10-07-2021, 18:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Honor 30 BMH-AN10 chip is damaged after removing FRP with Fastboot Erase tool I tried with Chimera to remove but it said to do testpoint and as I didn't wanted to open phone I bought the original key from Huawei and removed using Fastboot Erase tool. Is it possible to fix it just by flashing a full firmware file to the phone? Anybody can tell me ? Chimera log: Work log (153409373) Code: Chimera Mobile Phone Utility version: 29.89.1210 @ 2021-10-07 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished The procedure has been canceled. Finished at local time: [10.07.21 14:52:51] WorkID: 153409373 The phone had this firmware installed when I tried to remove FRP Code: Reading info.....OK Device Model: BMH-AN10 Device Firmware: :BMH-N19 4.0.0.160(C10E3R2P3) Base Firmware: :BMH-LGRP2-OVS 11.0.0.160 Custom Firmware: :BMH-N19-CUST 11.0.0.3(C10) Preload Firmware: :BMH-N19-PRELOAD 11.0.0.3(C10R2) BMH-N19 11.0.0.155(C10E3R4P3)_Firmware_EMUI11.0.0_05016TVU I can buy Halabtech licence again (to download the files) if it can work to repair the phone by just flashing.. Thanks |
10-08-2021, 07:42 | #2 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Because I see Sigmakey has implemented a special feature to repair this problem, but I don't have Sigmakey yet - only Chimera... That's why I am asking |
