10-09-2021, 15:56 | #31 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Chimera starts the job but asks for restart and phone to be reconnected to app .... the second time just states Failed to read. Tried multiple times on different usb ports take screen shot Printing phone history Huawei Id & Frp Remove 10/9/2021 2:28 PM Huawei Id & Frp Remove 10/9/2021 10:42 AM Huawei Id & Frp Remove 10/9/2021 10:39 AM Huawei Id & Frp Remove 10/9/2021 10:31 AM Load Factory Fastboot 10/9/2021 10:29 AM Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished We counld't identify the device, please select manually, if present! Uploading data Uploading data Failed to read, try to hard-reset the phone Finished at local time: [10.09.21 17:53:28] WorkID: 153681565 |
The Following User Says Thank You to tintome For This Useful Post: |
10-09-2021, 20:25 | #36 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Trujillo - Perú
Member: 432025 Status: Offline Thanks Meter: 122 | contected but dont erase huawei account, kirion 810 (JNY LX2) show error second step |
The Following 2 Users Say Thank You to WallfireX For This Useful Post: |
10-09-2021, 21:31 | #37 (permalink) | |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Quote:
Dear mate, So do you mansion like this, 10K Ω (D+) + VCC & 10K Ω (D+) + GND Colour Code resistor-10k-ohm | |
The Following User Says Thank You to -=P.F.U=- For This Useful Post: |
10-10-2021, 08:29 | #39 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Peshawar, Pakistan Age: 39
Member: 2622185 Status: Offline Sonork: 100.1675196 Thanks Meter: 19 | Yal-L21 Usb Mtp blocked Dear Chimera Tool Yesterday I was trying a Nova 5T with emui 11, since at that time there was no solution, so downgraded to emui 10 using hisuite proxy method. But after successful downgrade Usb Mtp blocked, I again upgraded to emui 11 using settings => Syste Update. but no success, no usb mtp. now does this method will work on my blocked usb mtp nova 5T ? |
10-10-2021, 11:46 | #41 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,030 | ELS LX9 after remove huawei id phone still locked to huawei id Chimera Mobile Phone Utility version: 29.90.1720 @ 2021-10-10 Printing phone history Huawei Id & Frp Remove 10/10/2021 7:59 AM Removing Huawei account Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.10.21 13:04:46] WorkID: 153752485 |
10-11-2021, 10:30 | #42 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,670 | reply Dear User, The cable is workable for the Harmony OS and with Android 11. The EMUI 10/9 versions won't need this cable. They have to be still used with the original Huawei cable. Best regards Sab Chimera Team |
10-11-2021, 10:41 | #45 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,670 | reply Dear User, Can you please send us a few photos of the device itself? We would like to check if its really a P40 PRO. Please send it in a Private message. Best regards Sab Chimera Team Quote:
