03-04-2023, 15:35 | #152 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Mardan Pakistan Age: 38
Member: 2768168 Status: Offline Thanks Meter: 42 | Chimera Mobile Phone Utility version: 34.98.1241 @ 2023-03-04 Printing phone history Model And Vendor/country Change 04-Mar-23 02:13 PM Converting to Dual SIM... Factory reset notify window was accepted. Searching for manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Changing the model name to dual SIM variant... Changing simcard slot information... This may take a while. Be patient! Do NOT disconnect the phone! Factory reset the device... Finished at local time: [03.04.23 19:32:55] WorkID: 214228115 Convert dual sim done. |
The Following User Says Thank You to Abdul Basit GSM For This Useful Post: |
03-06-2023, 14:52 | #153 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear Abdul, Thank you for sharing it with us! Best regards Sab Chimera team Quote:
03-14-2023, 07:40 | #154 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Peshawar, Pakistan Age: 40
Member: 2622185 Status: Offline Sonork: 100.1675196 Thanks Meter: 19 | d-01j didnt work Changing simcard slot information... This may take a while. Be patient! Do NOT disconnect the phone! Factory reset the device... Finished at local time: [03.14.23 11:38:13] WorkID: 215148418 |
03-14-2023, 14:01 | #155 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear Amin, As we see the work just ended successfully. What happened after that? The device is still showing a single Sim? Do you reflash the device after the process with a Dual sim firmware? Best regards Sab Chimera team |
04-19-2023, 18:47 | #156 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | It does not work. Phone has only one imei, has only one operator full signal but I can`t call on the phone... Only sms work. If I call the number on the phone, it goes straight to vocemail and on the Gra-L08 I receive an sms with missed call. I flashed with GRA-L09_C432B222_Firmware_CEE&Nordic European_Channel-Others_Andriod 5.0.1_EMUI 3.1_05012XMN.zip .... same thing Converting to Dual SIM... Factory reset notify window was accepted. Searching for manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Changing simcard slot information... This may take a while. Be patient! Do NOT disconnect the phone! Factory reset the device... Finished at local time: [04.19.23 20:44:47] WorkID: 218614962 |
04-20-2023, 08:49 | #157 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Once you do the "Convert to Dual Sim" service, you have to use the USB FIRMWARE UPDATE service. You have to flash a firmware which is a DUAL SIM FW. That is very important. Otherwise the method will not work. Best regards Sab Chimera team Quote:
04-25-2023, 12:24 | #158 (permalink) | |
Member: 120579 Status: Offline Thanks Meter: 182 | Quote:
Thank you. | |
04-25-2023, 12:31 | #159 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | Dear User, We are not able tell you an exact firmware. However when downloading a firmware for this you must pay attention to the follwoing: The Firmware must be DUAL SIM The Firmware must be compatible with the phone The EMUI version has to be the same or little bit higer We hopes this help, ChimeraTeam |
01-23-2024, 17:18 | #160 (permalink) |
Junior Member Join Date: Dec 2019 Location: maputo
Member: 2941618 Status: Offline Thanks Meter: 4 | Chimera Mobile Phone Utility version: 38.20.1102 @ 2024-01-23 Converting to Dual SIM... Factory reset notify window was accepted. Searching for manufacture port... Automatic Manufacture Port enabling... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Changing simcard slot information... This may take a while. Be patient! Do NOT disconnect the phone! Factory reset the device... Finished at local time: [01.23.24 17:53:15] WorkID: 255966388 not working |
