04-22-2022, 18:20 | #4264 (permalink) |
Insane Poster Join Date: May 2021 Location: Pakistan. Rajanpur
Member: 2989274 Status: Offline Thanks Meter: 20 | a107f u7 without root done Chimera Mobile Phone Utility version: 31.77.2201 @ 2022-04-19 Printing phone history Repair IMEI 19/04/2022 12:46 PM Repair IMEI 19/04/2022 12:45 PM Get Info 19/04/2022 12:40 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A107F Carrier ID: PAK Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed Dec 2 18:20:04 KST 2020 PDA Version: A107FXXU7BTL1 [december 2020, rev1] Phone Version: A107FXXU7BTK3 [november 2020, rev3] CSC Version: A107FOJM7BTL1 [december 2020, rev1] Board Platform: MT6765 Modem Platform: MT6762 Serial Number: R9Axxxxxxx Imei: 3556xxxxxxxxxxx Imei2: 35568xxxxxxxxxx Battery Status: 3.88V (29%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v00 Security Patch: 2020-12-01 Em Did: E71CFFCE3329 Repair imei... Operation in progress. Be patient! Do NOT disconnect the phone! Repaired imei: 353420xxxxxxxx Repaired imei2: 35342xxxxxxxxx Successfully finished. Finished at local time: [04.19.22 17:54:40] WorkID: 177069420 |
The Following User Says Thank You to Bismillah. For This Useful Post: |
04-25-2022, 06:33 | #4265 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Sabia >Gizan>KSA
Member: 978854 Status: Offline Thanks Meter: 32 | Nokia 6300(4G) TA-1287 Bricked phone repair successfully Nokia 6300(4G) TA-1287 phone condition (I received phone after first display of KaiOS shows recovery for 2/3 seconds and restart again to recovery) For EDL connectivity plug usb while pressing "*" and "#" Got an other Working same phone Connected phone Using EDL(For EDL connectivity plug usb while pressing "*" and "#" ) Software will detect as "Unknown Qualcomm">Select "Generic Qualcomm" Now it will show supported Options. For Backup From "Store/Restore Backup" tab >Selective Bckup>Reconnect Phone in EDL when software ask> Select partitions to backup press ok "For Restore" From "Store/Restore Backup" tab > Restore>Reconnect Phone in EDL when software ask> Select partitions to Restore press ok In my case after full flash with complete backed up file (Restored Clibration data as well) After Restore complete I got my phone Alive now. Note For Hard reset Power on phone While Pressed "*" button and follow on screen Recovery menu Thanks Chimera Team. Last edited by Waseem-y; 04-25-2022 at 06:39. Reason: Added some info |
04-25-2022, 20:14 | #4266 (permalink) |
Crazy Poster Join Date: Mar 2015 Location: iran
Member: 2365404 Status: Offline Thanks Meter: 9 | Chimera Mobile Phone Utility version: 31.85.1335 @ 2022-04-25 Printing phone history Repair IMEI 4/25/2022 6:59 PM Repair IMEI 4/25/2022 5:49 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J400F Carrier ID: XSG Sales Code: AFG Country Code: Afghanistan Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Oct 18 19:17:14 KST 2021 PDA Version: J400FXXU9CUJ3 [october 2021, rev3] Phone Version: J400FXXU9CUJ1 [october 2021, rev1] CSC Version: J400FOJM9CUJ3 [october 2021, rev3] Board Platform: UNIVERSAL7570 Modem Platform: SHANNON305 Serial Number: RZ8K92M491B Imei: 35875006****** Imei2: 3587500******* Network Type: GSM SIM Status: LOADED,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-09-01 Em Did: 05554E77BDB4 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [04.25.22 23:33:19] WorkID: 177841918 |
04-26-2022, 09:16 | #4267 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,720 | reply Dear MJS001, Thank you for the report! Good work from you. Best regards Sab Chimera team Quote:
05-18-2022, 14:57 | #4268 (permalink) |
Member: 2989274 Status: Offline Thanks Meter: 20 | a125f u2 null imei repair Chimera Mobile Phone Utility version: 32.05.1009 @ 2022-05-18 Printing phone history Repair IMEI 5/8/2022 7:29 PM Patch Certificate 5/8/2022 7:25 PM Repair IMEI 5/8/2022 7:21 PM Repair started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A125F Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Wed Jan 5 16:01:00 +07 2022 PDA Version: A125FXXS2BVA3 [january 2022, rev3] Phone Version: A125FXXS2BVA3 [january 2022, rev3] CSC Version: A125FOJM2BVA3 [january 2022, rev3] Board Platform: MT6765 Modem Platform: MT6765 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-01-01 Em Did: 942C75ACD0EB Repair imei... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Operation in progress. Be patient! Do NOT disconnect the phone! Repaired imei: 3507xxxxxxxxxxxx Repaired imei2: 356xxxxxxxxxxxxx Successfully finished. Finished at local time: [05.18.22 14:38:00] WorkID: 180599888 |
