g970F IMEI REPAIRED AND PATCHED BUT REBOOT After repaired imei and patched cert after 1min and 20sec phone reboot and no network , |
after patch cert remove root |
And it’s working without root? |
reply Hi, please send us the work id of the problematic process and we can check your case. Best regards Nicole Quote:
reply Hi, we added some bugfix. Please update your chimera to the latest (22.89.1233) version and try again. When it is done please send us feedback about the result. Best regards Nicole Quote:
a505f in my hand and removed root working fine without reboot |
just tried patch with 22.89.1233 still reboot after 1 min no signal tried removing magisk tried just about everything buggy Successfully finished. Finished at local time: [11.07.19 15:20:25] WorkID: 78530966 |
Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N970F Sales Code: MWD Country Code: MOROCCO Timezone: Europe/Amsterdam Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Sat Jul 20 17:07:01 KST 2019 PDA Version: N970FXXU1ASGO [july 2019, revO] Phone Version: N970FXXU1ASGP [july 2019, revP] CSC Version: N970FOXM1ASGP [july 2019, revP] Product Code: MWD HIDSw Version: N970FXXU1ASGO/N970FOXM1ASGP/N970FXXU1ASGP/N970FXXU1ASGO Board Platform: EXYNOS5 Modem Platform: SHANNON5000 Serial Number: RF8M747P89N Imei: 358780108615571 Unique Number: CE061936BAA4E833197E Connections: AT,MTP Battery Status: 3.72V (19%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.08.19 16:03:32] WorkID: 78653782 |
same probleme always phone rebooted and no network |
same probleme in g975f and g970f and n975f |
Always waiting answer |
is your problem solved? |
Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N970F Sales Code: ZTO Country Code: Brazil Timezone: America/New_York Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Aug 9 16:34:02 KST 2019 PDA Version: N970FXXU1ASH5 [august 2019, rev5] Phone Version: N970FXXU1ASH5 [august 2019, rev5] CSC Version: N970FOWO1ASH5 [august 2019, rev5] Board Platform: EXYNOS5 Modem Platform: SHANNON5000 Serial Number: R58M78WDRWB Imei: 359972083170446 Battery Status: 3.66V (3%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-08-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.10.19 20:37:57] WorkID: 78912957 SAME PROBLEM AFTER PATCH CERTIFICATE REBOOTING PHONE EVEN IF I REMOVED ROOT BUT IMEI STATUS SHOW OK AFTER PATCH CERTIFICATE |
