Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 06-23-2020, 14:46   #1 (permalink)
Member: 341207
Thanks Meter: 14
G960F S9 u8 android 10 imei repair
Chimera Mobile Phone Utility version: 25.18.1333 @ 2020-06-23
Printing phone history
Repair IMEI
23.06.2020
11:57:43
Repair IMEI
23.06.2020
09:48:04
Read Cert
23.06.2020
09:44:30
Repair started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G960F
Sales Code: TUR
Country Code: TURKEY
Timezone: Europe/Istanbul
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Mon Mar 30 14:18:37 KST 2020
PDA Version: G960FXXU8DTC5 [march 2020, rev5]
Phone Version: G960FXXU8DTC5 [march 2020, rev5]
CSC Version: G960FOXM8DTC5 [march 2020, rev5]
Product Code: TUR
HIDSw Version: G960FXXU8DTC5/G960FOXM8DTC5/G960FXXU8DTC5/G960FXXU8DTC5
Board Platform: UNIVERSAL9810
Modem Platform: SHANNON360
Serial Number: R58KC2WBFPX
Imei: 359938073142901
Unique Number: CE11182B59994506057E
Connections: AT,MTP
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2020-04-01
Repair imei...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Trying on port SAMSUNG Mobile USB Serial Port (COM51)
There is no proper diag port or not responding or the warranty is void
The warranty is void (KNOX)!
Repair imei failed.
Finished at local time: [06.23.20 16:43:54]
WorkID: 98701180
The warranty is void (KNOX)! ???
Old 06-23-2020, 15:29   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 22,171
reply
Hi,
please read carefully the description of our update: Added New Read Codes Online, Repair IMEI and Read/Write Cert Method for Exynos Models (Root: NO, Knox: 0, BIT: ANY)
KNOX must be 0 for the imei repair process. When your device's KNOX 1, process can not be done.
Best regards
Nicole
Repair IMEI
23.06.2020
11:57:43
Repair IMEI
23.06.2020
09:48:04
Read Cert
23.06.2020
09:44:30
Repair started
Model: SM-G960F
Sales Code: TUR
Product Code: TUR
Connections: AT,MTP
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Repair imei...
Repair imei failed.
WorkID: 98701180
Old 06-23-2020, 16:29   #3 (permalink)
Member: 2575029
Thanks Meter: 117
bro
all user need repiar and patch cert.
i repiar imei done,how to patch cert new security?
only repiar org imei.change imei done but imei cert ng and no solution yet!!
The Following User Says Thank You to gsm-ok For This Useful Post:
Old 06-24-2020, 09:12   #4 (permalink)
Member: 1787203
reply
Hi,
actually we have only Imei repair function, that mean you are able to restore your device's original imei number only.
Best regards
Nicole
Originally Posted by gsm-ok View Post
bro
Old 07-26-2020, 10:41   #5 (permalink)
engcobocell's Avatar
Member: 2590583
Thanks Meter: 197
[2:36 AM, 7/26/2020] Hafiz Imran: Chimera Mobile Phone Utility version: 25.48.1328 @ 2020-07-26
Patch Certificate
7/25/2020
8:10:05
AM
Patch Certificate
7/25/2020
7:46:06
AM
Patch Certificate
7/25/2020
7:44:32
AM
Patch Certificate
7/25/2020
7:41:36
AM
Patch Certificate
7/25/2020
7:40:15
AM
Patch certificate started
Model: SM-G960F
Sales Code: XFA
Country Code: SOUTH AFRICA
Timezone: Asia/Karachi
Build Date: Mon Apr 20 13:04:56 KST 2020
PDA Version: G960FXXS8DTD4 [april 2020, rev4]
Phone Version: G960FXXS8DTD1 [april 2020, rev1]
CSC Version: G960FOXM8DTD5 [april 2020, rev5]
Product Code: XFA
HIDSw Version: G960FXXS8DTD4/G960FOXM8DTD5/G960FXXS8DTD1/G960FXXS8DTD4
Serial Number: R58M32VVNDZ
Imei: 352502087219910
Unique Number: CE12182CB4EB8D30057E
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Preparing...
Checking root access.
The phone is rooted by: 20.4:MAGISKSU
Reading data...
Patching certificate...
About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Successfully finished.
