Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 01-11-2021, 12:26   #1 (permalink)
Member: 2372074
Sonork: 100.1663814
Thanks Meter: 167
g988b u5 imei repair done
Repair started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G988B
Carrier ID: KSA
Sales Code: PAK
Country Code: PAKISTAN
Timezone: Asia/Karachi
Android Version: 11 [RP1A.200720.012] [SDK 30]
Build Date: Sat Nov 21 18:20:16 KST 2020
PDA Version: G988BXXU5CTKG [november 2020, revG]
Phone Version: G988BXXS5BTIJ [september 2020, revJ]
CSC Version: G988BOXM5CTKF [november 2020, revF]
Product Code: PAK
HIDSw Version: G988BXXU5CTKG/G988BOXM5CTKF/G988BXXS5BTIJ/G988BXXU5CTKG
Board Platform: UNIVERSAL990
Modem Platform: SHANNON5123
Serial Number: R5CN70Y3RJF
Imei: 35xxxxxxxxxxxxx
Connections: AT,MTP
Battery Status: 3.73V (14%)
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2020-12-01
Repair imei...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Current imei: 35xxxxxxxxxxxxxxx
Repaired imei: 35xxxxxxxxxxxxxx
Current imei2: 35xxxxxxxxxxxxxx
Repaired imei2: 35xxxxxxxxxxxxxx
Successfully finished.
Finished at local time: [01.11.21 16:20:29]
WorkID: 121648813
Patch certificate started
Model: SM-G988B
Carrier ID: KSA
Sales Code: PAK
Product Code: PAK
Connections: AT,MTP
Battery Status: 3.64V (13%)
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
Checking root access.
The phone is rooted by: 1469b82a:MAGISKSU
Reading data...
Patching certificate...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Finished at local time: [01.11.21 16:22:07]
WorkID: 121648622
The Following User Says Thank You to ahmerrafiq30 For This Useful Post:
Old 01-11-2021, 12:36   #2 (permalink)
Member: 2372074
Sonork: 100.1663814
Thanks Meter: 167
file link here https://drive.google.com/u/0/uc?id=1...xport=download
Old 01-11-2021, 13:09   #3 (permalink)
Member: 2779917
Thanks Meter: 87
thanks for the info can i upgrade my u3 10Q to 11 u5 parch no problem
Old 01-11-2021, 13:25   #4 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,741
reply
Hello,
The Patch could be a problem. We faced issues with the Android 11 recently. We are working on the case, but we need time to fix it.
Old 01-13-2021, 15:36   #5 (permalink)
Member: 2372074
Sonork: 100.1663814
Thanks Meter: 167
Originally Posted by Chimera Tool View Post
Hello,
no problem only modem downgrade
Old 01-13-2021, 16:55   #6 (permalink)
Member: 1787203
reply
Yes the downgrade to Android 10 is the solution at the moment.
Old 01-14-2021, 00:35   #7 (permalink)
Member: 2779917
Thanks Meter: 87
ok thank you �� very much
Old 01-14-2021, 10:57   #8 (permalink)
Member: 1787203
reply
No problem. Hopefully you will be able to do it. If you face issues let us know it please.
Old 04-19-2022, 11:17   #9 (permalink)
Member: 2679747
Sonork: 100.107562
plz andriod 12 root file
Old 04-19-2022, 11:18   #10 (permalink)
Member: 2679747
Sonork: 100.107562
G988B U13 UD Android 12 ROOT file
Page generated in 0.17313 seconds with 8 queries