05-19-2022, 09:30 | #4269 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,720 | reply Dear Bismillah, Thank you for the feedback! Good work from you. If you have more jobs to share, please do it. We welcome failed works as well as in those cases we can try to fix them. Best regards Sab Chimera team Quote:
05-19-2022, 10:20 | #4270 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | Samsung J700Tb 7.1.1 U3 imei Repair one Click Chimera Mobile Phone Utility version: 32.05.1009 @ 2022-05-19 Printing phone history Repair IMEI 5/1/2022 11:41 AM Network Factory Reset 2/28/2022 9:00 AM Read Codes 2/28/2022 9:00 AM Network Factory Reset 2/28/2022 8:45 AM Network Factory Reset 2/28/2022 8:38 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J700T Sales Code: TMB Country Code: USA Timezone: Asia/Karachi Android Version: 7.1.1 [NMF26X] [SDK 25] Build Date: Tue Nov 7 18:15:26 KST 2017 PDA Version: J700TUVU3BQK3 [november 2017, rev3] Phone Version: J700TUVU3BQK3 [november 2017, rev3] CSC Version: J700TTMB3BQK3 [november 2017, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: R58H710J5HR Imei: 350894401326659 Battery Status: 4.00V (67%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-08-01 Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image-based root method... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-J700T, Region: USA, Provider: TMO, PDA: J700TUVU3BQK3 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Repairing IMEI... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! It is necessary to restart the phone. Be patient! Do NOT disconnect the phone! Restarting phone Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Writing secure image. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. If necessary, use the patch cert procedure. IMEI repaired. Successfully finished. Finished at local time: [05.19.22 14:18:36] WorkID: 180740576 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
05-19-2022, 13:44 | #4271 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,720 | reply Dear Qasir_amz, Thank you for the positive feedback! Great work from you. We welcome more works Best regards Sab Chimera team Quote:
05-21-2022, 08:45 | #4272 (permalink) |
Insane Poster Join Date: May 2013
Member: 1941684 Status: Offline Thanks Meter: 22 | Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935S Sales Code: XXV Country Code: VIETNAM Timezone: Africa/Bamako Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Apr 9 21:30:46 KST 2020 PDA Version: G935SKSU3ETD2 [april 2020, rev2] Phone Version: G935SKSU3ETJ1 [october 2020, rev1] CSC Version: G935FOLB4ESAH [january 2019, revH] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R39H80EJ98 Imei: 35 Imei2: 35 Battery Status: 4.18V (100%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Preparing... Checking root access. The phone is rooted by: 3.22:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.21.22 07:36:21] WorkID: 181004437 |
05-21-2022, 08:46 | #4273 (permalink) |
05-21-2022, 15:35 | #4274 (permalink) |
Member: 2989274 Status: Offline Thanks Meter: 20 | A325f u done with chimera king Chimera Mobile Phone Utility version: 32.13.1420 @ 2022-05-21 Printing phone history Get Info 5/21/2022 2:27 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A325F Carrier ID: XSG Sales Code: THL Country Code: THAILAND Timezone: Asia/Karachi Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Mon Oct 18 13:18:40 KST 2021 PDA Version: A325FXXU2AUJ4 [october 2021, rev4] Phone Version: A325FXXU2AUJ4 [october 2021, rev4] CSC Version: A325FOLM2AUJ3 [october 2021, rev3] Product Code: THL HIDSw Version: A325FXXU2AUJ4/A325FOLM2AUJ3/A325FXXU2AUJ4/A325FXXU2AUJ4 Board Platform: MT6768 Modem Platform: MT6765 Serial Number: R58xxxxxxxx Imei: 350854163332014 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,UNKNOWN Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 20834D837CA8C711 Repair imei... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Operation in progress. Be patient! Do NOT disconnect the phone! Repaired imei: 355xxxxxxxxxxxxx Repaired imei2: 3578xxxxxxxxxxxx Modifications might be lost with a factory reset! Successfully finished. Finished at local time: [05.21.22 19:32:08] WorkID: 181058553 |
05-23-2022, 10:46 | #4275 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,720 | reply Dear Bismillah, Thank you for the feedback. Best regards Sab Chimera team Quote:
