Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Narnia Age: 44
Member: 236667 Status: Offline Thanks Meter: 11 | EVR-AL00 to EVR-L29 SHA256RSA error code: Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-01 Printing phone history Get Info 9/1/2023 1:13 PM Modify Oeminfo 8/31/2023 12:38 PM Modify Oeminfo 8/31/2023 11:59 AM Modify Oeminfo 8/30/2023 2:39 PM Modify Oeminfo 8/30/2023 2:35 PM Gathering information... Reading identifiers... IMEI: 865129045007458 IMEI1: 865129045015659 MEID: A00000A7C9E16E SN: LKN5T19409001633 Information Wifi MAC: c4:06:83:48:0e:77 SIM card 1 state: ABSENT SIM card 2 state: ABSENT Model name: EVR-AL00 Manufacturer: HUAWEI Device code: HWEVR Product name: EVR-AL00 ABI: arm64-v8a Multisim Config: dsds Language: zh Region: CN Android version: 10 Build id: HUAWEIEVR-AL00 Build display id: EVR-AL00 10.1.0.163(C00E160R2P8) Build description: EVR-AL00-user 102.0.0 HUAWEIEVR-AL00 291-CHN-LGRP1 release-keys Build date: Wed Jan 18 18:38:37 CST 2023 Build UTC: 1595391092 Build characteristics: default Build product: EVR Build fingerprint: HUAWEI/EVR-AL00/HWEVR:10/HUAWEIEVR-AL00/10.1.0.163C00:user/release-keys Build security patch: 2020-07-01 Build SDK version: 29 Boot build date (UTC): 1595390772 Boot verified boot state: green Boot build fingerprint: kirin980/kirin980/kirin980:10/QP1A.190711.020/root202007221206:user/test-keys Boot serial: LKN5T19409001633 GSM version: 21C20B379S000C000,21C20B379S000C000 Current phone type: 1,1 Network type: UMTS,Unknown RIL version: CommRil 5.0 Data encryption state: encrypted SOC: kirin980 Board type: EVR Board platform: kirin980 UsbConfig: hisuite,mtp,mass_storage,hdb Debuggable: 0 Finished at local time: [09.01.23 16:47:54] WorkID: 232797297 ------------------------------------------------------------------------------ Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-01 Printing phone history Get Info 9/1/2023 2:41 PM Modify Oeminfo 9/1/2023 2:30 PM Enter Factory Mode 9/1/2023 2:28 PM Enter Factory Mode 9/1/2023 2:04 PM Enter Factory Mode 9/1/2023 2:01 PM Modify Oeminfo Rebooting phone to factory mode We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! We couldn't identify the device, please select manually, if present! Changing to factory mode Rebooting phone to USB update mode Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. It seems that your phone has HarmonyOS installed, please use Harmony cable to put the phone into factory mode. You must plug in the C type connector to the phone first, then the A type into the PC. For more details click here: https://chimeratool.com/en/docs/huaw...monyos-support. We couldn't identify the device, please select manually, if present! Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. New model name: EVR-L29 New vendor/country value: hw/eu Force hash overwrite We've just rebooted your phone into USB update mode, please do an USB firmware update without further reboot, because it might reinitialize the FW version compatibility flag. Please disconnect the USB cable from the PC as soon as possible and reconnect once the USB Update screen appears on the phone. It's important to remove the USB connector from the PC. You might want to swap to a regular USB cable instead of the Harmony cable now for high speed USB Update. In case your phone restarts in eRecovery mode, please reboot it, then power it off and restart procedure. In case your phone restarts in USB Update mode, and Chimera doesn't connect automatically, please reconnect the USB cable on computer side. Finished at local time: [09.01.23 17:43:39] WorkID: 232805372 -------------------------------------------------------------------------------------------- Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-01 Printing phone history Usb Firmware Update 9/1/2023 2:38 PM Modify Oeminfo 9/1/2023 12:58 PM Load Factory Fastboot 9/1/2023 12:55 PM Load Factory Fastboot 9/1/2023 12:51 PM Get Info 9/1/2023 12:49 PM Update firmware Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing PRETS. Processing PRETVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing KPATCH. Processing USERDATA. Processing UFSFW. Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/d/AppData/Local/Temp/CHIMERA_JIRRcdptable.app Validating base file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_aAJrgeupdate.app Validating customization file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_TdgFbkupdate.app Validating preload file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_HMVxpdupdate.app Processing C:/Users/d/AppData/Local/Temp/CHIMERA_JIRRcdptable.app Flashing SHA256RSA Operation failed Finished at local time: [09.01.23 17:45:08] WorkID: 232805715 |
