G930F Android 8 bit 3 FRP problem Hi, Tried every method, no luck. SBL Info: Model: SM-G930F, Region: EUR, Provider: OPEN, PDA: G930FXXS3ERI1 |
reply Hi, can I ask the exact work id of the problematic processes please? Thank you in advance! Best regards Nicole Quote:
one example : Selected model: SM-G930F Resetting FRP by old odin-based method. Processing... Waiting for download mode. Connecting. Initializing. SBL Info: Model: SM-G930F, Region: EUR, Provider: OPEN, PDA: G930FXXS3ERI1 Reading PIT. Reseting. Unable to reset. Finished at local time: [10.17.18 10:00:31] WorkID: 45980719 |
Reset FRP/Reactivation lock started Processing... Selected model: SM-G930F Waiting for download mode. Connecting. Initializing. Reading PIT. Serial port init failed. Finished at local time: [10.17.18 10:41:09] WorkID: 45982588 |
SM-G930F bin 3 FRP FAILED Inside phone is FW: COMBINATION_FA60_G930FXXU3ARI2_CL7964511_QB1963550 1_REV00_user_mid_noship Chimera Mobile Phone Utility version: 19.17.1421 @ 2018-11-07 Printing phone history Reset FRP/Reactivation Lock - UFS 07.11.2018 08:42:32 Reset FRP/Reactivation Lock - UFS 06.11.2018 13:57:35 Reset Screen Lock 06.11.2018 13:56:38 Reset FRP/Reactivation lock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Timezone: Europe/Warsaw Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Tue Sep 4 13:25:16 KST 2018 PDA Version: FA60_G930FXXU3ARI2 Phone Version: G930FXXU3ARI1 [september 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58K10TNTVF Imei: 35407409722416 Battery Status: 4.04V (71%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v00 Warranty Bit: 0 Security Patch: 2016-01-01 Data Encryption State: unencrypted Processing... Switching to download mode. Waiting for download mode. Connecting. Initializing. Reading PIT. Release the buttons! The appropriate serial port has been found. Succeeded. Successfully finished. Finished at local time: [11.07.18 09:47:32] WorkID: 47138014 after work FRP is still ON |
Dear Sir! If you use a combination file you will have adb communication and you will be able to do the process but not in a complete way. In order to have a satisfactory result, you have to use these steps. 1. Flash Combination The phone will start in the engineering menu and ad communication will be enabled but it is not necessary to use the FRP function 2. In these cases and to ensure that you have to enable USB debugging and do manual deletion and when you re-start the engineering menu, perform the activation of the development options again before doing flash Ideally, you can see the OEM option unlock. But, it does not matter and continue with the process. 3. Download from the support the firmware of 4 files in each folder and only check these options: A) BOOT - (check sboot) B) PDA - (tick Boot, Recovery, System) C) PHONE - DO NOT tick anything or load D) CSC - DO NOT tick or load |
Hello. Flash ENG SBOOT. https://mega.nz/#!9IpgySYQ!8ci-br0lC...HT1aur2nzj8Jqs Thenn RESTE FRP UFS METHOD. Flash Stock Sboot. https://mega.nz/#!ENRW0aqT!LdO4vVQ3R...mBDltw93hLfR3w If phone Hang on logo, just flash 4 files firmware DONE. BR Luis Manresa |
Anyone have these boot files still? |
reply Dear NuGSM, Sadly we do not have them, however, you can check the Easy-Firmware website or the Halabtech website for it. Best regards Sab Chimera team Quote:
