06-01-2017, 15:31 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Could you upload to this post the operation performed with chimera please? Here are the supported functions for this model: Samsung Galaxy A5 2016 Model: SM-A510F Supported features ✓ SW Change ✓ Unlock ✓ Read Codes ✓ Repair IMEI ✓ Info ✓ Root / Unroot ✓ Read / Write certificate ✓ Restore / Store backup ✓ Reset FRP Lock ✓ Repair EFS ✓ Reset Screen Lock ✓ Reset FRP Lock ✓ Firmware Compatibility ✓ Patch Certificate | |
06-01-2017, 15:42 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Flash this modem CP A510FXXU4CQDH Download CP_A510FXXU4CQDH_CP6274651_CL11072109_QB13281890_R EV00_user_low_ship.tar.rar | GSM FirmWare After, root and try to repair Imei https://download.chainfire.eu/937/CF...xx-sma510f.zip |
06-02-2017, 07:51 | #5 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Hungary Age: 64
Member: 207590 Status: Offline Thanks Meter: 51 | Quote:
[Repair EFS started]  Unable to detect imei number and baseband version. It seems that the modem does not work or network is unavailable/disabled.  Please reinstall a complete stock firmware and try again! Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A510F Sales Code: XEH Country Code: Hungary Android Version: 6.0.1 [MMB29K] Build Date: Fri Mar 3 16:39:47 KST 2017 PDA Version: A510FXXU4BQC1 [march 2017, rev1] CSC Version: A510FOXX4BQC1 [march 2017, rev1] Board Platform: EXYNOS5 Serial Number: RZ8H20MRZ6B Battery Status: 4.31V (100%) Network Type: GSM SIM Status: NOT_READY Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-03-01 Repairing EFS... Backing up EFS. Repairing EFS. Unable to repair EFS. Finished at local time: [06.02.17 08:51:25] WorkID: 21908235 | |
06-02-2017, 08:01 | #6 (permalink) |
Member: 207590 Status: Offline Thanks Meter: 51 | after flash modem, try to repaire imei [Repair started]  Unable to detect imei number and baseband version. It seems that the modem does not work or network is unavailable/disabled.  Please reinstall a complete stock firmware and try again! Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A510F Sales Code: XEH Country Code: Hungary Android Version: 6.0.1 [MMB29K] Build Date: Fri Mar 3 16:39:47 KST 2017 PDA Version: A510FXXU4BQC1 [march 2017, rev1] CSC Version: A510FOXX4BQC1 [march 2017, rev1] Board Platform: EXYNOS5 Serial Number: RZ8H20MRZ6B Battery Status: 4.20V (100%) Network Type: GSM SIM Status: NOT_READY Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-03-01 Repairing imei... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Repair imei failed. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. Unable to Repair imei Finished at local time: [06.02.17 08:59:02] WorkID: 21908302 |
06-02-2017, 08:05 | #7 (permalink) |
Member: 207590 Status: Offline Thanks Meter: 51 | [Read/Write certificate started]  Unable to detect imei number and baseband version. It seems that the modem does not work or network is unavailable/disabled.  Please reinstall a complete stock firmware and try again! Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A510F Sales Code: XEH Country Code: Hungary Android Version: 6.0.1 [MMB29K] Build Date: Fri Mar 3 16:39:47 KST 2017 PDA Version: A510FXXU4BQC1 [march 2017, rev1] CSC Version: A510FOXX4BQC1 [march 2017, rev1] Board Platform: EXYNOS5 Serial Number: RZ8H20MRZ6B Battery Status: 4.20V (100%) Network Type: GSM SIM Status: NOT_READY Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-03-01 Writing cert to phone... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Write cert failed. The phone is permanently rooted by custom root image. To avoid FRP/Reactivation/EE lock, please install a stock firmware. Unable to write cert. Finished at local time: [06.02.17 09:04:13] WorkID: 21908339 |
06-02-2017, 12:47 | #8 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Dear Sir, please install complete original stock firmware on the device. Without working modem the imei repair can not be done. Best regards Nicole Quote:
06-02-2017, 12:52 | #9 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear user! If you do not have NVM or EFS support then you can do the following: 1. The first thing is to have imei at 0000-0000 or Unknown 2. Version 6.0.1 3. Root the phone with CF Autorrot 4. Enable USB Debugging OEM Unlock 5. Install a Root Explorer / Root Explorer v.3 and access the EFS folder 6. In the EFS folder you have to delete all the contents except the "FactoryApp" and "prov_data" folders and turn off the phone 7. Flash via Odin the Factory_Binary of model G510F COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_Q B12832200_REV00_user_mid_noship.tar.md5.rar (Pass to decompress into the .rar) https://www.4shared.com/rar/e9Ua6a0j...A510FXXU4.html Once you turn on your phone, choose Restart 8. Once the Restart is done, press the "IME" button and a keyboard will appear with which we proceed to check the IMEI with * # 06 # and we will see that our imei is already correct again 9. Flash with a Stock Rom 4 files IMEI Recovered and ready |
06-02-2017, 13:13 | #11 (permalink) | |
06-02-2017, 13:26 | #12 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir, download the file and once downloaded double click with the mouse and the left button and you will see the password. The fimware A510FXXU4BQC1 version 6.0.1 you can find it in the support of Chimera or the official page of samsung. Also here: https://samsung-firmware.org/model/SM-A510F/ |
