interface... Waiting for upload interface. Be patient! Do NOT disconnect the phone! Upload interface: SAMSUNG Mobile USB Modem (COM19) Reading data... Reading data is in progress. Be patient! Do NOT disconnect the phone! Communicating with the server... The phone can be unplugged now. Waiting for server response... This operation costed 59 credits. Freeze Code: 36807913 Network Lock: 59240285 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 Successfully finished. Finished at local time: [11.30.19 18:07:36] WorkID: 81088443 |
![]() | #3808 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: Noitacol Age: 36
Member: 2532428 Status: Offline Thanks Meter: 34 | HUAWEI DUA-L22 FRP RESET DONE ! Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-05 Printing phone history FRP Remove 05.12.2019 11:44:42 Removing factory reset protection... Collecting information about the device... Removing factory reset protection lock... It did not work. Removing factory reset protection lock... It did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... It did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... It did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Wiping device... Finished at local time: [12.05.19 17:29:32] WorkID: 81799120 |
![]() | #3809 (permalink) |
Junior Member ![]() Join Date: Oct 2017 Location: bangladesh
Member: 2765662 Status: Offline Thanks Meter: 3 | Chimera Mobile Phone Utility version: 23.18.1359 @ 2019-12-08 Printing phone history Knoxguard Unlock 12/8/2019 5:18:11 PM Knoxguard Unlock 12/8/2019 2:02:53 PM Rmm Unlock 12/8/2019 2:01:46 PM Patch Certificate 12/8/2019 1:51:18 PM Reboot 12/8/2019 1:32:23 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N960F Sales Code: BNG Country Code: Bangladesh Timezone: Asia/Dhaka Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 13:16:49 KST 2019 PDA Version: N960FXXU3CSF9 [june 2019, rev9] Phone Version: N960FXXU3ASF1 [june 2019, rev1] CSC Version: N960FOXM3CSF9 [june 2019, rev9] Product Code: BNG HIDSw Version: N960FXXU3CSF9/N960FOXM3CSF9/N960FXXU3ASF1/N960FXXU3CSF9 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: RF8KC0ZAVKJ Imei: 352453548454565 Unique Number: CE10182AAB54A04E3F7E Connections: AT,MTP Battery Status: 4.14V (88%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 3.14:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.08.19 23:30:51] WorkID: 82173736 |
![]() | #3810 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Chimera Mobile Phone Utility version: 23.18.1359 @ 2019-12-09 Printing phone history Repair IMEI 12/9/2019 8:46:48 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J111F Sales Code: XSP Country Code: SINGAPORE Timezone: Africa/Johannesburg Android Version: 5.1.1 [LMY47V] [SDK 22] Build Date: Sat Jan 30 22:27:46 KST 2016 PDA Version: J111FXXU0APAD [january 2016, revD] Phone Version: J111FXXU0APB2 [february 2016, rev2] CSC Version: J111FOLB0APA5 [january 2016, rev5] Product Code: SM-J111FZKAXFA HIDSw Version: J111FXXU0APAD/J111FOLB0APA5/J111FXXU0APB2/J111FXXU0APAD Board Platform: SC8830 Modem Platform: SC9830I Serial Number: RV8J60SRR4J Imei: 350098765433339 Unique Number: C8G01197040CC44 Connections: AT,MTP Battery Status: 3.91V (8%) Network Type: GSM SIM Status: READY Warranty Bit: unknown Security Patch: 2016-02-01 Data Encryption State: unencrypted Patching certificate... Reading data. Be patient! Do NOT disconnect the phone! Writing data. Be patient! Do NOT disconnect the phone! Reminder! In case of new firmware, flashing the Patch Certificate process must be repeated! Succeeded. Successfully finished. Finished at local time: [12.09.19 10:48:40] |
