02-27-2021, 02:10 | #4051 (permalink) |
Junior Member Join Date: Jul 2018 Location: Peru
Member: 2852703 Status: Offline Thanks Meter: 5 | Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105M Carrier ID: PET Sales Code: TCE Country Code: MEXICO Timezone: America/Lima Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Jan 8 23:26:49 KST 2021 PDA Version: A105MUBS6BUA2 [january 2021, rev2] Phone Version: A105MUBS6BUA1 [january 2021, rev1] CSC Version: A105MOWA6BUA1 [january 2021, rev1] Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: R28M61NMEEV Imei: 359985042045582 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 359985042045582 Repaired imei: 356894658741554 Successfully finished. Finished at local time: [02.25.21 21:43:20] WorkID: 126226849 |
The Following User Says Thank You to YAMAZAKIX For This Useful Post: |
02-27-2021, 13:45 | #4052 (permalink) | |
Freak Poster Join Date: Jan 2017 Location: ALASKA
Member: 2678828 Status: Offline Thanks Meter: 231 | G975F_U8 Repair IMEI and Patch Cert Quote:
The Following User Says Thank You to we_fix_it For This Useful Post: |
03-05-2021, 16:35 | #4053 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Huawei P30 lite MAR-LX1a remove frp without testpoint ok Huawei P30 lite MAR-LX1a remove frp without testpoint ok |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
03-15-2021, 10:27 | #4054 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Zimbabwe
Member: 2524486 Status: Offline Thanks Meter: 112 | Samsung S9 Plus Patch Done Chimera Mobile Phone Utility version: 27.79.1138 @ 2021-03-12 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Carrier ID: XFA Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Harare Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Mar 30 14:19:26 KST 2020 PDA Version: G965FXXU8DTC5 [march 2020, rev5] Phone Version: G965FXXU8DTC5 [march 2020, rev5] CSC Version: G965FOXM8DTC5 [march 2020, rev5] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RF8K3204D2P Imei: 3xxxxxxxxxxxx5 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. Failed to write data. Checking boot image. Be patient! Do NOT disconnect the phone! Modifying boot image. Writing boot image. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.12.21 12:52:44] WorkID: 127745377 |
The Following User Says Thank You to julius84 For This Useful Post: |
03-16-2021, 11:42 | #4056 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,750 | reply Dear User, At here you can find the prices by License types: https://chimeratool.com/en/shop Please check them. Also if that is possible later on, please ask these questions under other Threads. Thank you. Best regards Sab |
03-17-2021, 08:07 | #4057 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G973F U8 Patch Cert successfuly Chimera Mobile Phone Utility version: 27.84.1435 @ 2021-03-17 Printing phone history Patch Certificate 17/03/2021 7:03 AM Reboot 17/03/2021 6:45 AM SW Change 17/03/2021 6:13 AM Patch Certificate 15/03/2021 11:19 AM Patch Certificate 15/03/2021 11:18 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jul 16 19:09:51 KST 2020 PDA Version: G973FXXU8CTG4 [july 2020, rev4] Phone Version: G973FXXU8CTG4 [july 2020, rev4] CSC Version: G973FOXM8CTG4 [july 2020, rev4] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8M21H1CMJ Imei: 35904908XXXXXXX Imei2: 35905008XXXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.17.21 12:05:29] WorkID: 128234355 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
03-18-2021, 02:15 | #4058 (permalink) |
Major Poster Join Date: Apr 2009 Location: New Zealand
Member: 1019740 Status: Offline Thanks Meter: 9 | Galaxy S10 SM-G973F IMEI Repair Success Chimera Mobile Phone Utility version: 27.84.1435 @ 2021-03-18 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: VNZ Sales Code: VNZ Country Code: New Zealand Timezone: Pacific/Auckland Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Sat Oct 26 15:35:43 KST 2019 PDA Version: G973FXXS3ASJG [october 2019, revG] Phone Version: G973FXXS3ASJA [october 2019, revA] CSC Version: G973FOXM3ASJD [october 2019, revD] Board Platform: EXYNOS5 Modem Platform: SHANNON5000 Serial Number: RF8MB0WJSSL Imei: 351912105417936 Battery Status: 3.70V (8%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Appropriate serial port is not available. 1. On the dial window, enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Trying to enable diagnostic mode. Be patient! Do NOT disconnect the phone! Succeeded. Trying on port SAMSUNG Mobile USB Serial Port (COM4) Diag mode available on port SAMSUNG Mobile USB Serial Port (COM4) The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 351912105417936 Repaired imei: 351912105990346 Successfully finished. Finished at local time: [03.18.21 14:11:41] WorkID: 128340004 |
The Following User Says Thank You to 1024kb For This Useful Post: |
03-25-2021, 03:03 | #4061 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | JNY-LX2 Nova 7i Huawei ID REMOVE Quote:
03-25-2021, 03:03 | #4062 (permalink) | |
03-25-2021, 10:30 | #4063 (permalink) |
Member: 1787203 Status: Online Thanks Meter: 23,750 | reply Dear User, From here you can do the download:https://chimeratool.com/en/download Just click on the Download Chimeratool Installer option. Best regards Sab Chimera team |
03-26-2021, 08:28 | #4064 (permalink) |
Member: 2524486 Status: Offline Thanks Meter: 112 | Htc One M9 Frp Reset Done Chimera Mobile Phone Utility version: 27.86.1322 @ 2021-03-25 FRP lock remove started Reading FRP information... Calculating FRP response... This may take a while. Be patient! Do NOT disconnect the phone! Writing FRP response... Rebooting the device... Successfully finished Finished at local time: [03.25.21 16:25:39] WorkID: 129087173 |
03-27-2021, 07:41 | #4065 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G955F Successful Repair imei & Patch cert Chimera Mobile Phone Utility version: 27.92.1510 @ 2021-03-27 Printing phone history Repair IMEI 27/03/2021 6:28 AM Repair IMEI 27/03/2021 6:26 AM Read Cert 27/03/2021 6:19 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Country Code: UK Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Oct 7 20:53:21 KST 2020 PDA Version: G955FXXSBDTJ1 [october 2020, rev1] Phone Version: G955FXXSBDTJ1 [october 2020, rev1] CSC Version: G955FH3GBDTJ1 [october 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8J82C81CM Imei: 357658015356151 Battery Status: 3.89V (82%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.27.21 11:29:52] WorkID: 129251077 |