![]() | #4 (permalink) |
Member: 236667 Status: Offline Thanks Meter: 11 | I have tried with 2 firmwares : Now I cannot set device model. It stays AL00. code: Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-04 Printing phone history Modify Oeminfo 9/4/2023 12:57 PM Get Info 9/4/2023 12:57 PM Modify Oeminfo 9/1/2023 2:42 PM Get Info 9/1/2023 2:41 PM Modify Oeminfo 9/1/2023 2:30 PM Gathering information... Device Model: EVR-AL00 Current software version: EVR-AL00 2.0.0.291(C00E230R2P6) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify fail Android version: 10 Battery state: 3795mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.8 Phone info: NO MAIN VERSION VendorCountry: hw/eu Base version: EVR-LGRP1-CHN 102.0.0.291 Cust version: EVR-AL00-CUST 102.0.0.230(C00) Preload version: EVR-AL00-PRELOAD 102.0.0.6(C00R2) Finished at local time: [09.04.23 16:02:38] WorkID: 233169907 --------------------------------------------------------------------------------------- Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-04 Printing phone history Get Info 9/4/2023 1:02 PM Modify Oeminfo 9/4/2023 12:57 PM Get Info 9/4/2023 12:57 PM Modify Oeminfo 9/1/2023 2:42 PM Get Info 9/1/2023 2:41 PM Modify Oeminfo Rebooting phone to factory mode Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. New model name: EVR-L29 We've just rebooted your phone into USB update mode, please do an USB firmware update without further reboot, because it might reinitialize the FW version compatibility flag. Please disconnect the USB cable from the PC as soon as possible and reconnect once the USB Update screen appears on the phone. It's important to remove the USB connector from the PC. You might want to swap to a regular USB cable instead of the Harmony cable now for high speed USB Update. In case your phone restarts in eRecovery mode, please reboot it, then power it off and restart procedure. In case your phone restarts in USB Update mode, and Chimera doesn't connect automatically, please reconnect the USB cable on computer side. Finished at local time: [09.04.23 16:04:40] WorkID: 233170020 Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-04 Printing phone history Usb Firmware Update 9/1/2023 2:44 PM Usb Firmware Update 9/1/2023 2:38 PM Modify Oeminfo 9/1/2023 12:58 PM Load Factory Fastboot 9/1/2023 12:55 PM Load Factory Fastboot 9/1/2023 12:51 PM -------------------------------------------------------------------------------------------------- Chimera Mobile Phone Utility version: 36.81.1014 @ 2023-09-04 Printing phone history Usb Firmware Update 9/4/2023 1:00 PM Usb Firmware Update 9/1/2023 2:44 PM Usb Firmware Update 9/1/2023 2:38 PM Modify Oeminfo 9/1/2023 12:58 PM Load Factory Fastboot 9/1/2023 12:55 PM Update firmware Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing SYSTEM. Processing CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing VENDOR. Processing ODM. Processing PRODUCT. Processing PREAS. Processing PREAVS. Processing PATCH. Processing USERDATA. Processing UFSFW. Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/d/AppData/Local/Temp/CHIMERA_CHWSsbptable.app Validating base file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_duswuSupdate.app Validating customization file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_DhDVZQupdate.app Validating preload file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_CxYxzuupdate.app Processing C:/Users/d/AppData/Local/Temp/CHIMERA_CHWSsbptable.app Flashing SHA256RSA Operation failed Finished at local time: [09.04.23 16:06:18] WorkID: 233170406 ----------------------------------------------------------------------------------------------------- Update firmware Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing USERDATA. Processing UFSFW. Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/d/AppData/Local/Temp/CHIMERA_flfSNtptable.app Validating base file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_jIDshmupdate.app Validating customization file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_rTqByfupdate.app Validating preload file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_WtvpfLupdate.app Processing C:/Users/d/AppData/Local/Temp/CHIMERA_flfSNtptable.app Flashing SHA256RSA Operation failed Finished at local time: [09.04.23 16:01:02] WorkID: 233169558 |
