Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 10-17-2018, 10:01   #1 (permalink)
Member: 397374
Thanks Meter: 25
G930F Android 8 bit 3 FRP problem
Hi,
Tried every method, no luck.
SBL Info: Model: SM-G930F, Region: EUR, Provider: OPEN, PDA: G930FXXS3ERI1
Old 10-17-2018, 10:16   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 19,411
reply
Hi,
can I ask the exact work id of the problematic processes please?
Thank you in advance!
Best regards
Nicole
Originally Posted by okrongly View Post
Hi,
Old 10-17-2018, 10:38   #3 (permalink)
Member: 397374
Thanks Meter: 25
one example :
Selected model: SM-G930F
Resetting FRP by old odin-based method.
Processing...
Waiting for download mode.
Connecting.
Initializing.
Reading PIT.
Reseting.
Unable to reset.
Finished at local time: [10.17.18 10:00:31]
WorkID: 45980719
Old 10-17-2018, 10:45   #4 (permalink)
Member: 397374
Thanks Meter: 25
Reset FRP/Reactivation lock started
Processing...
Connecting.
Initializing.
Reading PIT.
Serial port init failed.
Finished at local time: [10.17.18 10:41:09]
WorkID: 45982588
Old 11-07-2018, 09:52   #5 (permalink)
ersa's Avatar
Member: 75290
Thanks Meter: 52
SM-G930F bin 3 FRP FAILED
Inside phone is FW:
COMBINATION_FA60_G930FXXU3ARI2_CL7964511_QB1963550 1_REV00_user_mid_noship
Chimera Mobile Phone Utility version: 19.17.1421 @ 2018-11-07
Printing phone history
Reset FRP/Reactivation Lock - UFS
07.11.2018
08:42:32
06.11.2018
13:57:35
Reset Screen Lock
06.11.2018
13:56:38
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G930F
Timezone: Europe/Warsaw
Android Version: 6.0.1 [MMB29K] [SDK 23]
Build Date: Tue Sep 4 13:25:16 KST 2018
PDA Version: FA60_G930FXXU3ARI2
Phone Version: G930FXXU3ARI1 [september 2018, rev1]
Board Platform: EXYNOS5
Modem Platform: SHANNON335
Serial Number: R58K10TNTVF
Imei: 35407409722416
Battery Status: 4.04V (71%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v00
Warranty Bit: 0
Security Patch: 2016-01-01
Data Encryption State: unencrypted
Processing...
Switching to download mode.
Connecting.
Initializing.
Reading PIT.
Release the buttons!
The appropriate serial port has been found.
Succeeded.
Successfully finished.
Finished at local time: [11.07.18 09:47:32]
WorkID: 47138014
after work FRP is still ON
Old 11-07-2018, 13:06   #6 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,775
Dear Sir!
If you use a combination file you will have adb communication and you will be able to do the process but not in a complete way. In order to have a satisfactory result, you have to use these steps.
1. Flash Combination
The phone will start in the engineering menu and ad communication will be enabled but it is not necessary
to use the FRP function
2. In these cases and to ensure that you have to enable USB debugging and do manual deletion and
when you re-start the engineering menu, perform the activation of the development options again before doing flash
Ideally, you can see the OEM option unlock. But, it does not matter and continue with the process.
3. Download from the support the firmware of 4 files in each folder and only check these options:
A) BOOT - (check sboot)
B) PDA - (tick Boot, Recovery, System)
C) PHONE - DO NOT tick anything or load
D) CSC - DO NOT tick or load
The Following User Says Thank You to gcceleghg For This Useful Post:
Old 11-07-2018, 15:56   #7 (permalink)
lolo24's Avatar
Member: 2572618
Thanks Meter: 183
Hello.
Flash ENG SBOOT.
https://mega.nz/#!9IpgySYQ!8ci-br0lC...HT1aur2nzj8Jqs
Thenn RESTE FRP UFS METHOD.
Flash Stock Sboot.
https://mega.nz/#!ENRW0aqT!LdO4vVQ3R...mBDltw93hLfR3w
If phone Hang on logo, just flash 4 files firmware
DONE.
Luis Manresa
The Following 6 Users Say Thank You to lolo24 For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.15128 seconds with 7 queries
