06-23-2020, 14:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Türkiye Age: 44
Member: 341207 Status: Offline Thanks Meter: 14 | G960F S9 u8 android 10 imei repair Printing phone history Repair IMEI 23.06.2020 11:57:43 Repair IMEI 23.06.2020 09:48:04 Read Cert 23.06.2020 09:44:30 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: TUR Country Code: TURKEY Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Mar 30 14:18:37 KST 2020 PDA Version: G960FXXU8DTC5 [march 2020, rev5] Phone Version: G960FXXU8DTC5 [march 2020, rev5] CSC Version: G960FOXM8DTC5 [march 2020, rev5] Product Code: TUR HIDSw Version: G960FXXU8DTC5/G960FOXM8DTC5/G960FXXU8DTC5/G960FXXU8DTC5 Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: R58KC2WBFPX Imei: 359938073142901 Unique Number: CE11182B59994506057E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Trying on port SAMSUNG Mobile USB Serial Port (COM51) There is no proper diag port or not responding or the warranty is void The warranty is void (KNOX)! Repair imei failed. Finished at local time: [06.23.20 16:43:54] WorkID: 98701180 The warranty is void (KNOX)! ??? |
06-23-2020, 15:29 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,760 | reply Hi, please read carefully the description of our update: Added New Read Codes Online, Repair IMEI and Read/Write Cert Method for Exynos Models (Root: NO, Knox: 0, BIT: ANY) KNOX must be 0 for the imei repair process. When your device's KNOX 1, process can not be done. Best regards Nicole Quote:
06-23-2020, 16:29 | #3 (permalink) |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Offline Thanks Meter: 122 | bro all user need repiar and patch cert. i repiar imei done,how to patch cert new security? only repiar org imei.change imei done but imei cert ng and no solution yet!! |
The Following User Says Thank You to gsm-ok For This Useful Post: |
07-26-2020, 10:41 | #5 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | [2:36 AM, 7/26/2020] Hafiz Imran: Chimera Mobile Phone Utility version: 25.48.1328 @ 2020-07-26 Printing phone history Patch Certificate 7/25/2020 8:10:05 AM Patch Certificate 7/25/2020 7:46:06 AM Patch Certificate 7/25/2020 7:44:32 AM Patch Certificate 7/25/2020 7:41:36 AM Patch Certificate 7/25/2020 7:40:15 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Apr 20 13:04:56 KST 2020 PDA Version: G960FXXS8DTD4 [april 2020, rev4] Phone Version: G960FXXS8DTD1 [april 2020, rev1] CSC Version: G960FOXM8DTD5 [april 2020, rev5] Product Code: XFA HIDSw Version: G960FXXS8DTD4/G960FOXM8DTD5/G960FXXS8DTD1/G960FXXS8DTD4 Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: R58M32VVNDZ Imei: 352502087219910 Unique Number: CE12182CB4EB8D30057E Connections: AT,MTP Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.26.20 02:14:26] WorkID: 101938512 enjoy just prass thanks button |
03-30-2021, 14:44 | #9 (permalink) |
Insane Poster Join Date: Dec 2019 Location: bhakkar
Member: 2939076 Status: Offline Thanks Meter: 28 | samsung g960 u15 imei repair done Chimera Mobile Phone Utility version: 27.92.1510 @ 2021-03-30 Printing phone history Reboot 3/30/2021 11:47 AM Repair IMEI 3/30/2021 11:35 AM Repair IMEI 3/30/2021 11:31 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Carrier ID: SFR Sales Code: SFR Country Code: France Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Feb 15 14:58:33 KST 2021 PDA Version: G960FXXSFFUB3 [february 2021, rev3] Phone Version: G960FXXSFFUB3 [february 2021, rev3] CSC Version: G960FOXJFFUB3 [february 2021, rev3] Product Code: SFR HIDSw Version: G960FXXSFFUB3/G960FOXJFFUB3/G960FXXSFFUB3/G960FXXSFFUB3 Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: R58K85WYL8B Imei: 358624092365829 Imei2: 358625092365826 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-03-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 358624092365829 Repaired imei: 35 Current imei2: 358625092365826 Repaired imei2: 35 Successfully finished. Finished at local time: [03.30.21 18:42:38] WorkID: 129559908 |
03-30-2021, 14:49 | #10 (permalink) |
Member: 2939076 Status: Offline Thanks Meter: 28 | samsung g960f u15 patch cert done. Chimera Mobile Phone Utility version: 27.92.1510 @ 2021-03-30 Printing phone history Repair IMEI 3/30/2021 1:40 PM Reboot 3/30/2021 11:47 AM Repair IMEI 3/30/2021 11:35 AM Repair IMEI 3/30/2021 11:31 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G960F Carrier ID: SFR Sales Code: SFR Country Code: France Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Feb 15 14:58:33 KST 2021 PDA Version: G960FXXSFFUB3 [february 2021, rev3] Phone Version: G960FXXSFFUB3 [february 2021, rev3] CSC Version: G960FOXJFFUB3 [february 2021, rev3] Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Imei: 359055070154605 Imei2: 359055070155453 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-03-01 Preparing... Checking root access. The phone is rooted by: 21.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.30.21 18:46:24] WorkID: 129560500 |
03-30-2021, 15:12 | #11 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,760 | reply Hi there, Thank you for the feedback. Good work from you. IF you have more to share, even if the process failed, please post it so we can help. Best regards Sab Chimera Team Quote:
10-03-2021, 12:48 | #12 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: lithuania ,kedainiai Age: 60
Member: 36262 Status: Offline Thanks Meter: 26 | Quote:
how you root yours S9 ? thank you in advance | |
10-04-2021, 10:06 | #13 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,760 | reply Dear User, We would recommend using the Magisk Root manager and the EFTSU method. We do have two guides for those two: https://chimeratool.com/en/docs/rooting-with-eftsu https://chimeratool.com/en/docs/root...magisk-manager Best regards Sab Chimera Team |
10-10-2021, 13:04 | #14 (permalink) | |
