Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 01-15-2022, 13:44   #4201 (permalink)
Member: 2573102
Thanks Meter: 21
helloo!!
i need help from a moderator is anyone here!
Old 01-16-2022, 13:30   #4202 (permalink)
Member: 2353766
Thanks Meter: 73
Samsung Galaxy Note9 Imei Repair Done
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-N960F
Carrier ID: XFV
Sales Code: XFV
Country Code: South Africa
Timezone: Asia/Karachi
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Mon Nov 22 15:01:36 KST 2021
PDA Version: N960FXXU9FUK1 [november 2021, rev1]
Phone Version: N960FXXU9FUK1 [november 2021, rev1]
CSC Version: N960FOVF9FUJ2 [october 2021, rev2]
Board Platform: UNIVERSAL9810
Modem Platform: SHANNON360
Serial Number: RF8M1247Q2R
Imei: 356
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-11-01
Em Did: 20090DCE25528011
Repair imei...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Current imei: 356
Repaired imei: 869
Successfully finished.
Finished at local time: [01.16.22 17:27:07]
WorkID: 166176877
The Following User Says Thank You to WWRG For This Useful Post:
Old 01-16-2022, 13:32   #4203 (permalink)
Member: 2353766
Thanks Meter: 73
Samsung Galaxy Note9 Patch Cert Done
Model: SM-N960F
Carrier ID: XFV
Sales Code: XFV
Imei: 869
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Preparing...
Checking root access.
The phone is rooted by: 23.0:MAGISKSU
Reading data...
Patching certificate...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Finished at local time: [01.16.22 17:28:19]
WorkID: 166177034
Old 01-17-2022, 10:49   #4204 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,763
reply
Dear User,
Please let us know your issue in Private message so we can try to help you.
Best regards
Sab
Chimera team
Old 01-20-2022, 12:22   #4205 (permalink)
Member: 2353766
Thanks Meter: 73
J200H Flash Done!!!
Processing firmware...
Waiting for download mode.
Connecting.
Reading PIT from phone.
Flashing SPRDCP.img
Flashing SPRDDSP.img
Flashing boot.img
Flashing cache.img
Flashing hidden.img
Flashing recovery.img
Flashing sboot.bin
Flashing sboot2.bin
Flashing spl.img
Flashing system.img
Restarting phone.
Finished at local time: [01.20.22 16:09:06]
WorkID: 166648086
Old 01-20-2022, 13:55   #4206 (permalink)
Member: 2353766
Thanks Meter: 73
Huawei P9 lite Frp Done One Click
Chimera Mobile Phone Utility version: 30.88.1240 @ 2022-01-20
Removing factory reset protection...
Collecting information about the device...
Removing factory reset protection lock...
It did not work.
It did not work.
Checking if factory challenge needed...
Reading factory challenge...
Calculating response for the challenge...
This may take a while.
Sending response to the device...
Checking if the factory challenge-response succeed...
Wiping device...
Finished at local time: [01.20.22 17:53:44]
WorkID: 166659652
Old 01-20-2022, 15:33   #4207 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the positive feedback. Good work from you.
Best regards
Sab
Chimera team
It did not work.
It did not work.
Wiping device...
WorkID: 166659652
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 01-21-2022, 16:00   #4208 (permalink)
Member: 2353766
Thanks Meter: 73
Samsung A32 Downgrade Flash Done
Chimera Mobile Phone Utility version: 30.88.1240 @ 2022-01-21
Printing phone history
Repair IMEI
1/21/2022
11:21
AM
Firmware update started
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Android Version: 11 [RP1A.200720.012] [SDK 30]
Build Date: Wed Aug 4 15:56:28 +07 2021
PDA Version: A325FXXU1AUH2 [august 2021, rev2]
Phone Version: A325FXXU1AUH1 [august 2021, rev1]
CSC Version: A325FOJM1AUG5 [july 2021, rev5]
Board Platform: MT6768
Modem Platform: MT6765
Imei: 3522***********
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-08-01
Em Did: 2096FEDCDF4CF611
Switching to download mode.
Connecting.
Valid PIT file can be found in the firmware: A32_EUR_OPEN.pit
Use the Enable PIT Write option if you want to use it.
Flashing boot.img
Flashing dtbo.img
Flashing super.img
Flashing userdata.img
Flashing scp-verified.img
Flashing spmfw-verified.img
Flashing sspm-verified.img
Flashing tee-verified.img
Flashing tzar.img
Flashing vbmeta.img
Flashing vbmeta_system.img
Flashing gz-verified.img
Flashing misc.bin
Flashing md_udc.img
Flashing preloader.img
Flashing lk-verified.img
Flashing param.bin
Flashing up_param.bin
Flashing uh.bin
Flashing efuse.img
Flashing vbmeta.img
Flashing md1img.img
Flashing cache.img
Flashing omr.img
Flashing prism.img
Flashing optics.img
Restarting phone.