![]() | #5 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 22,837 | Dear User, Please do the MODIFY OEMINFO again, and when you see the message that says: We've just rebooted your phone into USB update mode, please do an USB firmware update without further reboot, because it might reinitialize the FW version compatibility flag. Please disconnect the USB cable from the PC as soon as possible and reconnect once the USB Update screen appears on the phone. It's important to remove the USB connector from the PC. You might want to swap to a regular USB cable instead of the Harmony cable now for high speed USB Update. Disconnect the USB cable from the PC side then immediately reconnect it. The phone should be in USB update mode, where you can flash it. It is very important NOT to boot up the device after the Modify Oeminfo. Best Regards, ChimeraTeam Quote:
![]() | #6 (permalink) |
Member: 236667 Status: Offline Thanks Meter: 11 | I done that way from the start. With harmony cable an without it. Testpoint is detected only with harmony cable, but when promted it can be swapped on the same port easy. Shoul I try a latest firmware EVR-L29 ? Or a board firmware? |
![]() | #7 (permalink) |
Member: 236667 Status: Offline Thanks Meter: 11 | The phone has now firmware EVR-AL00 2.0.0.291. I tried the same firmware to write to it. The same error. code: Update firmware Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PRETS. Processing PRETVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing KPATCH. Processing USERDATA. Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/d/AppData/Local/Temp/CHIMERA_PjsfKxptable.app Validating base file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_mJEBtEupdate.app Validating customization file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_ixFkmkupdate.app Validating preload file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_sYnJYbupdate.app Processing C:/Users/d/AppData/Local/Temp/CHIMERA_PjsfKxptable.app Flashing SHA256RSA Operation failed Finished at local time: [09.05.23 10:11:22] WorkID: 233277952 |
![]() | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 22,837 | Dear User, Please use a normal firmware and not a board firmware. And from the logs we see that you did a get info after the Modify oeminfo. But you should not do it, as you should flash it before it boots up. So do not boot the phone up, only flash it. Best Regards, ChimeraTeam |
![]() | #9 (permalink) |
Member: 236667 Status: Offline Thanks Meter: 11 | The phone has now firmware EVR-AL00 2.0.0.291. I tried the same firmware to write to it. The same error. code: Update firmware Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PRETS. Processing PRETVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing KPATCH. Processing USERDATA. Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/d/AppData/Local/Temp/CHIMERA_PjsfKxptable.app Validating base file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_mJEBtEupdate.app Validating customization file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_ixFkmkupdate.app Validating preload file Processing C:/Users/d/AppData/Local/Temp/CHIMERA_sYnJYbupdate.app Processing C:/Users/d/AppData/Local/Temp/CHIMERA_PjsfKxptable.app Flashing SHA256RSA Operation failed Finished at local time: [09.05.23 10:11:22] WorkID: 233277952 Report Post |
![]() | #10 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,837 | Dear User, We are looking for a solution for this issue. We will reply here if we have any solution. Sorry for the inconvenience. Best Regards, ChimeraTeam Quote:
