Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-22-2019, 14:04   #1 (permalink)
Member: 2169302
Thanks Meter: 49
Fly mode after patch network in a lot of phones
I have this problem after update chimera
When Fox this
Old 03-22-2019, 14:23   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 19,581
reply
Hi,
we did not heard about same problem than before, please send us work id and some other info about the case.
Best regards
Nicole
When Fox this
Old 03-22-2019, 14:54   #3 (permalink)
Member: 2532441
Thanks Meter: 30
mode avion samsung in patch cert
Gentlemen of Chimera, it is true since yesterday all the phones when you get to patches after the restart is put in airplane mode. in high binaries that happens with patch method february 2019 is happening that, I have customers desperate for their phones. fix the bug please
Old 03-22-2019, 14:57   #4 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 140
Airplane mode is now entered on each bootup while the patch cert process running on phone. When it is complete, after 20-70 seconds, it should disable airplane mode automatically. If it does not, something went wrong in process, can try reboot, or repeat patch cert operation with different firmware.
Old 03-22-2019, 15:04   #5 (permalink)
Member: 2532441
Thanks Meter: 30
it continues bugeado in cert status shows OK, but airplane mode disappears after a time sometimes calls, sometimes calls, sometimes restarts disappears airplane mode does not give signal and the signal is placed in a circle and the imei status says OK ... solution please
Old 03-22-2019, 15:27   #6 (permalink)
Member: 952912
Thanks Meter: 140
You must wait until airplane mode is off automatucally before check imei pass status. If do while still in airplane mode, the patch cert process has not completed yet. Does it help if you remove and reinsert the sim card?
Old 03-22-2019, 15:28   #7 (permalink)
Member: 2237569
Thanks Meter: 9
Hello
I am having the same problem after patch network works normally, when the device is restarted back in airplane mode and the status is NG
Old 03-22-2019, 15:47   #8 (permalink)
Member: 952912
Thanks Meter: 140
I repeat, airplane mode will be entered everytime phone reboots, for a period of 20-70 seconds. During this time, do not check imei status. After 20-70 seconds, device will exit airplane mode. Now you can check imei status. Makes sense?
Old 03-22-2019, 15:50   #9 (permalink)
Member: 2237569
Thanks Meter: 9
I already did this test I waited 10 minutes and there is still NG
Old 03-22-2019, 15:58   #10 (permalink)
Member: 952912
Thanks Meter: 140
Can you retry patch cert operations and post workid history.
Old 03-22-2019, 18:42   #11 (permalink)
Member: 2563951
Thanks Meter: 4
Same problem Airplane Mode After Patch
I have problem with two SM-G955F after patch start with airplane mode, after 1.45 min start normal network ok.
Version: v20.58.2014
Chimera Mobile Phone Utility version: 20.58.2014 @ 2019-03-22
Printing phone history
Patch Certificate
22/3/2019
17:28:39
Patch Certificate
22/3/2019
14:05:50
Patch Certificate
22/3/2019
14:00:21
Repair IMEI
22/3/2019
13:58:03
Patch Certificate
2/3/2019
10:35:31
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G955F
Sales Code: ARO
Country Code: Argentina
Timezone: America/Argentina/Buenos_Aires
Android Version: 8.0.0 [R16NW] [SDK 26]
Build Date: Tue Dec 4 12:07:47 KST 2018
PDA Version: G955FXXU4CRL3 [december 2018, rev3]
Phone Version: G955FXXU4CRKB [november 2018, revB]
CSC Version: G955FOXM4CRL1 [december 2018, rev1]
Product Code: ARO
HIDSw Version: G955FXXU4CRL3/G955FOXM4CRL1/G955FXXU4CRKB/G955FXXU4CRL3
Board Platform: EXYNOS5
Modem Platform: SHANNON355
Serial Number: R28J70VBFCF
Imei: 357820080------
Unique Number: CE051715CCCBB84003
Connections: AT,MTP
Battery Status: 4.11V (81%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2018-12-01
Data Encryption State: unencrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
Checking boot image. Be patient! Do NOT disconnect the phone!
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data...
Checking modem version.
Restarting phone.
Reading data. Be patient! Do NOT disconnect the phone!
Patching certificate...
Communicating with the server. Be patient! Do NOT disconnect the phone!
After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Successfully finished.
Finished at local time: [03.22.19 14:32:25]
WorkID: 55350528
Old 03-22-2019, 18:46   #12 (permalink)
Member: 181405
Thanks Meter: 234
Same problem Airplane Mode After Patch G570m airplane mode G610m airplane mode
fix problem all phone airplane mode
Old 03-22-2019, 20:19   #13 (permalink)
Member: 2377851
Thanks Meter: 26
Same problem happened to me yesterday on 3 differents J5 PRIME, after reboot this problem was gone.
Old 03-22-2019, 20:47   #14 (permalink)
Super Moderator
Braycel's Avatar
Member: 813309
Sonork: 100.1684834
Thanks Meter: 1,865
Strange maybe firmware problem
i repaired 3 g570m yesterday
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
Old 03-22-2019, 22:32   #15 (permalink)
Member: 2532441
Thanks Meter: 30
yesterday was normal, today was the problem since they got the update with the bug in airplane mode, the client will not say wait 2 minutes xD, gives me a good team and I return it in airplane mode and hope it disappears that is wrong.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17266 seconds with 7 queries
