02-19-2023, 14:21 | #1 (permalink) |
Freak Poster Join Date: Jun 2017 Location: Constantine
Member: 2723574 Status: Offline Thanks Meter: 15 | flashing eml-l29 failed i wrote oem info succefully but when i try to flash the firmware , the operation failed after " Flashing BASE_VER " work id : 212932521 i changed also oem info and another flash but still the same. |
02-21-2023, 13:29 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, if device is on high version of android, I recommend you flash board firmware, after flash it, flash any full stock firmware... and you will be ok |
02-21-2023, 14:17 | #3 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear ahmed26h, Thank you for the report. We noticed that you tried to flash the EMUI 10 version. We would recommend to flash an older EMUI version, like an EMUI 8 and then flash newer version to the phone. So make sure that you will not jump from EMUI 8 to 10. Best regards Sab Chimera team |
