Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 10-14-2020, 18:59   #136 (permalink)
Member: 240756
Thanks Meter: 86
Originally Posted by Chimera Tool View Post
Thank you for the cooperation. Please reflash the device with a firmware which is for the DUAL SIM version. Then check it.
problem Solved it was antina issue customer changed the Lcd and Damage Antina Connection.Thanx Chimera Team
The Following User Says Thank You to Aazib jhon For This Useful Post:
Old 01-15-2021, 15:08   #137 (permalink)
Member: 472482
Thanks Meter: 105
I want to convert P10 ,VTR-L09 , 1 sim to 2 sim, but no option , why ? In the new ,last exe not supported?
Old 01-15-2021, 15:37   #138 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,215
reply
Good day!
The mentioned device - VTR-L09 - is actually supported for the "Convert to Dual Sim" service. You have to connect the phone in ADB mode to be able to do it.
Also here you can check which other services are added to the device:
https://chimeratool.com/en/models#q=VTR-L09
Sab
Old 01-24-2022, 14:48   #139 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,083
PRA-LX1 Single To Dual SIM Convert Done ;)
upload gif online
Chimera Mobile Phone Utility version: 30.88.1240 @ 2022-01-24
Converting to Dual SIM...
Factory reset notify window was accepted.
Searching for manufacture port...
Testing connection...
Authenticating...
This may take a while.
Be patient! Do NOT disconnect the phone!
Checking IMEI(s)...
Identifying...
Changing the model name to dual SIM variant...
Changing simcard slot information...
Factory reset the device...
Finished at local time: [01.24.22 15:27:59]
WorkID: 167070213
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 01-24-2022, 17:14   #140 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the job, really great one!
Best regards
Sab
Chimera team
Originally Posted by ...:::::NP™:::::... View Post
upload gif online
Authenticating...
Checking IMEI(s)...
Identifying...
WorkID: 167070213
Old 02-14-2022, 20:14   #141 (permalink)
Member: 2640066
Sonork: 1675713
losing oem info
Authenticating...
Checking IMEI(s)...
Identifying...
Finished at local time: [02.14.22 20:09:13]
WorkID: 169521951
phone original name vtr-l09
phone name after repair onyx d188
stockage before 4ram/64rom
stockage now 2ram/16rom
Old 02-15-2022, 11:37   #142 (permalink)
Member: 1787203
reply
Dear Yassingsm,
Please reflash the device with firmware that is compatible with a Dual SIM model version. Then restart the phone and check the phone info.
Best regards
Sab
Chimera team
Authenticating...
Checking IMEI(s)...
Identifying...
WorkID: 169521951
Old 02-15-2022, 15:40   #143 (permalink)
Member: 3004729
Finished at local time: [02.15.22 22:42:10]
Work ID: 169613619
honor 8 lite
worked!Great!!
The Following User Says Thank You to simonfeng0668 For This Useful Post:
Old 02-15-2022, 16:52   #144 (permalink)
Member: 1787203
reply
Thank you for the positive feedback! Great work!
Work ID: 169613619
honor 8 lite
worked!Great!!
Old 04-25-2022, 10:50   #145 (permalink)
Member: 1726028
Sonork: 1647687
Thanks Meter: 10
WorkID: 177770476 p8 lite 2017 convert to dual sim job, still remain on one sim card after job finish
Old 04-25-2022, 13:34   #146 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 713
Reflash with Dual SIM firmware
The Following User Says Thank You to jepetu For This Useful Post:
Old 04-26-2022, 09:33   #147 (permalink)
Member: 1787203
reply
Dear bgfi,
As Jepetu said before correctly. The Device should be reflashed with a firmware that was released exactly for the DUAL SIM phones.
Best regards
Sab
Chimera team
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 05-13-2022, 10:50   #148 (permalink)
Member: 1726028
Sonork: 1647687
Thanks Meter: 10
WorkID: 179966301 p8 lite 2017
Old 05-16-2022, 10:00   #149 (permalink)
Member: 1787203
reply
Dear Bgfi,
Thank you for the posted Work ID. The phone is still a single sim one?
Best regards
Sab
Chimera team
Old 07-08-2022, 15:44   #150 (permalink)
Member: 2999402
WorkID: 187047718
Hi work perfectly set sengle to dual on p10 lite
Page generated in 0.30578 seconds with 8 queries