Finished at local time: [01.21.22 19:38:31]
WorkID: 166781399
Old 01-21-2022, 16:03   #4209 (permalink)
Member: 2353766
Thanks Meter: 73
Samsung A32 Imei / Patch Done Finally
Patch Certificate
1/21/2022
2:44
PM
SW Change
1/21/2022
2:29
PM
Repair IMEI
1/21/2022
11:21
AM
Repair started
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Build Date: Tue Jun 15 10:40:11 KST 2021
PDA Version: A325FXXU1AUF2 [june 2021, rev2]
Phone Version: A325FXXU1AUF2 [june 2021, rev2]
CSC Version: A325FOJM1AUF2 [june 2021, rev2]
Product Code: XFV
HIDSw Version: A325FXXU1AUF2/A325FOJM1AUF2/A325FXXU1AUF2/A325FXXU1AUF2
Serial Number: RZ8R80S8CQX
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-05-01
Repair imei...
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Repaired imei: 3588***********
Finished at local time: [01.21.22 19:47:09]
WorkID: 166783096
Patch certificate started
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Product Code: XFV
Imei: 3588***************
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Em Did: 2096FE***********
Patch cert...
Finished at local time: [01.21.22 19:48:47]
WorkID: 166783429
Old 01-21-2022, 16:03   #4210 (permalink)
Member: 2353766
Thanks Meter: 73
Patch Certificate
1/21/2022
2:44
PM
SW Change
1/21/2022
2:29
PM
Repair IMEI
1/21/2022
11:21
AM
Repair started
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Product Code: XFV
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Repair imei...
Restarting phone.
WorkID: 166783096
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Product Code: XFV
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Patch cert...
WorkID: 166783429
Old 01-21-2022, 17:06   #4211 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the report, really good job from you!
Best regards
Sab
Chimera team
Patch Certificate
1/21/2022
2:44
PM
SW Change
1/21/2022
2:29
PM
Repair IMEI
1/21/2022
11:21
AM
Repair started
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Product Code: XFV
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Repair imei...
Restarting phone.
WorkID: 166783096
Model: SM-A325F
Carrier ID: XFA
Sales Code: XFV
Product Code: XFV
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Patch cert...
WorkID: 166783429
Old 01-29-2022, 17:27   #4212 (permalink)
Member: 2230678
Thanks Meter: 4
Mi Note 8 pro patch imei
Done Mi Note 8 pro Patch imei
Old 01-31-2022, 11:57   #4213 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the post, please share the log as well
Best regards
Sab
Chimera team
Old 02-05-2022, 12:17   #4214 (permalink)
Member: 2353766
Thanks Meter: 73
Samsung A31 A315F Repair Imei and Patch Done ... NO ROOT
Chimera Mobile Phone Utility version: 31.07.1255 @ 2022-02-05
Repair started
Model: SM-A315F
Carrier ID: XSG
Sales Code: PAK
Country Code: PAKISTAN
Build Date: Fri Oct 2 12:25:56 KST 2020
PDA Version: A315FXXS1ATJ1 [october 2020, rev1]
Phone Version: A315FXXS1ATJ1 [october 2020, rev1]
CSC Version: A315FOJM1A*** [august 2020, rev3]
Modem Platform: MT6768
Serial Number: RF8N
Imei: 3
Imei2: 3
Battery Status: 4.02V (70%)
Network Type: GSM
SIM Status: ABSENT,LOADED
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2020-10-01
Em Did: ACDA7738D229
Repair imei...
Restarting phone.
Repaired imei: 3
Repaired imei2: 3
Finished at local time: [02.05.22 16:10:09]
WorkID: 168449690
Repair IMEI
2/5/2022
11:08
AM
Model: SM-A315F
Carrier ID: XSG
Sales Code: PAK
Serial Number: RF8N6
Imei: 3
Imei2: 3
Network Type: GSM
Knox Version: v30
Warranty Bit: 0
Em Did: ACDA773
Patch cert...
Finished at local time: [02.05.22 16:11:08]
WorkID: 168449873
Old 02-07-2022, 11:34   #4215 (permalink)
Member: 1787203
reply
Dear WWRG,
Thank you for the report, really good work from you.
Best regards
Sab
Chimera team
Repair started
Model: SM-A315F
Carrier ID: XSG
Sales Code: PAK
Serial Number: RF8N
Imei: 3
Imei2: 3
Network Type: GSM
Knox Version: v30
Warranty Bit: 0
Repair imei...
Restarting phone.
Repaired imei: 3
Repaired imei2: 3
WorkID: 168449690
Repair IMEI
2/5/2022
11:08
AM
Model: SM-A315F
Carrier ID: XSG
Sales Code: PAK
Imei: 3
Imei2: 3
Network Type: GSM
Knox Version: v30
Warranty Bit: 0
Em Did: ACDA773
Patch cert...
WorkID: 168449873
Page generated in 0.31370 seconds with 9 queries
