10-31-2020, 15:16 | #3976 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | LG LM-G710N FRP reset like a piece of cake Chimera Mobile Phone Utility version: 26.46.1149 @ 2020-10-31 Removing factory reset protection... Removing frp lock... Successfully finished. Finished at local time: [10.31.20 14:44:54] WorkID: 113537084 |
The Following 2 Users Say Thank You to byteforce2016 For This Useful Post: |
11-12-2020, 12:18 | #3977 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A310F Screen Lock Remove without Data Loss Chimera Mobile Phone Utility version: 26.52.2310 @ 2020-11-12 Reset screen lock started Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image-based root method... Waiting for download mode. Connecting. SBL Info: Model: SM-A310F, Region: EUR, Provider: OPEN, PDA: A310FXXS3BQC5 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling Knox. Be patient! Do NOT disconnect the phone! Knox disabled. Resetting screenlock... Processing. Be patient! Do NOT disconnect the phone! Succeeded. Successfully finished. Finished at local time: [11.12.20 11:07:37] WorkID: 114996800 |
11-12-2020, 13:51 | #3978 (permalink) |
Freak Poster Join Date: Nov 2017 Location: midrand
Member: 2783412 Status: Offline Sonork: 1680285 Thanks Meter: 226 | Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: XFA Sales Code: XXV Country Code: VIETNAM Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jun 2 11:00:06 KST 2020 PDA Version: A505FDDS5BTF1 [june 2020, rev1] Phone Version: A505FXXU5BTE1 [may 2020, rev1] CSC Version: A505FOLM5BTE1 [may 2020, rev1] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: RZ8M806FCHZ Imei: 354070101024763 Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Use stock firmware. Finished at local time: [11.12.20 14:14:02] WorkID: 115032778 |
11-12-2020, 13:52 | #3979 (permalink) |
11-12-2020, 14:10 | #3980 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
The Following User Says Thank You to allumts For This Useful Post: |
11-23-2020, 11:53 | #3981 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | a202f repair done.. Chimera Mobile Phone Utility version: 26.65.1300 @ 2020-11-23 Printing phone history Patch Certificate 23.11.2020 10:49 Patch Certificate 23.11.2020 10:35 Repair IMEI 23.11.2020 10:33 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A202F Carrier ID: PHN Country Code: Germany Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Jan 2 12:47:34 KST 2020 PDA Version: A202FXXU3ASL4 [december 2019, rev4] Phone Version: A202FXXU3ASL3 [december 2019, rev3] CSC Version: A202FOVF3ASL4 [december 2019, rev4] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58N35V41GV Imei: 352866061398770 Imei2: 358903050033706 Battery Status: 4.00V (72%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-01-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.23.20 13:51:00] WorkID: 116267613 |
The Following User Says Thank You to canliyayin For This Useful Post: |
11-24-2020, 14:54 | #3982 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Huawei vns-al00 frp reset done Chimera Mobile Phone Utility version: 26.65.1300 @ 2020-11-24 Removing factory reset protection... Collecting information about the device... Removing factory reset protection lock... It did not work. Removing factory reset protection lock... It did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished at local time: [11.24.20 12:52:08] WorkID: 116401047 |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
11-26-2020, 10:44 | #3983 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Hello, Please use stock Kernel on the device! Stock Firmware. Also next time please post this to another topic. Thank you for the cooperation. Quote:
11-27-2020, 04:54 | #3984 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Gt-I8200N Unlocked Done Finished #114471119 Nov 7, 2020 Samsung Samsung Galaxy A20 Knoxguard Remove Finished #114468243 Nov 7, 2020 Samsung Samsung Galaxy A20 Repair IMEI Finished #114342974 Nov 6, 2020 Xiaomi Xiaomi Redmi Note 8 Get Info Finished #114014704 Nov 4, 2020 Huawei Huawei Honor 8X Exit Factory Mode Finished #114013702 Nov 4, 2020 Huawei Huawei Honor 8X Load Factory Fastboot Finished #113430746 Oct 30, 2020 Samsung Samsung Galaxy A10e Get Info Finished #113379623 Oct 30, 2020 LG LG K51 Network Factory Reset Finished #113379482 Oct 30, 2020 LG LG Q51 Network Factory Reset Error #113378569 Oct 30, 2020 LG LG K51 Reboot into normal mode Finished #113374538 Oct 30, 2020 LG LG K51 Reboot into normal mode Finished #112922388 Oct 27, 2020 Huawei Huawei P smart Pro / Y9s Exit Factory Mode Finished #112922268 Oct 27, 2020 Huawei Huawei P smart Pro / Y9s FRP Remove Finished #112921151 Oct 27, 2020 Huawei Huawei P smart Pro / Y9s Load Factory Fastboot Finished #112020366 Oct 20, 2020 Samsung Samsung Galaxy A30s Patch Certificate Finished #112020017 Oct 20, 2020 Samsung Samsung Galaxy A30s Patch Certificate Canceled #112019581 Oct 20, 2020 Samsung Samsung Galaxy A30s Repair IMEI Finished #112017956 Oct 20, 2020 Samsung Samsung Galaxy A30s Repair IMEI Error #112014205 Oct 20, 2020 Samsung Samsung Galaxy A30s Get Info Finished #111892676 Oct 19, 2020 Samsung Samsung Galaxy A30s Patch Certificate Finished #111892284 Oct 19, 2020 Samsung Samsung Galaxy A30s Repair IMEI Error #111891546 Oct 19, 2020 Samsung Samsung Galaxy A30s Repair IMEI Error #111890928 Oct 19, 2020 Generic Android Unknown Android Development Support Finished #110598465 Oct 9, 2020 Xiaomi Xiaomi Redmi 8A Remove FRP lock Error #109867433 Oct 3, 2020 Xiaomi Xiaomi Redmi Note 6 Pro Update Firmware Finished #109832745 Oct 2, 2020 Xiaomi Xiaomi Redmi Note 6 Pro Update Firmware Error #109832400 Oct 2, 2020 Xiaomi Xiaomi Redmi Note 6 Pro Update Firmware Error #109831747 Oct 2, 2020 Xiaomi Xiaomi Redmi Note 6 Pro Update Firmware Error #109515809 Sep 30, 2020 Samsung Samsung Galaxy Grand Prime VE Duos Reset FRP Lock Error #109511937 Sep 30, 2020 Samsung Samsung Galaxy Grand Prime VE Duos Reset FRP Lock Error #109298759 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Exit Factory Mode Finished #109298594 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Network Factory Reset Finished #109298393 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Load Factory Fastboot Finished #109296963 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Repair IMEI Finished #109290985 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Usb Firmware Update Error #109289725 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Network Factory Reset Finished #109289536 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Load Factory Fastboot Finished #109289339 Sep 28, 2020 Huawei Huawei P20 Lite Dual SIM Get Info Finished 123...10 INFORMATION Become a Reseller! Installation instructions Shipping Information Payment Information ChimeraTool Refund Policy Terms & Conditions, Privacy policy General Data Protection Regulation SUPPORT Our support team is ready to help you with any questions or comments you may have! The staff will answer incoming emails within 24 hours from Monday to Friday. [email protected] chimeratool (+44) 7441445060 It is available on working days: 09h - 17h (GMT). All rights reserved! © Chimera Tool — 2013-2020 Work log (116684501) Chimera Mobile Phone Utility version: 26.65.1300 @ 2020-11-26 Printing phone history Network Factory Reset 26-Nov-20 3:59 PM Network Factory Reset started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I8200N Country Code: UK & IRE Timezone: Africa/Lagos Android Version: 4.2.2 [JDQ39] [SDK 17] Build Date: Thu Jun 5 21:53:37 KST 2014 PDA Version: I8200NXXUANF1 [june 2014, rev1] Phone Version: I8200NXXUANE3 [may 2014, rev3] CSC Version: I8200NO2UANF1 [june 2014, rev1] Board Platform: MRVL Modem Platform: PXA986 Serial Number: RF1FB1865YK Imei: 355583067964524 Battery Status: 4.33V (92%) Network Type: GSM SIM Status: NETWORK_LOCKED The phone is rooted incorrectly. Please reinstall a complete stock firmware and try again! Doing Network Factory Reset Reading and storing secure image. Be patient! Do NOT disconnect the phone! Trying method 1... Preparing. Be patient! Do NOT disconnect the phone! Network configuration was set to factory default. Successfully finished. Finished at local time: [11.26.20 17:17:09] WorkID: 116684501 |
11-27-2020, 04:56 | #3985 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Gt-I8200N Unlocked Done Chimera Mobile Phone Utility version: 26.65.1300 @ 2020-11-26 Printing phone history Network Factory Reset 26-Nov-20 3:59 PM Network Factory Reset started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I8200N Country Code: UK & IRE Timezone: Africa/Lagos Android Version: 4.2.2 [JDQ39] [SDK 17] Build Date: Thu Jun 5 21:53:37 KST 2014 PDA Version: I8200NXXUANF1 [june 2014, rev1] Phone Version: I8200NXXUANE3 [may 2014, rev3] CSC Version: I8200NO2UANF1 [june 2014, rev1] Board Platform: MRVL Modem Platform: PXA986 Serial Number: RF1FB1865YK Imei: 355583067964524 Battery Status: 4.33V (92%) Network Type: GSM SIM Status: NETWORK_LOCKED The phone is rooted incorrectly. Please reinstall a complete stock firmware and try again! Doing Network Factory Reset Reading and storing secure image. Be patient! Do NOT disconnect the phone! Trying method 1... Preparing. Be patient! Do NOT disconnect the phone! Network configuration was set to factory default. Successfully finished. Finished at local time: [11.26.20 17:17:09] WorkID: 116684501 |
11-27-2020, 10:23 | #3986 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Hello, Thank you for the many posts. We saw that you used the tool very effectively. We hope that our software can serve you well in the upcoming tasks as well. Quote:
12-10-2020, 07:18 | #3989 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G950F imei Repair Chimera Mobile Phone Utility version: 26.85.1317 @ 2020-12-09 Printing phone history Repair IMEI 12/9/2020 11:43 AM Read Cert 12/9/2020 11:41 AM Get Info 12/9/2020 11:40 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Carrier ID: XEU Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Aug 7 15:55:11 KST 2020 PDA Version: G950FXXUADTG6 [july 2020, rev6] Phone Version: G950FXXUADTG4 [july 2020, rev4] CSC Version: G950FOXMADTG6 [july 2020, rev6] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8K80QZY8Z Imei: 3550640xxxxxxxx Battery Status: 3.69V (21%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.09.20 16:45:00] WorkID: 118135224 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
12-10-2020, 12:31 | #3990 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A520F August 2020 Securiety Patch Certificate Done Chimera Mobile Phone Utility version: 26.88.1044 @ 2020-12-10 Printing phone history Repair IMEI 12/10/2020 11:26 AM Read Cert 12/10/2020 11:24 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Jul 30 11:09:34 KST 2020 PDA Version: A520FXXSFCTG8 [july 2020, rev8] Phone Version: A520FXXSFCTG8 [july 2020, rev8] CSC Version: A520FOXAFCTH1 [august 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58K543KG8H Imei: 355813xxxxxxxxx Battery Status: 4.11V (82%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.10.20 16:28:39] WorkID: 118266565 |
