10-12-2021, 22:49 | #1 (permalink) |
Insane Poster Join Date: Jul 2018 Location: Tunis
Member: 2848399 Status: Offline Thanks Meter: 41 | ELE-L29 KIRIN980 FRP + Imei Repair Android 11.0.0.159 Harmony TP not working for hcu and octoplus only chimera FRP: Removing Huawei account Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.12.21 18:01:18] WorkID: 154054175 you can use any cert kirin710 for devices kirin980 its working fine Write Cert: Chimera Mobile Phone Utility version: 29.90.1720 @ 2021-10-12 Printing phone history Get Info 12/10/2021 5:39 PM Huawei Id & Frp Remove 12/10/2021 4:59 PM Enter Factory Mode 10/10/2021 10:29 PM Get Info 10/10/2021 10:28 PM Huawei Id & Frp Remove 10/10/2021 10:26 PM Writing certificate... Validating certificate files Validating C:/Users/AnIs/Desktop/SNE-LX3 KIRIN710 Colombia/SNE-LX3_Group_1_Slot_1_869325035932335.imei. Validating C:/Users/AnIs/Desktop/SNE-LX3 KIRIN710 Colombia/SNE-LX3_Group_1_Slot_1_869823030758986.imei. Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The OEMINFO PSID seems to be invalid. Uploading certificate file from C:/Users/xxx/Desktop/KIRIN710 /Group_1_Slot_1_xxxxxxxxxxxxxx.imei Uploading certificate file from C:/Users/xxx/Desktop/KIRIN710 /Group_2_Slot_2_xxxxxxxxxxxxxx.imei Finished at local time: [10.12.21 18:44:49] WorkID: 154060034 |
The Following User Says Thank You to Anis07 For This Useful Post: |
10-13-2021, 10:10 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, Thank you for this detailed report about your work. Hopefully, many users can use this guide. Best regards Sab Chimera team Quote:
10-19-2021, 07:01 | #3 (permalink) | |
Junior Member Join Date: Oct 2016
Member: 2638870 Status: Offline Thanks Meter: 1 | Quote:
10-19-2021, 10:10 | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, After the Uploading "part", you have to disconnect the Harmony cable from the Computer. NOT from the phone. Then connect it back. That should do the trick for you. If not, please post the WORK ID from the problematic job, so we can have a better look on the issue. Best regards Sab Chimera team |
11-22-2021, 07:41 | #5 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
getting USB device not recognizeeeee. here is WorkID: 159090297 | |
11-22-2021, 11:17 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, Please reinstall the Chimera Tool drivers: Huawei driver specifically. Then do the process once again. MAke sure that you disconnect the cable from the computer, and not from the Phone end. And then reconnect it. Best regards Sab Chimera Team |
11-23-2021, 11:07 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Okay, that is great. Then please reconnect the cable to the computer when the tool requires it. Do not disconnect the phone from the cable, just the cable from the pc. |
