02-15-2018, 11:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Age: 40
Member: 224075 Status: Offline Thanks Meter: 69 | G935f new security patch unlock problem [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: XEG Country Code: Germany Timezone: Africa/Tripoli Android Version: 7.0 [NRD90M] Build Date: Mon Jan 15 17:08:54 KST 2018 PDA Version: G935FXXS2DRA9 [january 2018, rev9] Phone Version: G935FXXU2DRA9 [january 2018, rev9] CSC Version: G935FXEG1DQJ1 [october 2017, rev1] Product Code: XEG HIDSw Version: G935FXXS2DRA9/G935FXEG1DQJ1/G935FXXU2DRA9/G935FXXS2DRA9 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58H91QG78D Imei: 353556085172157 Unique Number: AD01170206EE190327 Connections: AT,MTP Battery Status: 4.11V (71%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-01-01 Data Encryption State: encrypted Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Unlock failed. Unable to Unlock Finished at local time: [02.15.18 12:23:49] WorkID: 33446526 |
02-15-2018, 12:50 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! You have a firmware with binary: 2 like this G935FXXU2DRAG and I already explained that it can not be degrade because you could damage the phone. Firmware with binary file: 2 are not yet supported to repair Imei and patch the certificate. If your phone with the latest firmware Do not try to downgrade !! You can not downgrade AP SW REV because if you are in Binary security bit 2, You can only flash firmware with Security bit 2 !! G935FXXU2DRAG like this. With SW REV That you can not downgrade. You can not downgrade this new firmware. If you flash any older sboot than you will get binary error because of Samsung roll back protection on this very new firmware! If you flash any older modem than you will get UNKNOWN BASEBAND. However, writing new modem will again get back to you the baseband. Try write cert file. |
The Following 3 Users Say Thank You to gcceleghg For This Useful Post: |
02-15-2018, 23:53 | #3 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Any solution soon I got G930FXXU2RA phone in hand to imei repair ?
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! |
02-18-2018, 14:28 | #6 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
1. Put your phone in download mode and flash with chimera using the S / N so that the software detects the firmware corresponding to your phone. 2. If you could not recover it, you could use Smart Switch. 3. If you have damaged the EFS file, this process may serve: Steps to try to rebuild the EFS folder with a combination file: 1. The first thing is to have our phone with imei in 0000-0000 or Unknown 2. Rootear, with CFAutoRoot and is done through Odin v.3.12.5 in the AP option and activate in addition to USB Debugging the OEM Unlocking 3. Once the root is done we proceed to install a Root Explorer and access the EFS folder and we will delete all the content except the folders "FactoryApp" and "prov_data" and turn off the phone. 4. The next step will be to flash via Odin with the Factory_Binary (Combine File) of the model to work. 5. Once the Reset is done, press the "IME" button and a keyboard will appear with which we proceed to verify the IMEI with * # 06 # and we will see that our imei is already correct again 6. Proceed to flash with a Stock Rom and this is it, IMEI Recovered and ready to continue working. | |
03-02-2018, 01:07 | #7 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2368780 Status: Offline Thanks Meter: 2 | combination factory binary for g935fd 2018 security pls can u upload a factory binary for this model with 2018 security . the one avilable on xda doesnt boot up fully even after waiting for 30 minutes , thank you |
03-04-2018, 23:53 | #9 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, not solution available yet... need wait for news as soon as we have... Best Regards Shensohau |
The Following User Says Thank You to Shensohau For This Useful Post: |
