Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #4396 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | J701F FRP one Click Printing phone history Device Info 4/17/2022 8:23 AM Device Info 8/20/2019 6:51 AM Reset FRP lock started Resetting FRP... Operation in progress. Be patient! Do NOT disconnect the phone! Model: SM-J701F SW Version: J701FXXU3ARB1/J701FOJV3ARB1/J701FXXU3ARA3/J701FXXU3ARB1 Serial: R28K10WS7HM IMEI: 35XXXXXXXXXXXXX Product Code: EGY Unique Number: CAJ00CB575AFEC4 Phone does not respond Restart the phone, then try again Please 'Allow USB debugging' in the popup window Waiting for ADB device... Resetting FRP... To complete resetting FRP, go to 'Settings/General management/Reset' then select 'Factory data reset' Restarting phone Successfully finished. Finished at local time: [11.02.22 15:13:33] WorkID: 201419441 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
![]() | #4397 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 22,870 | reply Dear Qasir, Thank you for the feedback! Good job from you. Best regards Sab Chimera team Quote:
![]() | #4398 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | A107F u8 imei repair done Chimera Mobile Phone Utility version: 33.81.1134 @ 2022-11-03 Printing phone history Repair IMEI 11/3/2022 1:21 PM Repair IMEI 11/3/2022 12:39 PM Repair IMEI 11/3/2022 12:37 PM Repair IMEI 11/3/2022 12:10 PM Repair IMEI 11/3/2022 12:10 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A107F Carrier ID: XSG Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Mar 9 10:31:35 KST 2021 PDA Version: A107FXXS8BUC1 [march 2021, rev1] Phone Version: A107FXXS8BUC1 [march 2021, rev1] CSC Version: A107FOJM8BUC1 [march 2021, rev1] Board Platform: MT6765 Modem Platform: MT6762 Serial Number: R9WMA0FZZ4J Imei: 35XXXXXXXXXXXX Imei2: 35XXXXXXXXXXXX Battery Status: 4.20V (99%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v00 Security Patch: 2021-03-01 Em Did: 0C964AF3F248 Patch cert... Operation in progress. Be patient! Do NOT disconnect the phone! Please restart the phone manually using the power button! Successfully finished. Finished at local time: [11.03.22 18:23:02] WorkID: 201565854 |
![]() | #4399 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | A125F frp Chimera Mobile Phone Utility version: 33.74.1311 @ 2022-11-03 Remove FRP lock Selected method: Soft-brick method Rebooting phone to normal mode ADB interface detected. Switching to download mode. Waiting for download mode. Change to bootrom mode bootrom interface detected. Initializing... Removing factory reset protection... Waiting for the phone to restart... Successfully finished. Finished at local time: [11.03.22 15:27:40] WorkID: 201542244 |
![]() | #4400 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | G950F patch done Chimera Mobile Phone Utility version: 33.74.1311 @ 2022-11-03 Printing phone history Repair IMEI 11/3/2022 12:33 PM Reboot 11/3/2022 11:58 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Carrier ID: XEU Sales Code: XEU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Apr 6 19:15:03 KST 2021 PDA Version: G950FXXUCDUD1 [april 2021, rev1] Phone Version: G950FXXUCDUD1 [april 2021, rev1] CSC Version: G950FOXMCDUD1 [april 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J463QS8E Imei: 359xxxxxxxxxxxxx Battery Status: 3.79V (54%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 000ECEC95022 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.03.22 17:35:03] WorkID: 201559270 |
![]() | #4401 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,870 | reply Dear Qasir, Thank you for the report. Good work from you. Best regards Sab Chimera team Quote:
![]() | #4402 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | A10s successful patch Chimera Mobile Phone Utility version: 33.81.1134 @ 2022-11-06 Printing phone history Patch Certificate 11/6/2022 7:34 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A107F Carrier ID: XSG Sales Code: AFR Country Code: Kenya Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Mar 9 10:31:35 KST 2021 PDA Version: A107FXXS8BUC1 [march 2021, rev1] Phone Version: A107FXXS8BUC1 [march 2021, rev1] CSC Version: A107FOJM8BUC1 [march 2021, rev1] Board Platform: MT6765 Modem Platform: MT6762 Serial Number: R9AN60AV7AJ Imei: 3564XXXXXXXXXX Imei2: 35641XXXXXXXXX Battery Status: 3.81V (17%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v00 Security Patch: 2021-03-01 Em Did: 2453368C3438 Patch cert... Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Operation in progress. Be patient! Do NOT disconnect the phone! Please restart the phone manually using the power button! Successfully finished. Finished at local time: [11.06.22 15:14:30] WorkID: 201893171 |
![]() | #4403 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,870 | reply Dear Qasir, Thank you for the valuable report. Good work from you once again! Best regards Sab Chimera team Quote:
