10-20-2019, 11:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | S9 g960f u6 imi repair patch done Code: Chimera Mobile Phone Utility version: 22.65.0616 @ 2019-10-20 Printing phone history Patch Certificate 10/20/2019 10:31:56 AM Knoxguard Unlock 10/20/2019 9:49:46 AM Patch Certificate 10/20/2019 9:49:18 AM Repair IMEI 10/20/2019 9:43:04 AM SW Change 10/6/2019 5:24:29 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 16 07:57:08 KST 2019 PDA Version: G960FXXU6CSG8 [july 2019, rev8] Phone Version: G960FXXU6ASG5 [july 2019, rev5] CSC Version: G960FOVF6CSG4 [july 2019, rev4] Product Code: XFV HIDSw Version: G960FXXU6CSG8/G960FOVF6CSG4/G960FXXU6ASG5/G960FXXU6CSG8 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58K2155E6P Imei: 352802092855652 Unique Number: CE12182CA8C95203037E Connections: AT,MTP Battery Status: 3.88V (49%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.3:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. Do not check the status of the imei! It is important that the SIM card is on the phone at startup and the PIN authentication is turned OFF. The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [10.20.19 12:40:59] WorkID: 76720367 |
The Following 4 Users Say Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
10-25-2019, 11:30 | #4 (permalink) | |
Insane Poster Join Date: Aug 2010 Location: Tunisia
Member: 1364859 Status: Offline Thanks Meter: 16 | Quote:
EMERGENCY CALL | |
10-26-2019, 07:28 | #5 (permalink) |
Freak Poster Join Date: Sep 2012 Age: 43
Member: 1809124 Status: Offline Sonork: Kwam Thanks Meter: 26 | Cannot remove Rmm prenormal, Kg state checking. Phone has 2 prenormal status, I manage put KG state to checking, but Rmm still prenormal. And chimera cannot remove rmm. I Reflash phone with Old and new firmware but always present Rmm and KG Prenormal. |
10-26-2019, 07:47 | #6 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
flash this this firmware let me know if ok r not G960FXXU6CSG8 | |
The Following 2 Users Say Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
10-26-2019, 13:10 | #9 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
RMM/KG STATE : PRENORMAL FIX 2019 | HIDDEN OEM UNLOCK ENABLE https://www.youtube.com/watch?v=TBUY05mnCP8 | |
The Following User Says Thank You to amleto90 For This Useful Post: |
10-28-2019, 07:58 | #10 (permalink) | |
Member: 1809124 Status: Offline Sonork: Kwam Thanks Meter: 26 | Quote:
10-30-2019, 18:10 | #12 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Quote:
hello i have g965f , i try to patch cert but cellphone enter to upload mode whe is in procces ,any help . | |
10-31-2019, 11:08 | #13 (permalink) | |
