Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2687119 Status: Offline Thanks Meter: 0 | G890a Reactivation Lock Error - SOLVED Unable to reset. Code: Chimera Mobile Phone Utility version: 12.89.0901 at 2017-02-20 Printing phone history Reset FRP/Reactivation Lock 2/20/2017 15:53:19 Reset FRP/Reactivation Lock 2/20/2017 15:52:50 Reset FRP/Reactivation Lock 2/20/2017 15:52:17 Reset FRP/Reactivation Lock 2/20/2017 15:49:44 Reset FRP/Reactivation Lock 2/20/2017 15:47:55 [Reset reactivation lock started] Selected model: SM-G890A Processing... Waiting for download mode. Connecting. Initializing. Reading PIT. Reseting. Unable to reset. Finished at local time: [02.20.17 10:13:59] WorkID: 18170243 Any help would be appreciated. Thanks. Last edited by Chimera Tool; 02-23-2017 at 11:28. |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear User, Information about the chimeratool remove frp lock processes: 1. FRP lock remove (old method): in each case install older firmware than august 2016 on the device and the frp lock remove will be ok. (Please use the firmware compatibility check process, with it you can be sure everything will be ok with the flash firmware) 2. Reset FRP lock - NEW: it is working only on the listed models with the listed (exact firmwares). That means when you can not find your device's firmware version in a list, please do not use that function, it will be failed. 3. Reset reactivation lock / frp lock: It is a special function that is able to use only in the listed models. In your case and with this model I recommend using the option Reset FRP / Reactivation Lock. Please upload the result of the operation. Thank you! |
![]() | #3 (permalink) | |
Member: 2687119 Status: Offline Thanks Meter: 0 | Quote:
However, I found a workaround for that. If, after using chimera but before the phone reboots, I put the phone in recovery mode and then reboot. It startup with only a few errors. But then, going through and attempting "Factory Data Reset" prompts for a Samsung Account. So, I still can't remove the Reactivation Lock. So, just to reiterate, the Rest FRP / Ractivation Lock. Can bypass setup, but it doesn't remove Reactivation Lock. | |
![]() | #4 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 22,835 | reply Dear Sir, please log out and log in again into the chimeratool software. We fixed some things on the mentioned model. If it is possible try again the frp lock remove on the mentioned model and send us some feedback about the result. Thank you in advance! Best regards Nicole Quote:
The Following 2 Users Say Thank You to Chimera Tool For This Useful Post: |
![]() | #5 (permalink) | |
How do I edit OP now? I'd like to change title to include [Solved] | |
![]() | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 22,835 | reply Dear Sir, thank you for your feedback ![]() When you click to edit your post you are able to modify the post name too, but we can do it too ![]() Best regards Nicole |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004 Location: Now on earth Age: 47
Member: 75290 Status: Offline Thanks Meter: 55 | G890A reactivation failed SW REV:5 B:2 S:2 Is it possible to remove samsung account? I did it with chimera but after restart, firmware show always error. Impossible to go to settings. Downgrade impossible I think... Firmware COMBINATION exist? How to remove? BR ERSA Seb |
