Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #17 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003 Location: Iassy
Member: 19723 Status: Offline Thanks Meter: 359 | Huawei P10 Plus [Converting to Dial Sim...] Searching for Manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Rebooting device to fastboot mode... Device found! Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Changing simcard slot information... Factory reset the device... Finished successfully. Finished at local time: [07.03.17 17:57:11] WorkID: 23192785 Worked for me !!!!!!!!!!!! |
The Following User Says Thank You to usernome For This Useful Post: |
![]() | #19 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003 Age: 45
Member: 37485 Status: Offline Thanks Meter: 73 | Hi To all I´me a chimera client, and have in hands a P9 lite verison L31 how to Single SIM phones convert to Dual SIM processes In program just could unlock boot loader and SIM lock any special tool? Like to try |
![]() | #20 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012
Member: 1787203 Status: Offline Thanks Meter: 21,793 | reply Dear Sir, on the L31 device the convert to dual sim process not supported at the moment. You can use the follow functions on your phone: Direct Unlock FRP Remove Repair IMEI Unlock / Relock Bootloader Factory reset Get Info Remove Huawei-ID Lock Repair MAC Update Firmware Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
![]() | #22 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | Quote:
any special adapter to hardware modification fo do this work thanks in advance | |
![]() | #23 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 947 | Hello sir . I got P9-Lite (VNS-L31) I want to convert it to dual sim. I just want to make sure if i will convert it . is it same to keep data. I dont want to remove any data. Is it possible. |
![]() | #24 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | Chimera Mobile Phone Utility version: 14.54.1007 @ 2017-07-31 [Converting to Dial Sim...] Searching for Manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Rebooting device to fastboot mode... Device found! Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Changing simcard slot information... Factory reset the device... Finished successfully. Finished at local time: [07.31.17 12:31:15] WorkID: 24441663 |
![]() | #28 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2747529 Status: Offline Thanks Meter: 1 | P10 Lite DUAL SIM Hi! P10 Lite DUAL SIM option is worked perfectly! Thanks! P10 Lite (WAS-LX1) WorkID: 25109811 |
The Following User Says Thank You to zsolt32 For This Useful Post: |
![]() | #30 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | Conversion Done Successfully: Huawei P10 Plus (VKY-L09) Chimera Mobile Phone Utility version: 14.88.1343 @ 2017-08-29 Printing phone history Get Info 8/29/2017 10:40:28 PM Unlock / Relock Bootloader 8/29/2017 10:38:31 PM Unlock / Relock Bootloader 8/29/2017 10:33:35 PM [Converting to Dial Sim...] Searching for Manufacture port... Testing connection... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Checking IMEI(s)... Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Rebooting device to fastboot mode... Device found! Checking if factory challenge needed... Already unlocked. Changing simcard slot information... Factory reset the device... Finished successfully. Finished at local time: [08.29.17 18:45:32] WorkID: 25813790 |