Finished at local time: [07.26.20 02:14:26]
WorkID: 101938512
enjoy just prass thanks button
Old 07-26-2020, 11:53   #6 (permalink)
Member: 2590583
Thanks Meter: 197
100% done
Old 09-07-2020, 12:23   #7 (permalink)
Member: 2652788
Thumbs down
Originally Posted by Chimera Tool View Post
Hi,
Best regards
Nicole
Even if we restore the original imei number, the device will remain in ng and will not give the network.
Old 09-07-2020, 14:50   #8 (permalink)
Member: 2111301
Sonork: 1651880:UzjavaAzizbek
Thanks Meter: 63
Hi,
Best regards
Nicole
if not support patch cert, hide repair imei function
Old 03-30-2021, 14:44   #9 (permalink)
Member: 2939076
Thanks Meter: 28
samsung g960 u15 imei repair done
Chimera Mobile Phone Utility version: 27.92.1510 @ 2021-03-30
Reboot
3/30/2021
11:47
AM
Repair IMEI
3/30/2021
11:35
AM
Repair IMEI
3/30/2021
11:31
AM
Repair started
Model: SM-G960F
Carrier ID: SFR
Sales Code: SFR
Country Code: France
Build Date: Mon Feb 15 14:58:33 KST 2021
PDA Version: G960FXXSFFUB3 [february 2021, rev3]
Phone Version: G960FXXSFFUB3 [february 2021, rev3]
CSC Version: G960FOXJFFUB3 [february 2021, rev3]
Product Code: SFR
HIDSw Version: G960FXXSFFUB3/G960FOXJFFUB3/G960FXXSFFUB3/G960FXXSFFUB3
Serial Number: R58K85WYL8B
Imei: 358624092365829
Imei2: 358625092365826
Connections: AT,MTP
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-03-01
Repair imei...
Current imei: 358624092365829
Repaired imei: 35
Current imei2: 358625092365826
Repaired imei2: 35
Finished at local time: [03.30.21 18:42:38]
WorkID: 129559908
Old 03-30-2021, 14:49   #10 (permalink)
Member: 2939076
Thanks Meter: 28
samsung g960f u15 patch cert done.
Repair IMEI
3/30/2021
1:40
PM
Reboot
3/30/2021
11:47
AM
Repair IMEI
3/30/2021
11:35
AM
Repair IMEI
3/30/2021
11:31
AM
Model: SM-G960F
Carrier ID: SFR
Sales Code: SFR
Imei: 359055070154605
Imei2: 359055070155453
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
The phone is rooted by: 21.4:MAGISKSU
Reading data...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
After installing new firmware, the patchcert process must be repeated.
Finished at local time: [03.30.21 18:46:24]
WorkID: 129560500
Old 03-30-2021, 15:12   #11 (permalink)
Member: 1787203
reply
Hi there,
Thank you for the feedback. Good work from you. IF you have more to share, even if the process failed, please post it so we can help.
Best regards
Sab
Chimera Team
Repair IMEI
3/30/2021
1:40
PM
Reboot
3/30/2021
11:47
AM
Repair IMEI
3/30/2021
11:35
AM
Repair IMEI
3/30/2021
11:31
AM
Model: SM-G960F
Carrier ID: SFR
Sales Code: SFR
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
Reading data...
WorkID: 129560500
Old 10-03-2021, 12:48   #12 (permalink)
Member: 36262
Thanks Meter: 25
Repair IMEI
3/30/2021
1:40
PM
Reboot
3/30/2021
11:47
AM
Repair IMEI
3/30/2021
11:35
AM
Repair IMEI
3/30/2021
11:31
AM
Model: SM-G960F
Carrier ID: SFR
Sales Code: SFR
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
Reading data...
WorkID: 129560500
hello,
how you root yours S9 ?
thank you in advance
Old 10-04-2021, 10:06   #13 (permalink)
Member: 1787203
reply
Dear User,
We would recommend using the Magisk Root manager and the EFTSU method.
We do have two guides for those two:
https://chimeratool.com/en/docs/rooting-with-eftsu
https://chimeratool.com/en/docs/root...magisk-manager
Best regards
Sab
Chimera Team
Originally Posted by Jurgis View Post
hello,
Old 10-10-2021, 13:04   #14 (permalink)
Member: 36262
Thanks Meter: 25
Dear User,
Best regards
Sab
Chimera Team
all ok, thank you.......
Old 10-11-2021, 12:17   #15 (permalink)
Member: 1787203
reply
Dear User,
No problem, if you have more issues please let us know it.
Best regards
Sab
Chimera Team
Page generated in 0.28644 seconds with 8 queries
