07-25-2021, 14:10 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | G977n U5 patch cert done but keep restarting i need to patch CERT G977n U5. with chimera Patch opration Done. but phone keep restarting . Work ID (143573803) here is log Code: Chimera Mobile Phone Utility version: 29.04.1243 @ 2021-07-25 Printing phone history Patch Certificate 7/20/2021 12:44 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G977N Carrier ID: KTC Sales Code: KTC Country Code: KOREA Timezone: Asia/Karachi Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri May 7 11:37:38 KST 2021 PDA Version: G977NKSU5FUE3 [may 2021, rev3] Phone Version: G977NKOU5FUE1 [may 2021, rev1] CSC Version: G977NOKR5FUE3 [may 2021, rev3] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON50005100 Imei: 35898205522772 Battery Status: 3.70V (24%) Network Type: GSM Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-05-01 Em Did: 202834CE80F98011 Preparing... Checking root access. The phone is rooted by: 22.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.25.21 13:12:30] WorkID: 143573803 |
07-26-2021, 10:29 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,764 | reply Dear Hafiz, Thank you for the report. The patching was done fully, and because of that the device keeps rebooting. So please reflash the phone. Root it again. Then run the IMEI REPAIR and the PATCH CERT services in Airplane mode and then in Normal mode. Turn off the phone and wait a few minutes, then check the network. Best regards Sab Chimera Team Quote:
07-27-2021, 09:40 | #3 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
07-28-2021, 10:42 | #4 (permalink) | |
please check on server Work log (143992673) | |
07-29-2021, 10:13 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,764 | reply Dear User, Before you patch it, please boot up the device from recovery. Then do the imei repair and the patch cert services with the chimera tool. Best regards Sab Chimera Team |
