06-06-2020, 17:16
#1 (permalink)
Member: 2171294
Sonork: 100.1659207(No More Use) Thanks Meter: 706 | G570F DRK/Baseband/Imei/NG Fixed Quote:
Chimera Mobile Phone Utility version: 24.92.2104 @ 2020-06-06
Printing phone history
SW Change6/6/202011:41:23AM
SW Change6/6/202011:39:38AM
SW Change6/6/20208:14:32AM
SW Change6/6/20207:58:00AM
SW Change6/6/20207:51:51AM
Firmware update started
Processing firmware...
Waiting for download mode.
Connecting.
SBL Info: Model: SM-G570F, Region: MEA, Provider: JV, PDA: G570FXXS2CSG2
Reading PIT from phone.
Flashing boot.img
Flashing system.img
Flashing userdata.img
Flashing sboot.bin
Flashing param.bin
Flashing cm.bin
Flashing modem.bin
Flashing cache.img
Flashing hidden.img
Restarting phone.
Successfully finished.
Finished at local time: [06.06.20 17:46:07]
WorkID: 97198526 | Quote:
Repair Device Root Key6/6/20203:50:14PM
Repair Device Root Key4/23/20205:01:13PM
Repair Device Root Key4/23/20204:59:23PM
Repair started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G570F
Sales Code: CAC
Country Code: Central Asia
Timezone: Asia/Dhaka
Android Version: 8.0.0 [R16NW] [SDK 26]
Build Date: Sat Jul 27 14:53:11 KST 2019
PDA Version: G570FXXS2CSG2 [july 2019, rev2]
Phone Version: G570FXXS2CSG3 [july 2019, rev3]
CSC Version: G570FOXE2CSG1 [july 2019, rev1]
Product Code: CAC
HIDSw Version: G570FXXS2CSG2/G570FOXE2CSG1/G570FXXS2CSG3/G570FXXS2CSG2
Board Platform: EXYNOS5
Modem Platform: SHANNON305
Serial Number:
Imei: 000000000000000
Unique Number: CQE0019E2DA88B4
Connections: AT,MTP
Battery Status: 4.18V (79%)
Network Type: GSM
SIM Status: ABSENT,NOT_READY
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-08-01
Repair imei...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Current imei: 000000000000000
Repaired imei: 3455
Current imei2: 000000000000000
Repaired imei2: 34555
Finished at local time: [06.06.20 21:52:57]
WorkID: 97222438 | Quote:
Patch Certificate6/6/20203:57:28PM
Set SIM Count6/6/20203:55:09PM
Repair IMEI6/6/20203:52:27PM
Patch certificate started
Model: SM-G570F
Sales Code: CAC
Product Code: CAC
Serial Number:
Imei: 3455
Connections: AT,MTP
Battery Status: 4.18V (81%)
Network Type: GSM
SIM Status: ABSENT,ABSENT
Knox Version: v30
Warranty Bit: 0
Preparing...
Checking root access.
The phone is rooted by: 21.0:MAGISKSU
Reading data...
Patching certificate...
About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Finished at local time: [06.06.20 21:59:38]
WorkID: 97223127 |
Baseband fixed Manually |