![]() | #4404 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | G960f last binary cert patch Chimera Mobile Phone Utility version: 33.81.1134 @ 2022-11-08 Printing phone history Repair IMEI 11/8/2022 11:19 AM Reboot 11/8/2022 10:33 AM Reboot 11/6/2022 10:18 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Carrier ID: OMN Sales Code: VD2 Country Code: Germany Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Oct 19 11:22:58 KST 2021 PDA Version: G960FXXSHFUJ2 [october 2021, rev2] Phone Version: G960FXXSHFUJ2 [october 2021, rev2] CSC Version: G960FOVFHFUJ1 [october 2021, rev1] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: R58K64KMQJZ Imei: 3537XXXXXXXXXX Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 200B778DAF980011 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.08.22 16:24:31] WorkID: 202123850 |
![]() | #4405 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,870 | reply Dear Qasir, Thank you! We do not received work with that device for a while now. Best regards Sab Chimera team Quote:
![]() | #4406 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | G930F patchhhhhhhhhhhhhhhhhhhhhhhhh Chimera Mobile Phone Utility version: 33.81.1134 @ 2022-11-09 Printing phone history Reboot 11/9/2022 6:54 AM Patch Certificate 10/17/2022 10:42 AM Patch Certificate 10/17/2022 10:41 AM Repair IMEI 10/17/2022 10:40 AM Reboot 10/17/2022 9:58 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Sales Code: ZTA Country Code: Brazil Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed Nov 18 23:49:26 KST 2020 PDA Version: G930FXXS8ETKF [november 2020, revF] Phone Version: G930FXXS8ETCE [march 2020, revE] CSC Version: G930FZTA8ETCA [march 2020, revA] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58HA6A4Q1Y Imei: 35XXXXXXXXXXXXX Battery Status: 4.15V (66%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.09.22 12:06:41] WorkID: 202226296 |
![]() | #4407 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 380 | huawei p30 pro frp done. Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.09 V Phone model: VOG-L29 Build number: VOG-L29 12.0.0.134(C636E1R1P1) Vendor/Country: hw/spcseas System version: Skipped Android version: 10 Base version: VOG-LGRP2-OVS 102.0.0.134 Custom version: VOG-L29-CUST 102.0.0.1(C636) Preload version: VOG-L29-PRELOAD 102.0.0.1(C636R1) Huawei-Over-the-Air info: C_version: C636 D_version: D000 PLMN: 52004 BoardID: 8542 DeviceName: VOG-L29 Done Chimera Mobile Phone Utility version: 33.81.1134 @ 2022-11-09 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished We counld't identify the device, please select manually, if present! Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [11.09.22 18:10:04] WorkID: 202253259 |
The Following User Says Thank You to wsmobile For This Useful Post: |
![]() | #4408 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,870 | reply Dear User, Thank you for the positive feedback! That is a pretty good job from you. Best regards Sab Chimera team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
![]() | #4409 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | G965F Repair imei Chimera Mobile Phone Utility version: 33.89.1458 @ 2022-11-12 Printing phone history Patch Certificate 10/12/2022 8:24 AM Repair IMEI 10/12/2022 8:22 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Carrier ID: XEU Sales Code: XEU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Feb 24 10:14:52 KST 2022 PDA Version: G965FXXUHFVB4 [february 2022, rev4] Phone Version: G965FXXUHFVB4 [february 2022, rev4] CSC Version: G965FOXMHFVB4 [february 2022, rev4] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RF8K61GF7HD Imei: 359435304054260 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-03-01 Em Did: 200AB50D5EFE0011 Repair imei... Operation in progress. Be patient! Do NOT disconnect the phone! Current imei: 000000000000000 Repaired imei: 3594XXXXXXXXXX Successfully finished. Finished at local time: [11.12.22 12:20:09] WorkID: 202591019 |
![]() | #4410 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 388 | G965F Repair imei & Patch certificate Success Chimera Mobile Phone Utility version: 33.89.1458 @ 2022-11-12 Printing phone history Repair IMEI 11/12/2022 9:50 AM Patch Certificate 9/18/2022 11:46 AM Repair IMEI 9/18/2022 11:44 AM Reboot 9/18/2022 11:32 AM Get Info 9/18/2022 11:09 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Carrier ID: EVR Sales Code: EVR Country Code: UK Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jul 21 10:31:07 KST 2022 PDA Version: G965FXXUHFVG4 [july 2022, rev4] Phone Version: G965FXXUHFVB4 [february 2022, rev4] CSC Version: G965FOBEHFVA1 [january 2022, rev1] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RF8K609KR8J Imei: 356XXXXXXXXXXXX Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-03-01 Em Did: 20080C8DA4440011 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... Operation in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.12.22 14:52:59] WorkID: 202606639 |
