04-28-2021, 18:03 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Age: 33
Member: 1996171 Status: Offline Thanks Meter: 74 | FRP P40 Pro Operation failed Code: Chimera Mobile Phone Utility version: 28.27.1513 @ 2021-04-28 Printing phone history Huawei Id & Frp Remove 4/28/2021 4:52 PM Get Info 4/27/2021 4:33 PM Enter Factory Mode 4/27/2021 4:31 PM Get Info 4/27/2021 4:30 PM Enter Factory Mode 4/27/2021 4:26 PM Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Operation failed Finished at local time: [04.28.21 17:56:49] WorkID: 132727831 |
04-29-2021, 09:45 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,736 | reply Dear User, The mentioned device does not have FRP lock on it. If you want to remove the ID from the phone, then just perform the service (the same service) again. But make sure that you reinstall the Chimera Tool Huawei driver, and you use another port and cable (if you can use the original Huawei cable) for the method. Best regards Sab Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-30-2021, 02:06 | #6 (permalink) | |
Member: 1996171 Status: Offline Thanks Meter: 74 | Thank you chimera tool Team Quote:
