01-31-2020, 09:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870226 Status: Offline Thanks Meter: 52 | G955F U6 Patch Cert Done Successfully 2. Repair Imei Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: DBT Country Code: Germany Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Nov 18 18:07:43 KST 2019 PDA Version: G955FXXU6D*** [november 2019, rev9] Phone Version: G955FXXU6DSK5 [november 2019, rev5] CSC Version: G955FOXM6D*** [november 2019, rev9] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8KB311ZED Imei: 353***********21 Battery Status: 4.35V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-11-01 Data Encryption State: encrypted Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35*************21 Repaired imei: 35************90 Current imei2: 359************3 Repaired imei2: 35***********36 Successfully finished. Finished at local time: [01.31.20 11:42:07] 3. Root https://drive.google.com/open?id=1xb...JrDmopr3LB6vZ1 4. Patch Certificate Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: DBT Country Code: Germany Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Nov 18 18:07:43 KST 2019 PDA Version: G955FXXU6D*** [november 2019, rev9] Phone Version: G955FXXU6DSK5 [november 2019, rev5] CSC Version: G955FOXM6D*** [november 2019, rev9] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8KB311ZED Imei: 35*************0 Battery Status: 4.16V (91%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Data Encryption State: unsupported Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.31.20 12:46:02] WorkID: 87690724 After Patch Imei Status Ok And working without any problems |
The Following 4 Users Say Thank You to tokey786 For This Useful Post: |
